Old 10-13-2015, 09:01 PM   #1
GMJimmy
Which oil pan?
I've got a new project. A 68 SWB fleetside with a 5.3 LS engine in it. The stock oil pan is too low and I'm planning on replacing it with a Holley 302-1 or a 302-2 or something better if there is one. Anybody have any ideas?
Thanks.
GMJimmy is offline   Reply With Quote
Old 10-13-2015, 09:24 PM   #2
cableguy0
Re: Which oil pan?
I cant answer your question but Im going to move this to the Ls section for you. The guys there will be able to help you out.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-13-2015, 09:34 PM   #3
hugger6933
Re: Which oil pan?
The H3 pan may be a ton cheaper and I know the S-10 guys are using them for that type of truck so it should be plenty for yours. Jim
hugger6933 is offline   Reply With Quote
Old 10-13-2015, 09:44 PM   #4
TwinsSpeedShop
Re: Which oil pan?
The f body pan was $300 to my door. Read up on the Holley pans, you need to modify the windage tray which scares me
TwinsSpeedShop is offline   Reply With Quote
Old 10-13-2015, 10:15 PM   #5
GMJimmy
Re: Which oil pan?
Thanks... I'm not sure where to ask this.
Old 10-13-2015, 10:16 PM   #6
GMJimmy
Re: Which oil pan?
ooops
Old 10-13-2015, 10:17 PM   #7
GMJimmy
Re: Which oil pan?
What is the H3 pan?
How low is the F body pan in a 68?
Old 10-14-2015, 01:30 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Which oil pan?
The "H3" pan is another name for something called the LH8 or "Hot Rod" Pan. Allow me to expound: The Hummer H3 got made for a few end-run years in a model called the Alpha, which replaced the 3.7 5cylinder with a setup for the 5.3 but still retaining hummers AWD system. When GM did that version of the truck, they approached it much like a hot rodder would, and simply went into the GM parts locker for a solution.
GM had started selling crate motors and replacement motors by that time, and they had an existing part # in their "Hot Rod Swap Kit" which, sure enough, just happen to be the SAME pan that fits the Hummer. For most purposes, its the universal solution.
It WILL still hang about to crossmember level, but not below, and clear the crossmember just fine.
There are multiple sources, but searches for "GM Hot Rod Pan, LH8 Pan, or H3 Alpha Pan" will all return the same part #'s. I suggest checking places like Nalley (which sells GM part #'s for a few $$ less than most local dealers and no tax).
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-14-2015, 07:01 AM   #9
Paul Y
Re: Which oil pan?
Could always look at ebay for a CTSV pan. Picked up a new one including windage tray and dipstick for $100 + the ride.
Not fitted the engine yet but looks like it will give plenty of clearance over the stock truck one.
P.
Paul Y is offline   Reply With Quote
Old 10-14-2015, 04:29 PM   #10
boostedc10
boostedc10's Avatar
Re: Which oil pan?
Incorrect info removed at request of the poster.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 10-14-2015, 09:55 PM   #11
GMJimmy
Re: Which oil pan?
Thanks for all the help everyone. The muscle car pan kit at jegs for 149.00 with all I need sure beats 350 for the Holley 302-2. The Holley looks nicer and holds 3/4 of a qt. more oil but when you're on a budget........
Thanks again.
Old 10-14-2015, 10:00 PM   #12
dayj1
Re: Which oil pan?
The GM muscle car pan is a great deal when you need to replace a truck pan. Unfortunately, it's not much help for gaining clearance over the truck pan. The H3/muscle car pan is just over 1/2 shallower than a truck pan (7.75" vs 8.34"). For comparison, a CTS-V pan is 7" deep, and F-Body pan is 5.62" and the Holley 302-1 is 5.71".
Here's a link to various oil pan dimensions:
http://www.dirtydingo.com/shop/pages.php?pID=8&CDpath=0
And a comparison of the Holley pan to the H3 pan:
dayj1 is offline   Reply With Quote
Old 10-14-2015, 10:08 PM   #13
boostedc10
boostedc10's Avatar
Re: Which oil pan?
Yup Dayj1 is right. Don't know how I missed the actual numbers on the jegs page too. Thanks for the correction Dayj1. For some reason I thought that pan was closer to the fbody pan.
Brandon
Instagram: DRVFSTR
Old 10-15-2015, 01:05 AM   #14
68c10airstream
68c10airstream's Avatar
Re: Which oil pan?
I installed the "F" body pan and made my own motor mount brackets using the organ donor 2001 ls mounts. I chose the "F" body pan for the additional reason it's the thinnest up front below the timing cover. My steering linkage center section ( stock linkage) almost rubs the pan as it passes under the front lip. The clearance is 1/4" max. The low sump area is still higher than the factory cross member by maybe 1/2".
68c10airstream is offline   Reply With Quote
Old 10-15-2015, 09:28 AM   #15
Aruba1
Re: Which oil pan?
Jimmy,
I just did this and I used a stock truck oil pan. I can take picture tonight and post them but the truck pan is just fine and fits like a glove. Personally I don't see any reason to go with the lower profile pan. Have you already installed your engine and realized that you want a lower profile pan? If not, and if you are on a budget, I'll say go with stock and spend the money elsewhere. Believe me, there will be more i$$ue$ that will come along with this swap.
Aruba1 is offline   Reply With Quote
Old 10-15-2015, 10:18 AM   #16
dayj1
Re: Which oil pan?
With most mounts the truck pan is going to be lower than the crossmember. Usually in the range of about 3/4" lower. That is not a problem at all for stock height trucks. But, if you lower the truck enough, it becomes a real possibility that you'll catch the oil pan on something. It's much better to drag to crossmember than the oil sump. I don't know the OP's reasoning behind wanting a shallower oil pan, but this is one possibiilty.
Old 10-15-2015, 10:35 AM   #17
LockDoc
The Older Generation
LockDoc's Avatar
Re: Which oil pan?
This is true. I just talked to a guy a week ago Sunday that broke his oil pan because it hung lower than his cross member. He said that it was not a fun experience...... Also had a guy looking at my '67 Panel when I was putting gas in it and while talking to him he mentioned that he had his truck oil pan sectioned and welded back together to shorten it. Not sure how that would work but he said he hadn't had any trouble with it. I would think you would have to get a shorter pickup tube for the oil pump. Dunno what they look like inside the pan.
LockDoc
Leon
Old 10-15-2015, 02:25 PM   #18
Aruba1
Re: Which oil pan?
Oh ok, I now see the reasoning behind the question as a lot of people likes to lower these truck. Mine sits between 1-2 higher since I have HD suspension so probably that is why it was a noticeable issue to me. I'll check when I get home tonight how mine sits and I'll also post some pictures.
Old 10-15-2015, 05:02 PM   #19
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Which oil pan?
LockDoc
Its pretty straightforward, just a matter of getting all the oil off the weld surface, sectioning it like you would a body panel or anything else, and weld her up. The oil pan is technically a support structure on the engine, so it is important to get a good weld and only use like-material.
As for the pickup tube, its possible to modify one, but its crucial that the pickup tube rests at the lowest/sump point. As long as it doesn't have any kinks or an excessive length, it'll work just fine.
Old 10-15-2015, 08:03 PM   #20
GMJimmy
Re: Which oil pan?
Thanks everyone for all the help and conversation. It really helps listening to all the suggestions. My 68 has been dropped 2-1/2 inches. The oil pan hangs about 2-1/2 inches below the cross member and about 2-1/2 to 3 inches from the road. I think the Holley pan may be the best choice for me.
Old 10-15-2015, 08:42 PM   #21
LockDoc
LockDoc's Avatar
Re: Which oil pan?
Thanks for the input on that. I guess if a guy shortened the tube the same amount as the section he would be good to go. I am going to be picking up a '01 truck 5.3 and all matching components in the next couple of days so that's probably what I will do....
LockDoc
Leon
Old 10-16-2015, 10:11 AM   #22
Aruba1
Re: Which oil pan?
It's funny that I never paid attention to the oil pan when I installed the engine. Mine sticks about 2" also and I am not comfortable with that, even though my truck has a lot of ground clearance. I hope to build a skid plate soon that will provide protection to the pan, last thing I want is a hole in that thing.
Old 10-17-2015, 10:43 PM   #23
Hart_Rod
Hart_Rod's Avatar
Re: Which oil pan?
Cadillac CTSV pan...
Hart_Rod is offline   Reply With Quote
Old 10-18-2015, 06:35 PM   #24
GMJimmy
Re: Which oil pan?
Does anybody know what dipstick and tube is used with the Holley pan? My dipstick is the wrong one for the motor.
Thanks.
Old 10-19-2015, 09:14 AM   #25
Willie Makeit
Willie Makeit's Avatar
Re: Which oil pan?
i second this.
Willie Makeit is offline   Reply With Quote
