Old 10-24-2015, 11:26 PM   #2226
Gregski
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by enaberif View Post
Do you plan to leave it as pure metal or put foam/vinyl over it? If pure metal I'm totally interested in seeing this as I've seen a few people think about it and I've thought about it too.
The thought of going real thin spunge like material maybe 1/8th of an inch thick with black vinyl over it did cross my mind, but that would be Plan B.
Plan A is to just primer and paint it, I can always go with Plan B over that if I don't like the bare results, but I hope I will cause I like the Spartan look and feel of my truck.
Gregski is offline   Reply With Quote
Old 10-24-2015, 11:28 PM   #2227
Gregski
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by Chaplain View Post
Hmm...
Exactly!
Old 10-24-2015, 11:53 PM   #2228
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
First thought, maybe hydro-dipped with your pattern of choice? Just a thought...
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 10-25-2015, 01:33 AM   #2229
Gregski
Gregski's Avatar
Re: Restoring Rusty
You gonna make me Google that, aint you John? LOL
Old 10-25-2015, 01:58 AM   #2230
Barbecue
Re: Restoring Rusty
Black crinkle paint would look very professional and badass at the same time.
Barbecue is offline   Reply With Quote
Old 10-25-2015, 11:43 AM   #2231
Gregski
Gregski's Avatar
Re: Restoring Rusty
whoa, "professional and badass", I'm in, ha ha
so I think we are thinking something along these lines, this paint aint cheap it's $10 bucks a rattle can but that's still $250 ahead of a new "aftermarket" dash
Dupli Color
Textured Metallic Coating
"Use on trunks, dashboards, and Toolboxes"
Old 10-25-2015, 11:47 AM   #2232
Gregski
Gregski's Avatar
Re: Restoring Rusty
so checked on our dash this morning and it is coming along nicely
one Top Tip: don't kill yourself scrapping all the padding off of it, let Mr. P do the work for you, soak the left over foam and adhesive with phosphoric acid and go watch some TV
Old 10-25-2015, 12:17 PM   #2233
79sierra
79sierra's Avatar
Re: Restoring Rusty
I am interested to see how this turns out painted! Will you weld/fill the extra holes?
79sierra is offline   Reply With Quote
Old 10-25-2015, 12:27 PM   #2234
Gregski
Gregski's Avatar
Re: Restoring Rusty
I wish I was man enough to do so, but when I went through my second midlife crisis I sold my Harbor Freight MIG welder and mask, etc so now I am in between welders, ha ha
so the short answer to your question is no, not at this time, I may re do it at some point in the future, unless someone from the Sac Crew shows up at my doorstep and welds them in for me
Old 10-25-2015, 12:31 PM   #2235
enaberif
Re: Restoring Rusty
If I was to paint that I would use plastidip. It will be a neat texture and if you don't like it peel it off.
If you want to cover up the holes you could use some JB Weld and just put a backing plate behind the holes for it to grab on to.
Or the other option would be to basically strip to metal then let it rust up a bit then clear coat with stuff that is UV compatible.
enaberif is offline   Reply With Quote
Old 10-25-2015, 12:34 PM   #2236
68Timber
68Timber's Avatar
Re: Restoring Rusty
That is a most snazzy idea.
John
74 Honda Z50 build
Old 10-25-2015, 04:21 PM   #2237
rich weyand
rich weyand's Avatar
Re: Restoring Rusty
I would probably do it in black wrinkle paint. Kill the glare as well as the windshield reflection. The Rustoleum stuff isn't too expensive. The thing about Rustoleum is that it dries slow, to produce a more flexible coating. This doesn't micro-crack and let moisture and oxygen in to start rusting. For a dash, which can get very hot in the sun, I think the Rustoleum product is probably the way to go.
http://www.zoro.com/rust-oleum-wrink...Q&gclsrc=aw.ds
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 10-25-2015, 09:13 PM   #2238
rusty76
rusty76's Avatar
Re: Restoring Rusty
Awesome idea. Waiting on pics
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-26-2015, 08:33 PM   #2239
Country705
Country705's Avatar
Re: Restoring Rusty
Can't wait for more updates!
And in the end, it’s not the years in your life that count. It’s the life in your years.” — Abraham Lincoln
Country705 is offline   Reply With Quote
Old 10-27-2015, 12:39 AM   #2240
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: Restoring Rusty
Fiberglass the frame. No welder needed to cover holes...
Below is an old thread. I'm sure there are more threads /ideas...
You can still use the black textured paint to keep the glare down or find someone to cover the dash in marine grade UV resistant vinyl.
http://67-72chevytrucks.com/vboard/s...=441581&page=2
http://67-72chevytrucks.com/vboard/s...d.php?t=592107
Rich
1972 K5 Blazer CST Click HERE
Old 10-27-2015, 10:36 PM   #2241
Gregski
Gregski's Avatar
Re: Restoring Rusty - The 40 Yard Dash
snuck out for a few in between kids piano lessons and Halloween haunted house rehersals
a little wire wheel, a little acid, a little more wire wheel, and a bit more acid and it will be all clean and rust free
Old 10-27-2015, 10:42 PM   #2242
68Timber
68Timber's Avatar
Re: Restoring Rusty
Did you decide which way to go with it?
John
74 Honda Z50 build
Old 10-27-2015, 10:47 PM   #2243
Gregski
Gregski's Avatar
Re: Restoring Rusty
Well since I already am a proud owner of sum JB Weld (if I can find it) I will stick on some backing plates behind the round and oval holes and fill them even with bondo, then shoot the entire dash, both sides, back and belly with my favorite paint over rust primer, and then go with the textured spray paint in black
chose not to go with fiber glass since it would mean I would need to cover the entire dash otherwise there would be mole hills where I attempted to cover the holes, and that just sounds like too much work, even for The Greg.
going for good enuff for goberment work type of result !!!
Old 10-27-2015, 10:56 PM   #2244
68Timber
68Timber's Avatar
Re: Restoring Rusty
Cool, looking forward to seeing how it turns out. I've used a similar spray paint, I think it's from Rustoleum, they call it "hammertone". It hides flaws well and looks good.
John
74 Honda Z50 build
Old 10-28-2015, 06:59 PM   #2245
rusty76
rusty76's Avatar
Re: Restoring Rusty
I can't wait to see it
My build thread
Crossmembers CC
Old 10-28-2015, 09:01 PM   #2246
Gregski
Gregski's Avatar
Re: Restoring Rusty
hid in the garage for a little while in between, Greg, Greg, and Daddy, Daddy... I swear I just want to be left alone sometimes to wrench, look I aint hurtin' no body so just leave me alone
someone mentioned they would like to see the dash installed to make a decision on which finish to pick, and I thought that made sense so today I popped it back in, and I must say this here might could work
first you will notice how much that dash bar covers, it covers both AC vents and two oval holes right off the bat
and really when you is sitting down in the seat all you see is the two oval holes in front of the passenger and well maybe that third oval hole on the ramp to the gauges
I'll share some big shots then some close ups
Old 10-28-2015, 09:09 PM   #2247
Gregski
Gregski's Avatar
Re: Restoring Rusty
ok here are some close ups so we all can see the four round holes section, the six pac hole section, the defrost/heater vents, and the in dash speaker area
so the plan is to cover the speaker with a 4x10 speaker grill of some sorts
now were there defrost vent covers in 1974 or did they come into play in the 80s?
and I aint gonna worry about those 1/4 inch square holes where the clippy clips go cause it's hip to be square!
Old 10-28-2015, 09:12 PM   #2248
Gregski
Gregski's Avatar
Re: Restoring Rusty
and here's a looksie from the outside looking in, or as I like to call it the Pebble Beach Concours de Elagance Judges View
whats up with that raised square section above the steering column, thanks a lot GM, The Greg almost pulled this off
Old 10-28-2015, 09:22 PM   #2249
enaberif
Re: Restoring Rusty
You have solidified my thought regarding doing this to my truck so thanks a lot lol.
I'm wondering what that bump above the steering wheel is for myself.
Old 10-28-2015, 10:21 PM   #2250
Jeramy
Jeramy's Avatar
Re: Restoring Rusty
wondering myself if the skeleton from the 81 and up is the same, as mine is pretty toast.
wonder if a little time spent with a body work hammer and dolly could flatten out that square patch
by the way i vote black.with or with out texture is chefs choice.
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
