#26 |
It followed me home?
Re: My 83' Crew Cab Dually project
I've been watching your build on c10forum. Your notch is just about perfect for my truck , too bad you cant unbolt it and mail it to me hahah. Good luck
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#27 |
#28 |
What would you charge for a notch? Would u do a different size? 8 or 10 in? Cross bars included?
94 ls swap silverado 65 Pontiac 78 c30 crew cab dually (parted and gone) 82 c30 crew cab dually ( now building ) 91 r30 crew cab dually (parted and gone) 69 swb-sold 71 lab sold all in progress......__ ..........._______ |__\__ ..........|__(O)______(O)] ........................ |
#29 |
#30 |
Ok, so air tanks. I've got a single 5 gallon and it seems like it's too small. One lift up on just the front and the compressors kick on. I'm thinking about ordering two more 5 gallon ones and stuffing them into the frame. Does this sound like enough? What's common for these trucks?
#31 |
I'm running 14 gallons total, enough to fill RE8 bags all the way around twice before the EDC kicks on
#32 |
Cool. Thanks. I just ordered a couple more 5 gallon ones. They have a bunch of 1/4 ports on the side, so I should just be able to plug those and run a T to the 3/8 end port on each. I've got miles of room between the frame and the rockers, so I can stuff one on each side and never see them.
#33 |
Getting the four-link mocked up...
#34 |
Take a ton of install pics of that 4 link install. Ive looked at that kit for months and dont know if i could do it myself or not
#35 |
Pics as requested...
Everything is tacked up and in place. ![]() Pan hard bar tacked in place. I've probably cycled this thing on the Jack 50 times today. There's not a lot of options for where to mount it with the big ass pumpkin... This appears to be the best of any. ![]() |
#36 |
So, after staring at it and cycling up and down over and over, I've come to the conclusion that there is simply no room to run this as a bag over axle. I've changed direction and I'm going to mount the bags on the upper link bars. Since this is a really robust kit, I'm not concerned about the strength of the bars/mounts. Plenty of guys are doing a bag on bar setup on just the lower(longer) bar on a triangulated system. Just for the sake of argument and to make it even tougher, I ordered up some 1/4" gussets to run the length of the upper bar.
![]() I'll have to fab up some upper mounts that sit around 10" above the frame, so once these parts show up, I'll start building that. In the meantime, I'll be working on a new crossmember to replace the stock one that I hacked in half yesterday to make room for the driveshaft. So here's a question...would you guys run the exhaust all the way back to the axle or dump it ahead of it? I'm torn which way to go and the crossmember needs me to make a decision before I build it. ![]() |
#37 |
Exhaust termination is subjective.
Some don't mind the noise of a dumped set-up; some do. Some want to keep under-bed cleaner w/a full length set-up; for others it doesn't matter. I wanted mine quiet & clean so the full length set-up was mandatory.
#38 |
Did u need a bigger notch for it to work?
#39 |
I will. I'm just doing everything else I can before I cut it apart and rebuild it taller. Nobody likes redoing their own hard work. Plus, I want to make everything nice and stiff on the frame ahead of the notch so it doesn't move.
Today I built the crossmember...seriously. All frickin day on this stupid thing. Everything was going the wrong direction for me and I should have quit before I started. Burnt myself several times, welder was acting up, plasma torch wouldn't cut clean, didn't have all the material I wanted to use, stepped in some dog ****...oh well, I pushed through and made it work. ![]() ![]() Last edited by DblTrbl; 11-01-2015 at 10:38 PM. |
#40 | |
#41 |
Looks good bro.
74 C10 LWB 350/T5 Dropped on 20's Soon to be Bagged and Injected 84 C35 Crew Cab Dually. 454/400 Dropped a lot. Instagram: mmmdropp |
#42 |
Travlinman - I stumbled across these. Thought you might be interested:
http://ktperformance.net/i-10767016-...FYZefgod910JwQ |
#43 |
Member of the longbed union.
That's a pretty expensive price for just front adapters. http://www.tnwheelandtire.com/site/7...8X10CHEV73-200 builds them for little over $900 for fronts and back.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
#44 |
Thanks. I checked them out and ya 550 for just the 2 front adapters is quite expensive. That Tennessee wheel sells all 4 for 900 shipped. Probably where I'll order them from. I've had my wheels cut and polished in my garage for almost a year now
#45 |
I guess I should have read that closer! Haha. I didn't realize it was only the front two.
#46 | |||
I'm just glad to be here!
http://ktperformance.net/i-19722311-...ront-rear.html
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#47 |
I'm heading to buy materials this morning. Going a different route on the notch and rear frame. I read through the thread over on the C10 forum with the guy from Canada that was building "Dool Eh". He used 4x3 1/4" and it looks way cleaner than the traditional step frame that I did. I'll keep mine a little more tame, but I plan to lop the frame off right in front of the existing notch and rebuild from scratch. Then I can tie in the same material when I do the SFBD and Z the front.
So...this step notch will be available in one big piece if anyone wants to come get it!! Lol |
#48 |
"Dool Eh" was one of the cleanest frame builds I've ever seen. I based my frame off of his because I liked the way he tied the front together. He put his cab on, went to a couple shows, haven't seen it since.
#49 |
#50 |
I'll take the notch and 4 link off ur hands lol . What size did u order? Wanna come do mine too?I'm starting to get tired of staring at it at stock height lol
