08-16-2015, 10:15 AM | #126 |
Re: Project 69 Blown Gasser!
Frame was covered in dust. Pushed it outside to power wash it off.
Brad handshoe |
09-09-2015, 08:04 PM | #127 |
Painted the bottom of the cab and mounted it on the frame for the last time! Paint is Inferno Red Metallic with 3 coats of clear ( camera makes it look more orange than dark red). I'm super happy how it turned out.
Brad handshoe |
09-09-2015, 08:08 PM | #128 |
PROJECT 7DEUCE
Is that a dodge color?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
09-09-2015, 08:48 PM | #129 |
Kirker Paint, not sure if its the same as Dodge?
Brad handshoe |
09-10-2015, 09:01 PM | #130 |
6>8 Plugless........
That turned out awesome!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
09-13-2015, 12:36 PM | #131 |
Brad handshoe |
09-14-2015, 12:13 AM | #132 |
Looks good, I'd drive it!
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
10-17-2015, 07:58 AM | #133 |
Finally painted the rest of the cab, except for the top, painting the top white and then clear with pearl.
Brad handshoe |
10-18-2015, 08:20 PM | #134 |
You are one good painter sir!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
10-18-2015, 08:43 PM | #135 |
12-13-2015, 06:23 PM | #136 |
Disassemble of my doors for sand blasting and skins.
Brad handshoe |
12-13-2015, 11:00 PM | #137 |
This thing is gonna be so awesome.. Im tuned in foe the doors.. About to do mine.. please tell all you can and what brand of skins and bottoms you use. I desperately need the drivers side hinge area... I see you need some work around yours too.. what do you plan on doing there?
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
01-24-2016, 06:38 PM | #138 |
Installed the steering column and moved it forward about 3" to give the driver a little more room. Also did a little work on the headers to get them to clear the steering shaft and welded up some 3" exhaust pipe to feed the Jones Chambered Mufflers. Oh, and changed the throttle linkage over to a cable pedal.
Brad handshoe |
06-04-2016, 02:42 PM | #139 |
It's been a long time since I updated this. Today I painted the top Pure White and epoxy primed some other parts. You may notice I installed a brake booster & master along with gauges and header wrap. Getting close to starting this thing up!
Brad handshoe |
06-04-2016, 06:10 PM | #140 |
Lookin' good. I really dig this project.
11-13-2016, 10:10 AM | #141 |
A few more pictures of my progress.
Brad handshoe |
12-05-2016, 01:15 AM | #142 |
So glad I found this build, I've been tossing the idea of doing a gasser build with my 68, but hadn't seen anyone try it yet. I love it and I think you just sold me on the idea.
Chevy Pride |
12-05-2016, 05:03 PM | #143 |
Glad you like it. I tossed around the idea of going with a straight axle front but didn't.
Brad handshoe |
12-05-2016, 05:08 PM | #144 |
I have both a factory ifs front end and a straight axle out of a mid 40s Chevy truck. My truck was originally a 4x4 K20 so the straight axle will be pretty easy to do and I believe that is the route I'm heading in, but I'm sure the ifs would be a lot nicer to drive.
Chevy Pride |
12-12-2016, 01:03 AM | #145 |
Door progress?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-12-2016, 05:53 AM | #146 |
Doors are on hold until spring, going in for Hernia surgery next week.
Brad handshoe |
06-17-2017, 07:14 PM | #147 |
Cut the door bottoms and had them sand blasted. Plan to spray some epoxy primer in the next few days.
Brad handshoe |
06-19-2017, 03:27 PM | #148 |
Nice work! I hope all went well with your surgery earlier this spring.
06-19-2017, 04:37 PM | #149 |
That paint is gorgeous!
10-15-2017, 09:19 AM | #150 |
Getting a little closer to being done. Covered the inside door panels with copies from old drag racing magazines to match the headliner.
Brad handshoe |
