986839 grill guard
I found a grill guard # 986839 is stamped under the right headlight. Is this an factory grill guard and would it fit a 70 chevy. It is currently welded on a 68 C10. Thanks Jim
Re: 986839 grill guard
Picture would be best..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Added pictures
Carpe manana
![]() ![]() Join Date: Dec 2010
Yes - I believe that is a dealer accessory GM grill guard.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
![]() Join Date: Feb 2014
If the bumper bolt holes will line up, I think this would work well enough on a Chevy.
Now I don't know for sure but assuming the point above and if it's tall and wide enough it should be fine. Fixing the missing side bars (GMC's have 4 lights) one could fix that easily with some bar stock, which any welding shop or machine shop could make up for you. We could make it at our welding school so any VTEC should be able to make it also. A novice welder with access to the right tools could fix that. *I think the addition of expanded metal to the backside of the guard would go a long way to providing grill protection although those done that way never look very good. |
#7 | |
Carpe manana
