#26 |
Hollister Road Co.
Re: Parting out - 1957 3600 3/4 ton truck
Well if they say no I'll send you the book pages that say custom is the nice cab deluxe is the standard cab.
#27 |
![]() Join Date: Jun 2007
I am thinking this might be Chevrolet-specific information - I am pretty sure GMC did not call non-Deluxe cabs Deluxe....we are investigating this further. Always good to learn new / correct information so we share with others the right knowledge
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
#28 |
I have to ask...is there any chance your inline 6 could be a 261 and not a 235. The 261's are getting hard to find.
Thanks, Jeff |
#29 |
The inline 6 could be anything. If you can tell me where to find some identifying numbers I would be glad to identify it. It is a complete motor and trans. the trans is a 4 speed with a granny first gear. the e-brake is actually on the output shaft and has a circular brake pad around it that holds the shaft.
The extra body I have is a '55 and it is a custom small window. It has all the holes around the window and doors for the mouldings that were on it. The doors are now sold. but I still have a complete cab for $450.00. needs the outside rear corners and the lower door hinge sills. most everything else is pretty good condition. I'll even repair it (weld on new parts, no body work) if you pay the bill.
My Build: 57 Chevy Pro-Street |
#30 |
![]() Join Date: Mar 2015
I guess I unknowingly set off a controversy about custom vs. deluxe cabs.
I'm happy that I learned something new and its great information to have. I have a small back window cab without custom trim and was considering replacing the cab with a large back window version (if I can find was reasonably priced). Sounds like both of yours are small back windows like mine though.
56 Chevy step-side 68 Chevy Suburban 69 Corvette Stingray 00 BMW 325 (Daily driver) 09 BMW M3 18 GMC Acadia (Wife's daily driver) |
#31 |
[QUOTE=ptc;7192068]The inline 6 could be anything. If you can tell me where to find some identifying numbers I would be glad to identify them.
The 7 digit casting numbers are on the distributor side and below the line of the distributor mounting hole. They may be in-front-of, or to the rear of the fuel pump, depending on the year and c.i. The 261 will also carry with it captain's bars ( l l ) which will be cast back by the starter, usually between and above the CON number and the date code ( a letter followed by three or four numbers ). If you could just reply with the 7 digit casting number I can decode year and c.i. Thanks, Jeff |
#32 | |
The whole thing is up for sale as a 235 with trans now for $300!!! is that deal or what? I just heard of a local SF woman who junked an old MAC computor her husband had at the house when he passed away, the e-junk company found out it was worth $200K and is trying to find her to split the money with her.... If its a 261 I'll split the extra value proceeds with ya!
#33 |
Your 235 deal is great but I'm set on a 261. I've got the correct 261 head and am trying to rebuild my '52 Chevy pickup into a strong everyday driver, just can't find the block. Plus, you're just a few miles away. Well, here's hoping!
#34 |
Ok the numbers by the fuel pump are 3837004 with GM under it.
the numbers by the rear of block are CON4 L286 Posted via Mobile Device |
#35 |
'55-'57 235ci. Thanks for checking.
#36 |
do you still have the interior handles. If they are not pitted i'd be interested in all 4.
#37 |
![]() Join Date: Jun 2015
I can use the light switch and ignition if it has the key/s. Shipping is to 91945
#38 |
![]() Join Date: Sep 2007
still interested in the valve cover if you still have it
1967custom |
#39 | ||
sorry Mike engine was sold with trans and everything all together...
#40 | |
The next biggest error is Cab identification. Most think that a De Luxe Cab was the better cab with a big window and a chromed heater panel in the dash. Again not so. De Luxe was the base model cab that could be optioned with a big window and a deluxe heater. A Custom cab was the high end cab that would have been optioned with a chrome trim package and better interior with or without a big window or heater. The spare cab I have available is a 1955 CUSTOM CAB and has holes for all the trim!!! it is totally bare $450.00- it had the stainless steel trim all around it. It is a small back window. it has minimal rust in the typical areas. It has been blasted and thats why it has surface rust on the outside. A spray of Rust Remover and this will be clean steel again..... Needs rear corners replaced, lower door jambs. couple small floor patches. Can do all repairs if wanted, I can do a big back window conversion too if needed @ cost+ welding time.
My Build: 57 Chevy Pro-Street Last edited by ptc; 10-20-2015 at 02:56 PM. |
#41 | |
#42 |
I need a fan shroud. Did that truck come with one?
John Z 1962 Chevy C10 Stepside 62 Barnfind My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513 |
#43 |
Front spindles availible?
I know they're a PIA to seperate. Chris |
#44 |
#45 |
Started a new post with parts listed that are left. thx
#46 |
Does your truck have the clutch lever ?? (inboard of the frame).
thanks bb
http://67-72chevytrucks.com/vboard/s...d.php?t=385404 |
#47 |
Yes it does
#48 |
I need just the lever, if you had the rod and other linkage in good shape I might take that as well. Shipped to 93004 ??
#49 |
Something like this??
#50 |
Spindles?
