07-10-2015, 09:45 PM | #201 |
Re: My 89 CC Dually: Double Wide
I know you know better
Long live SLIM ------------------ At least try to buy American |
07-18-2015, 11:49 PM | #202 |
Gauges/bezel done. Speedo & tach both work. Something weird going on w/fuel gauge when using the pass side tank. Gotta research that one.....
Got the crossover duct installed for the drivers side a/c vent. Adjusted the toe. Much better. Progress.....
08-25-2015, 01:17 PM | #203 |
Still finishing up on my side project w/my buddy & his boys. We're working on cleaning up the wiring now & hope to have this thing ready to fire up again soon (1st time in over a year).
Over the last year or so, it's had:
He's already aquired all the needed parts to swap in some era correct bucket seats & the SS console shifter so the interior is right around the corner too. His boy is soooooo ready to start pounding the streets! Hope to have my dually up soon for front end aligning & then off to get the bed Line-X'd.
08-26-2015, 09:57 AM | #204 |
I'm just glad to be here!
Good looking El Camino. He does look ready to go!
Hope to see the dually done soon...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
09-29-2015, 08:12 AM | #205 |
Village Idiot....
Any Dually progress?
http://www.hubgarage.com/mygarage/n2billet -67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold -71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold |
09-29-2015, 09:40 AM | #206 |
Is waiting progress??
My side project is complete (the part I helped with anyway). My trailer will be empty & the elcamino parts occupying space in the shop are w/the camino or have been recycled/trashed. Now back to the dually. I did swap in new inner/outer tie-rod ends last night. They were the last items on the front suspension that had not been done & I wanted to have everything fresh before aligning. My buddy assures me that he will have time to align the front end (& check rear thrust) before this Friday. Hopefully this happens. Then I'll move forward on the bed + stereo completion next week & try putting some road miles on it to work the bugs out. I'll swing by your place hopefully during some of those miles (and a car wash... that thing is filthy) since I'll be on that side of town using the dually to bring home my 64's chassis.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 09-29-2015 at 09:47 AM. |
09-29-2015, 11:24 AM | #207 |
Does this mean you are going to need help swapping bodies on to that chassis for the '64 this year? Last time we talked about it you needed some help to get it done and you have that frame I could use when you get that swapped around...
09-30-2015, 09:28 PM | #208 | |
I did pull the dually out last night after work to reset the toe. After moving forward & backing up a dozen or so times I have it close. I also yanked an 1/8" shim from all 4 spots for some slight neg camber @ my planned ride height (~27" @ front wheel well C/L). It still has something wrong mechanically. If it idles for extended periods (6-10 mins), you can hear slight backfiring in the exhaust. I noticed it before but thought when I heard it yesterday I would just drive it around my neighborhood & see if that helped clear it up. After the 3rd time around the circle (~7/10th of a mile), I put my foot into it aggressively & it does it then as well. I don't know what it could be @ this point & can't seem to find much TBI support/help locally. Frustrating. No alignment yesterday. No alignment today......
10-08-2015, 09:08 AM | #209 |
Progress!!
10-08-2015, 10:48 AM | #211 |
Looks real good. Getting close!
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
10-08-2015, 12:00 PM | #212 |
I tried to skim through the entire thread but didn't find it but what size are those rolling sleeve airbags in the rear??
10-08-2015, 12:42 PM | #213 | |
6.5" min height 10.5 installed height 13" max height 9" OD It's the bag they supplied for their original 'bolt-on' C-30 HD Air Bar kit.
10-08-2015, 03:28 PM | #214 |
Thanks. Just order me a pair
10-18-2015, 01:26 PM | #215 |
Installing the bed solo was a PITA but I got it done. The additional weight made a noteable difference in ride quality which was a relief.
So w/that accomplished, I scraped off the 3yr expired registration/inspection stickers, knocked off the heavy dust, plugged in all the lights & cruised up the street for it's maiden voyage beyond my neighborhood.....
10-18-2015, 02:49 PM | #216 |
Any pics with it aired down?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
10-18-2015, 03:20 PM | #217 |
Not w/the bed on. I'll prob get a couple one day this week.
10-18-2015, 04:23 PM | #218 |
Your dually looks really good at that height. Congratulations on the maiden voyage!
10-18-2015, 05:22 PM | #219 |
It followed me home?
good for your SCOTI !! Hope there arent many bugs to work out
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
10-18-2015, 06:56 PM | #220 |
67-72 parts collector,…
Looks perfect!
10-19-2015, 12:14 AM | #221 |
Cant wait to see them. Very clean work (like all your other work).
10-19-2015, 07:19 AM | #222 |
Thanks guys.
It was a good feeling buzzing up the road w/it back together. I went back to check off the last few items on my 'punchlist' yesterday & what a list! I hope to get it up today for inspection. If so, I'll be legal by noon tomorrow & will try to get the bed Line-X'd pending weather by the end of the week (supposed to rain this week after Tuesday).
10-19-2015, 08:08 PM | #223 |
Tuckin caps.....
10-20-2015, 03:05 AM | #225 |
In the Forgotten far North.
your tailgate insert.... where did you get it?
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
