06-25-2015, 08:54 AM | #76 |
Re: DBW pedal mounting bracket
It's an LQ4 with Fbody oil pan and exhaust manifolds. So I guess it's a Camaro trapped in a box truck.LOL
06-25-2015, 09:21 AM | #77 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-26-2015, 12:22 PM | #78 |
Do you have any left for the truck style pedal? I'd like one. Can you ship to Canada?
Saskatoon, Saskatchewan Canada |
06-26-2015, 12:24 PM | #79 | |
This one: http://67-72chevytrucks.com/vboard/s...d.php?t=651123 If so, I do have some left. What is required to ship it to Canada?
06-27-2015, 12:36 AM | #80 |
Yes the bent one. I like my stuff sent USPS. You will likely have to fill out a declaration of value, what the part is and where it was made. Should be about it. I'm happy to pay some extra handling for your trouble.
06-27-2015, 07:51 AM | #81 |
PM me your address and I'll talk to the post office.
07-14-2015, 09:05 AM | #82 |
Thanks for the purchase! Only 10 Left!
07-14-2015, 11:21 AM | #83 |
Got it yesterday. It looks great. Thanks a bunch
09-26-2015, 05:40 PM | #84 |
Are these still available ? I would like to package one with the hood brackets if you do.
Thanks, Anthony |
09-26-2015, 06:00 PM | #85 |
Yes I Do! Text me.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 09-28-2015 at 08:19 AM. |
10-23-2015, 12:16 PM | #86 |
Need one for a 05 truck pedal if you have one available.
10-23-2015, 01:09 PM | #87 |
Yes sir! PM sent and here's a link to that thread: http://67-72chevytrucks.com/vboard/s...d.php?t=651123
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 10-23-2015 at 01:20 PM. |
10-23-2015, 04:41 PM | #88 |
Ok,Thanks
10-29-2015, 12:43 AM | #89 |
CopyWritten
Intestred in a bracket for my 86. I have a pedal from an 05 Cadillac Escalade EXT.
10-29-2015, 09:08 AM | #90 |
I don't make a bracket specifically for the 73-87, but some guys have modified my 67-72 bracket to work on the 73-87. LMK
01-07-2016, 12:02 PM | #91 |
For all of the guys looking for a pedal bracket to work with the 73-87 trucks, here's a thread that has some great info in it:
http://67-72chevytrucks.com/vboard/s...d.php?t=692222 http://www.hotrodlane.cc/Streetstories/81%20swap.pdf Apparently a factory OEM gas pedal from a 94-02 CHEVY GMC 6.5L V8 DIESEL (PN 15984422) will bolt right in. You have to repin a few wires, but it's supposed to be pretty straight forward. The .pdf file has a complete discussion on the entire install, but here is a small snippet: "This is the installed Pedal Position Sensor AKA Drive by Wire pedal. I used one from a 1998 6.5 Diesel truck as it bolts right up and is a closer match than the later Silverado pedal. A couple of the wires do have to be moved as it is internally wired different. Basically, there are three different sensors in the pedal and the PCM compares all three of these to determine how much throttle opening the drivers is requiring. If these three sensors do not agree, a code will be set and the PCM takes a best guess at what the throttle opening should be. The gray wire was moved from location A to J, the Brown wire was moved from location E to A and the Yellow wire was moved from location J to E. I also had to add a slot in the connector plug so it would plug into the pedal." PLEASE NOTE I HAVEN'T TRIED THIS ON A TRUCK, I'M JUST PASSING THE INFORMATION. DO YOUR HOMEWORK BEFORE YOU PURCHASE ANY PARTS!!!! Good luck with your LS Swap!!!
04-05-2016, 10:06 AM | #92 |
Rob, i would like one of your corvette pedal brackets, i have sent a Paypal payment to the email listed on page 1
Paypal: robhartley@aol.com, enter "CPB" in message block. Thank you!
My build: Project "Lazarus" 8.1 Vortec and Allison in a 72 swb k10 http://67-72chevytrucks.com/vboard/s...d.php?t=555878 |
04-05-2016, 10:22 AM | #93 | |
04-08-2016, 09:13 PM | #94 |
Rob, I received my bracket today, excellent service, Thank You!
04-09-2016, 01:37 AM | #95 |
Rob, just sent a Paypal payment for a Gen IV pedal bracket for a 72. Thank you.
Jordan 1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205 1982 Chevy C10 SWB, 2006 LS2/4l70e In progress.... http://67-72chevytrucks.com/vboard/s...d.php?t=439860 |
04-09-2016, 08:01 PM | #96 | ||
Rob
11-15-2016, 09:12 AM | #97 |
bump
11-22-2016, 07:09 PM | #98 |
Just wanted to say that interestingly enough I too had the same problem as "derotoreut" with my holes not lining up and my blazer is a '72 purchased in Texas. It wasn't a problem for me, I just lined up the bottom hole, drilled 2 new holes and welded up the old ones. I wonder if it would be location, mine was made in April of 72 in Flint.
12-25-2016, 01:54 AM | #99 |
Hi Rob,
I need one of the Corvette pedal brackets,I'm going to send you the payment in a few minutes. Thanks Brian
1971 c10 custom deluxe fleetside swb LS3 w/BTR stage IV cam,4L85E w/3600 stall 67-72chevytrucks.com/vboard/showthread.php?t=558024 |
12-25-2016, 09:10 AM | #100 |
Got it Brian, thanks! It will be in the mail Tuesday. Let me know if you have any questions. Merry Christmas!
