10-25-2015, 08:27 PM | #1 |
Question about changing headlight bulb on '53 3100
I'm new to the classic truck game so if anyone can help me I'd appreciate it. I need to replace the passenger side headlight bulb and I can't figure out how the bulb comes out. I tried pulling it out from the rear of the light but all it does is spin. I'm sure it's simple and I'm just missing it. Still learning! Thanks for the info!
10-25-2015, 10:19 PM | #2 |
Re: Question about changing headlight bulb on '53 3100
Unless your light is frenched and won't come out the front you reove the screw at the bottom of the trim ring aka headlight door and pop it off take out the three small screws that hold the ring around the bulb out (be careful not to drop them as the they get real hard to find when you do) and take ring off and take the bulb out and disconnect the plug and put your new one in.
Don't take out the two adjuster screws that are used to adjust the headlight. There are two screws to adjust it and a spring to retain it in place and you leave those alone.
10-25-2015, 11:52 PM | #3 | |
Posted via Mobile Device |
10-26-2015, 02:46 PM | #4 |
Old truck use sealed beam lights, here is a link to R&R.
http://www.hotrod.com/how-to/paint-b...-chevy-pickup/
