10-20-2015, 12:46 PM | #11 |
Re: 1965 C20 fleet side longbed DD low budget build.
Matt--probably just the transfer case, the bearings in the 420 are big and probably ok. (unless it was low on oil at one time). I might put some 90-140 gear lube in the tf/c and see if it quiets down some. maybe some fine sawdust will help? you have mufflers on the tk? if you are going to rebuild the 420 Jason with Big Ugly did have some bearings at a good price.
look for a dodge DV 205 and a nv4500 just got all mt parts for the d-44 gear change (Auburn posi) also got some ford Bronco brake backing plates (hope they work) to get rid of the goofy front chevy ones. chevy changed in 64 up to the newer type (star wheel adj) we will see.
1961 chevy K10 my build is------------61K10 build |
