Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > LSx Classifieds
Old 10-19-2015, 07:10 PM   #126
O2bwheelin
Re: DBW Gas Pedal Adpater bracket for truck/suv pedal
Payment sent.
Scott
O2bwheelin is offline   Reply With Quote
Old 10-19-2015, 07:19 PM   #127
Hart_Rod
Hart_Rod's Avatar
Originally Posted by O2bwheelin View Post
Payment sent.
Scott
Thanks Scott! Your bracket shipped yesterday via FEDEX!
Hart_Rod is offline   Reply With Quote
Old 10-29-2015, 09:27 PM   #128
hozeman469
Payment on the way
Thanks Rodney
hozeman469 is offline   Reply With Quote
Old 10-30-2015, 03:22 AM   #129
Hart_Rod
Hart_Rod's Avatar
Originally Posted by hozeman469 View Post
Payment on the way
Thanks Rodney
I got it yesterday Rodney and your bracket is on its way via USPS. Thanks again!
Rob
Old 11-04-2015, 04:09 PM   #130
ironfish96
Will these work in a 68 with an 2007 pedal? Thanks
ironfish96 is offline   Reply With Quote
Old 11-05-2015, 11:50 AM   #131
Hart_Rod
Hart_Rod's Avatar
Can you post a picture of your pedal?
Old 11-05-2015, 07:30 PM   #132
michael bustamante
michael bustamante's Avatar
ok rob im gonaa be new to this ls conversion
im getting a 2004 yukon 5.3 set up, including the pedals. how do i know if i need this plate?
its going in my 67 short stepper
1967custom
michael bustamante is offline   Reply With Quote
Old 11-05-2015, 09:20 PM   #133
Hart_Rod
Hart_Rod's Avatar
You'll need it!!!!!
Old 11-09-2015, 11:05 PM   #134
michael bustamante
Ok then bud. As your former New Mexico parts trader ;-)
What's your price?
1967custom
Old 11-14-2015, 12:17 PM   #135
Hart_Rod
Hart_Rod's Avatar
What's your price?
PM sent!
Old 11-21-2015, 04:21 PM   #136
CustomK5
Re: Gas Pedal Adpater bracket for truck/suv pedal
Hello was wondering if these are still available doing a 5.3 swap out of a 05 in a 72 blazer
CustomK5 is offline   Reply With Quote
Old 11-21-2015, 07:32 PM   #137
Hart_Rod
Hart_Rod's Avatar
Yes sir! $100 paypal robhartley@aol.com. Thanks!
Old 12-11-2015, 01:09 PM   #138
Hart_Rod
Hart_Rod's Avatar
bump!
Old 12-11-2015, 04:29 PM   #139
Chris95GT
Man. I wish I would have known about these when I did my last swap, I had to do a lot more cutting and hacking then I was happy with doing, this would have made that far far easier. Great product!
1991 C1500 ECSB - 5.3 LS 4L80E 14bsf - Gone but not forgotten
1999 C2500 GMT-400 Crew Cab Short Bed - 6.0 LQ4 - 4L85E
2003 Denali XL - Wifeys Ride
2008 K2500HD Duramax Sierra Crew Cab Short Bed - Daily
Chris95GT is offline   Reply With Quote
Old 12-13-2015, 01:16 PM   #140
Hart_Rod
Hart_Rod's Avatar
Thanks! Tell all of your friends!!!!!
Old 12-14-2015, 10:55 AM   #141
Ellistk
Ellistk's Avatar
I will take one. Thanks
Ellistk is offline   Reply With Quote
Old 12-14-2015, 11:17 AM   #142
Hart_Rod
Hart_Rod's Avatar
Sweet! $100 shipped to you, paypal is robhartley@aol.com
Old 12-15-2015, 10:51 AM   #143
Hart_Rod
Hart_Rod's Avatar
PM sent with payment information.
Old 12-17-2015, 11:22 AM   #144
zach_carver
zach_carver's Avatar
Any option on these for 1965 C10? With a vette pedal
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 12-17-2015, 12:05 PM   #145
Hart_Rod
Hart_Rod's Avatar
I've never tried one of my vette pedal brackets in that year model. I know several people have modded my truck pedals to work in the 60-66s, but I'm not sure how they did it. LMK.
Old 12-28-2015, 01:32 AM   #146
Chrisbeds82
Chrisbeds82's Avatar
I have a 72 c10 swapping in a LS3. Is there a particular pedal that will work best with this? The best place to source that pedal? And price shipped for this bracket?
Chrisbeds82 is offline   Reply With Quote
Old 12-28-2015, 10:35 AM   #147
Hart_Rod
Hart_Rod's Avatar
I would use the 2005+ corvette pedal. You can find it on ebay for - $50-$100. The pedal bracket is $50 shipped. Check out this thread it contains all the info for that pedal bracket:
http://67-72chevytrucks.com/vboard/s...d.php?t=631165
Thanks! Rob
Old 12-29-2015, 03:05 PM   #148
Hart_Rod
Hart_Rod's Avatar
What did you decide on the pedal?
Old 01-07-2016, 11:54 AM   #149
Hart_Rod
Hart_Rod's Avatar
For all of the guys looking for a pedal bracket to work with the 73-87 trucks, here's a thread that has some great info in it:
http://67-72chevytrucks.com/vboard/s...d.php?t=692222
http://www.hotrodlane.cc/Streetstories/81%20swap.pdf
Apparently a factory OEM gas pedal from a 94-02 CHEVY GMC 6.5L V8 DIESEL (PN 15984422) will bolt right in. You have to repin a few wires, but it's supposed to be pretty straight forward.
The .pdf file has a complete discussion on the entire install, but here is a small snippet:
"This is the installed Pedal Position Sensor AKA Drive by Wire pedal.
I used one from a 1998 6.5 Diesel truck as it bolts right up and is a closer match
than the later Silverado pedal. A couple of the wires do have to be moved as it is
internally wired different. Basically, there are three different sensors in the pedal
and the PCM compares all three of these to determine how much throttle
opening the drivers is requiring. If these three sensors do not agree, a code will
be set and the PCM takes a best guess at what the throttle opening should be.
The gray wire was moved from location A to J, the Brown wire was moved from
location E to A and the Yellow wire was moved from location J to E. I also had to
add a slot in the connector plug so it would plug into the pedal."
PLEASE NOTE I HAVEN'T TRIED THIS ON A TRUCK, I'M JUST PASSING THE INFORMATION. DO YOUR HOMEWORK BEFORE YOU PURCHASE ANY PARTS!!!!
Good luck with your LS Swap!!!
Old 01-10-2016, 10:22 PM   #150
downbytheriver
downbytheriver's Avatar
Ready to buy, you ready to ship?
68 SWB 5.3 turbo build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=578220
downbytheriver is offline   Reply With Quote
