Old 10-30-2015, 08:59 AM   #151
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Originally Posted by Sicksty8 View Post
Your progress is quite astonishing. Looks pretty damn good
Thanks I take pride in all my work and I work hard at it. Any progress is progress and I try to do something on it everyday. I want to drive it.
Derek
Metaldoc is offline   Reply With Quote
Old 10-30-2015, 09:07 AM   #152
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I noticed I call my truck it as the name has not divulged itself. Rodney has come up as it's name. Usually the name comes out during the build but not yet. Not even sure if it's a girl or guy truck either. Just keep building and it will come to me I guess.
Old 10-31-2015, 11:56 AM   #153
Metaldoc
Metaldoc's Avatar
Re: 67 long box
My neighbor is taking his project out to the hanger to assemble the rest. This is his third but second amphibious ultra light built in his garage
Old 10-31-2015, 08:30 PM   #154
Metaldoc
Metaldoc's Avatar
Re: 67 long box
starting to look like it has potential
Old 11-03-2015, 07:14 PM   #155
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Rear end is in place and it all fit back together. I still need rear springs and blocks to set ride height. Gas tank is in with the new straps. Looking purdy !
Old 11-03-2015, 07:40 PM   #156
Advanced Design
Advanced Design's Avatar
Re: 67 long box
Looking really good. Do you help with the plane?
Advanced Design is offline   Reply With Quote
Old 11-03-2015, 10:48 PM   #157
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks it's starting to pay off with all the hard work. I did help with all three he built. The first was a challenger and the second two are sea-rays . I flew the challenger with him in it.
Old 11-04-2015, 10:27 AM   #158
Sicksty8
Sicksty8's Avatar
Re: 67 long box
Looking really good. Just wondering which bushings you used on your custom trailing arms and second what size is the tube you used to build them. I'd like to build a set for mine as well.
Sicksty8 is offline   Reply With Quote
Old 11-04-2015, 11:25 AM   #159
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I used new stock bushings, I took a piece of 2" tube 3/16 wall and cut it to right length . Then cut a strip out of the length and squeezed it back together to right id size. I could not find the right size tube so the was the best way to resize the tube as I don't want to pay to have a piece machined. All the parts I made use stock size bushings. The arms are 2x3x3/16 and the set the offset to 12.5 deg. There is a piece of tubing in all the bolt holes as well so the 2x3 tube doesn't crush when bolting U bolts and springs in.
Thanks Derek
Old 11-05-2015, 05:47 PM   #160
Metaldoc
Metaldoc's Avatar
Re: 67 long box
mated and back in place till the next upgrade
Old 11-07-2015, 04:27 PM   #161
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Drive shaft in, E-brake cables in, clutch linkage in with an extra spring on it so it stays together. Springs and spindles on but waiting for the paint to dry on the rotor to finish. It is just about ready for the cab.
Old 11-08-2015, 06:07 PM   #162
Metaldoc
Metaldoc's Avatar
Re: 67 long box
cut up the old exhaust and welded a couple of pipes to pass safety
Old 11-10-2015, 02:23 PM   #163
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Front brakes done. Now to lift the cab back on . Things are coming together quick with all the parts ready to go on.
Old 11-11-2015, 01:01 AM   #164
71Sleeper
71Sleeper's Avatar
Re: 67 long box
Coming together nicely. Working with clean parts makes things so much simpler. I would say its a shame that all your hard work will be covered up soon and not seen but that's not always the case. Because the true car/truck fanatics will be laying on the ground just to sneak a peak. Keep up the good work.
71Sleeper is offline   Reply With Quote
Old 11-11-2015, 11:07 AM   #165
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks and ya all this work not to be seen. Like you said "we know it's right and it's looks perfect but it will only be me and my mechanic who safeties it will ever see it. The truck will look very similar to when I drove it in the shop to when I drive it out with 1000 or so hours under it.
Old 11-11-2015, 06:46 PM   #166
Metaldoc
Metaldoc's Avatar
Re: 67 long box
then and now . wow is all I can say, it's not the same truck
Old 11-11-2015, 11:04 PM   #167
Advanced Design
Re: 67 long box
Yeah, very nice!
Old 11-11-2015, 11:09 PM   #168
Bomp
Bomp's Avatar
Re: 67 long box
Nice and Clean. Great works so far.
Bomp is offline   Reply With Quote
Old 11-12-2015, 08:11 PM   #169
Metaldoc
Metaldoc's Avatar
Re: 67 long box
It's turning out real nice, This is my first complete project that I've done all the work myself.
Thanks Derek
Old 11-14-2015, 01:30 AM   #170
swamp rat
swamp rat's Avatar
Re: 67 long box
Your doing a great job MisterDoc!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-14-2015, 11:03 AM   #171
Xeen
Xeen's Avatar
Re: 67 long box
Thanks Derek
You are going at a breakneck pace compared to most builds on here, I think you are going to be done before May unless you hit a financial roadblock.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 11-14-2015, 11:53 AM   #172
Metaldoc
Metaldoc's Avatar
Re: 67 long box
Thanks and if I do keep up this pace I will be ready for May or sooner, It gives me time to do a nice job on details at the end. I have most of the stuff for the truck as it was a driver when I bought it . The cost starts to add up quick in the end part of the build though.
Derek
Old 11-15-2015, 09:56 PM   #173
Metaldoc
Metaldoc's Avatar
Re: 67 long box
steering column in, pedals in , E-brake done, both vents in, clutch hooked up, throttle on. I had a good day.
Old 11-16-2015, 12:24 AM   #174
Metaldoc
Metaldoc's Avatar
Re: 67 long box
I even impressed myself with the kick panel repair on the drivers side considering it was made from scratch. It looks like I cut it out of another cab and welded it in.
Old 11-16-2015, 11:10 AM   #175
Advanced Design
Re: 67 long box
Looking really good! Nice progress.
