![]() Join Date: Feb 2011
HEI fitting question
I have been looking at 4X4 builds and on some builds the HEI fits and some don't. But what my question is does it matter if it is a K10 or K20 stick or auto?
Thanks Baron |
Strongman Garage
![]() Join Date: Apr 2000
Re: HEI fitting question
Not really, it's because the engine sits far back on the firewall. Fresh body mounts will help a lot or a 1" body lift
Kalle 68 GMC Suburban 1500 4x4 SOLD 69 Pontiac Lemans 99 Silverado 4.8 5 speed ECSB [ Facebook Instagram Subscribe on YOUTUBE |
My 60K20 had high valve covers and a standard points Dizzy. The valve covers hit the firewall and the distributer was close but fit. I tried to put a HEI on but the back was really tight against the firewall. I did a little massaging with a body hammer and made it work. Glad I did it!!!
60 K20, eaton HO52, T221, SM420, Dana 44 closed 78 K20 Burb, 14 bolt, NP205, SM465, Dana 44 open 05 Dodge Ram 2500 5.9 Cummins 4x4 |
Oh yeah, mine is a standard 4 on the floor.
20' Daredevil (Ret)
![]() Join Date: May 2003
Great question..... wish I could offer a definitive answer. Lacking that, I will tell you (In case you are building a database) that it fit my '72 K20 (350/350) just fine. Not a lot of extra room, but nothing hit either. I did have to remove the cap before I could install the HEI.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Yes building data base have 383 with tall valve covers (dang roller rockers). Doing most of the work by my self but not the body work. Got a complete rolling chassis just swapping everything over and getting a parts list together.
fit my 71 k10 fine 350/sm456. I didn't have to take the cap off to install
Brian |
Strongman Garage
From experience
68 K10 327/4 speed not even close. Put a MSD instead and because it was slightly taller than stock I had to take cap off to install. 68 K10 suburban 327/4 speed appears to be same clearance but fresh bushings I will be putting the same MSD in soon and will report back
Anything new to report there 68?
72 K5 Blazer - Delco HEI went on nicely. Tight but right.
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
I put an HEI in my '70 GMC K2500 and it fit with no issues. 350/TH350 in stock location.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
My experience:
1971 K10 350 4 speed HEI fit. 1971 Blazer 4x4 350 TH350 HEI fit. 1971 Blazer 4x4 350 TH350 HEI fit. (another Blazer) They were all a little close, but they all fit. All had original body mounts, so were probably sagging a bit.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Okay how about tall valve covers???
![]() Join Date: May 2014
Aren't there smaller cap HEI distributors? I was about to post a question concerning this and then I saw this thread. I have very little room (maybe 1/8") between my cap and firewall on my 72 K10 w/350 sb. I'm now getting some popping from my exhaust and wondered if maybe it has something to do with my #5 plug wire resting tightly against the firewall. I really haven't done any diagnostics yet to find the problem, but wanted to try a smaller cap distributor
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
#15 |
Hei is a large cap rotor with coil built in on top of the cap.
#16 |
[QUOTE=enigma;7342021]Okay how about tall valve covers???[/QUOT
you will have to change or modify (lengthen) the alt bracket
Brian |
#17 |
What about something like this one? Is this a points distributor or does it need something like one of those MSD modules?
#18 |
that is more like stock size will fit no prob but will have to have separate coil.
