10-10-2015, 09:39 AM | #251 |
Re: 1976 Square "Simple Green"
Bottom of LCA. Bolts holding in coil block.
10-10-2015, 11:16 AM | #252 |
Those came out great! Now get them installed!
Matt |
10-10-2015, 11:44 AM | #253 |
10-11-2015, 11:33 AM | #254 |
Upper
10-11-2015, 11:34 AM | #255 |
Upper 2
10-11-2015, 11:35 AM | #256 |
Upper done
10-11-2015, 11:35 AM | #257 |
Lower
10-11-2015, 11:36 AM | #258 |
Lower 2
10-11-2015, 11:37 AM | #259 |
Lower 3
10-11-2015, 11:38 AM | #260 |
Lower 4
10-11-2015, 11:39 AM | #261 |
Lower done
10-11-2015, 11:39 AM | #262 |
Just need to install the lower ball joints and time for install! To put the control arms together was easy peasy!
10-13-2015, 12:01 AM | #263 |
Do you have a part number for the gas-a-just front shocks you're running with the porterbuilt front shock extenders??
10-13-2015, 05:02 AM | #264 |
I think you are meaning front shock relocators? Here is the part number it is KYB-KG5474. Buy them from rockauto they have the best price on them.
10-13-2015, 05:05 AM | #265 |
Shock stud mounted on LCA. This stud did not come with control arms that will have to be purchased separate from your local parts store. I will be pressing the ball joint in today!
10-13-2015, 08:46 AM | #266 |
those looks really good, makes you almost not want to cover them up!
Matt |
10-13-2015, 09:09 AM | #267 |
Lol. Yes they do. They won't be covered up as of now cause I still am not done with my inner fenders got sidetracked. So I can look at them every time I open up the hood lol. I am ready to get them on and hit the side roads and throw them into a curve or 2. Plus a spirited run up interstate 40 at about 100 plus lol.
10-13-2015, 11:34 AM | #268 |
10-13-2015, 11:39 AM | #269 |
10-13-2015, 11:40 AM | #270 |
10-13-2015, 11:43 AM | #271 |
Man I felt the same way when I saw that. That's why I posted it lol. Yes I have the rear gas a just part number also I have them on my truck also give me a min. No they are for lowered I have 8" drop in rear. 6.5" drop in front.
10-13-2015, 11:46 AM | #272 |
Rear KYB-KG5401
I took the part numbers for the shocks Nate aka Porter lol uses in his kits and called KYB and had them cross reference them over to the gas a just. |
10-13-2015, 11:54 AM | #273 |
Oh really? I have about a 6" rear drop and plan to run shock extenders. I saw a couple pages back that you have them too. I thought the point of the extenders was to run stock-ish shocks. My rear end rides like crap right now, the shocks are damn near horizontal. I'm lookin to stiffen it up and the gas-a-just seem the way to go. How do you like the ride in the rear with the extenders/shocks you just mentioned.
10-13-2015, 12:00 PM | #274 | |
The specs on the rear KYB I posted is Ext. 18.07 Comp. 11.57 |
10-13-2015, 12:03 PM | #275 | |
