Old 10-10-2015, 09:39 AM   #251
RodsGreen10
RodsGreen10's Avatar
Re: 1976 Square "Simple Green"
Bottom of LCA. Bolts holding in coil block.
RodsGreen10 is offline   Reply With Quote
Old 10-10-2015, 11:16 AM   #252
muthstryker
muthstryker's Avatar
Those came out great! Now get them installed!
Matt
muthstryker is offline   Reply With Quote
Old 10-10-2015, 11:44 AM   #253
RodsGreen10
Lol! I got to finish putting them together first. That will be this evening or tomorrow. Going to TN vs GA game. But I will get them on and take pics for everyone.
Old 10-11-2015, 11:33 AM   #254
RodsGreen10
Upper
Old 10-11-2015, 11:34 AM   #255
RodsGreen10
Upper 2
Old 10-11-2015, 11:35 AM   #256
RodsGreen10
Upper done
Old 10-11-2015, 11:35 AM   #257
RodsGreen10
Lower
Old 10-11-2015, 11:36 AM   #258
RodsGreen10
Lower 2
Old 10-11-2015, 11:37 AM   #259
RodsGreen10
Lower 3
Old 10-11-2015, 11:38 AM   #260
RodsGreen10
Lower 4
Old 10-11-2015, 11:39 AM   #261
RodsGreen10
Lower done
Old 10-11-2015, 11:39 AM   #262
RodsGreen10
Just need to install the lower ball joints and time for install! To put the control arms together was easy peasy!
Old 10-13-2015, 12:01 AM   #263
conman585
conman585's Avatar
Do you have a part number for the gas-a-just front shocks you're running with the porterbuilt front shock extenders??
conman585 is offline   Reply With Quote
Old 10-13-2015, 05:02 AM   #264
RodsGreen10
I think you are meaning front shock relocators? Here is the part number it is KYB-KG5474. Buy them from rockauto they have the best price on them.
Old 10-13-2015, 05:05 AM   #265
RodsGreen10
Shock stud mounted on LCA. This stud did not come with control arms that will have to be purchased separate from your local parts store. I will be pressing the ball joint in today!
Old 10-13-2015, 08:46 AM   #266
muthstryker
those looks really good, makes you almost not want to cover them up!
Matt
Old 10-13-2015, 09:09 AM   #267
RodsGreen10
Lol. Yes they do. They won't be covered up as of now cause I still am not done with my inner fenders got sidetracked. So I can look at them every time I open up the hood lol. I am ready to get them on and hit the side roads and throw them into a curve or 2. Plus a spirited run up interstate 40 at about 100 plus lol.
Old 10-13-2015, 11:34 AM   #268
conman585
conman585's Avatar
Semantics... thanks for the part #. Your truck is sick
Old 10-13-2015, 11:39 AM   #269
RodsGreen10
Anytime. Thanks appreciate it.
Old 10-13-2015, 11:40 AM   #270
conman585
conman585's Avatar
Wow I totally wouldn't have guessed they were from a Toyota. I do think you mentioned that earlier in your build. Thanks for narrowing it down.
Are the rear Gas-a-just shocks just stock length for a C10?
Old 10-13-2015, 11:43 AM   #271
RodsGreen10
Man I felt the same way when I saw that. That's why I posted it lol. Yes I have the rear gas a just part number also I have them on my truck also give me a min. No they are for lowered I have 8" drop in rear. 6.5" drop in front.
Old 10-13-2015, 11:46 AM   #272
RodsGreen10
Rear KYB-KG5401
I took the part numbers for the shocks Nate aka Porter lol uses in his kits and called KYB and had them cross reference them over to the gas a just.
Old 10-13-2015, 11:54 AM   #273
conman585
conman585's Avatar
Rear KYB-KG5401
Oh really? I have about a 6" rear drop and plan to run shock extenders. I saw a couple pages back that you have them too. I thought the point of the extenders was to run stock-ish shocks. My rear end rides like crap right now, the shocks are damn near horizontal. I'm lookin to stiffen it up and the gas-a-just seem the way to go. How do you like the ride in the rear with the extenders/shocks you just mentioned.
Old 10-13-2015, 12:00 PM   #274
RodsGreen10
Yes really lol. The purpose of me putting the shock extenders on was to correct the angle of the rear shock. My truck has never rode so good. It rides better than the wife's new SUV. That is the reason I still have the gas a just on. I love the ride!
The specs on the rear KYB I posted is Ext. 18.07 Comp. 11.57
Old 10-13-2015, 12:03 PM   #275
SCOTI
SCOTI's Avatar
Most likely, the problem lies more in the "near horizontal" angle than anything else.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
