Old 11-13-2015, 10:41 AM   #401
THEE OG
THEE OG's Avatar
Re: 1952 Chevy Vette Roadmaster LT1 Farm Truck Build
Originally Posted by FarmerSid View Post
Thanks! I'm trying....
I'm a welder by trade. Heading to my site and I got to read about half your build. Can't wait to get home and really look at this thing. Beautiful
2010 dodge 3500 dually (Cummins tow pig)
2010 CTS-V
2003 TT 03 Cobra
The BUILD!!! 1955 GMC series 1
This build is a wedding present to my soon to be wife. She has no clue. But I'm building her dream truck and hands down one of my favorite vehicles of all times.
THEE OG is offline   Reply With Quote
Old 11-13-2015, 10:53 AM   #402
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
I thought about taking my stock rad to a place and see if they can duplicate it for my V8. Maybe I will.
I'm out to lunch on master cylinders, hydro boost etc. Is there an advantage to running hydro boost over vacuum? I will be running 1996 Vette front and rear disk brakes. May take you up on your offer. Mighty fine of you.
The stock radiator ( if it's clean) is plenty adequate for a V8, just the fittings are in all the wrong places!
As to the hydroboost - it's got some benefits, as far as being physically smaller unit, and having a more consistent pedal feel (especially if you had a lumpy cam and little vacuum) - but it's a bunch of extra plumbing. I did it on my '72 K3500 build, but I personally wouldn't ever do all that extra plumbing on a street car unless it was turbo.
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 11-13-2015, 11:51 AM   #403
FarmerSid
FarmerSid's Avatar
Thanks JJ! Info I need to hear.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 11-17-2015, 10:43 AM   #404
FarmerSid
FarmerSid's Avatar
Had a night off of hockey so one of my young lads and I headed out to the barn and installed the Vette suspension and placed the engine to see how the milled Camaro manifolds fit. As you can see, no go unless I modify the frame. Will have to wait and see how the Hooker LS manifolds fit up.
Here you can see the rack clearance I have between oil pan and crank pulley. I may have to raise the engine a bit and use F body accessories to move things closer to the engine for rad clearance. Man.... all these little things are starting to $$$$$.
Here you can see how low the truck oil pan hangs below the cross member. I will have the F body pan here shortly.
And an overall shot of how things are sitting.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-17-2015, 10:51 AM   #405
JJorgensen52
The Hooker manifolds are supposed to be about 5/8" narrower each side, if I remember correctly.
On the rack, your pan and pulley clearance looks okay (since the rack is stationary), but would there be interference between the PS pump and the input on the rack? Just from my view, that looks like the biggest hurdle to overcome. All of the factory LS bracketry has something in that spot, except the 'vette.
CURRENT
SOLD
Old 11-17-2015, 12:57 PM   #406
solidaxel
solidaxel's Avatar
Hey nice "rollers"
I am having the same problem with the PS pulley and rack input port, maybe a smaller pulley on the pump.
I did have to lower the rear trans mount to get clearance but now I am concerned about the drive shaft angle, how much angle are you running on your D/S
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-17-2015, 01:36 PM   #407
Advanced Design
Advanced Design's Avatar
Well, I was hoping the exhaust manifolds would fit after the modification. Ugh. Hopefully the Hookers will. Always something.
Advanced Design is offline   Reply With Quote
Old 11-17-2015, 03:56 PM   #408
ptc
ptc's Avatar
Try also BBK - they make the most compact shorty headers I have ever seen and decently priced.
My Build: 57 Chevy Pro-Street
ptc is offline   Reply With Quote
Old 11-17-2015, 04:32 PM   #409
FarmerSid
FarmerSid's Avatar
JJ - I will get some better pics tonight after hockey. I have the pump but it's filthy and will clean it up and see if I have any issues. Got me worried now.
Solid - You copy cat! LOL! My engine is 3* down and rear is 3* up.
AD - It sure is always something. If it's not that its $$$
ptc - thanks for the BBK info. Will look into them if my hookers don't fit.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-17-2015, 09:23 PM   #410
FarmerSid
FarmerSid's Avatar
Went down to the barn after hockey and did some figuring. I installed the PS pump for ya solid to see my setup. I tightened down the 2010 Camaro exhaust manifolds as they were loose as the bolts are now too long. They fit much better. The drivers side clears but the passenger side is still a bit too close to the frame rail. A little more angle milling and it will work. Still hoping the Hooker manifolds fit better. On with the pictures.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-17-2015, 09:27 PM   #411
FarmerSid
FarmerSid's Avatar
Manifolds are getting close to hitting the block. May have to remove some of the block.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-17-2015, 09:30 PM   #412
FarmerSid
FarmerSid's Avatar
Here's the clearance around the PS pump.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-18-2015, 09:25 AM   #413
lower50's
lower50's's Avatar
Your getting there I had to cut the outlet off my passenger manifold and make it point up to go to the turbo. Every modification requires massaging.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 11-18-2015, 01:26 PM   #414
99 to Life
99 to Life's Avatar
looks great. Do they make a remote PWS set up like they do for racecars? be interesting to see if any are available for situations like this.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 11-18-2015, 02:00 PM   #415
ptc
ptc's Avatar
Yes they do. look up Sweets, or KRC... even Billet Specialties if you want something pretty.....
I think any 'block hugger headers' will work better than your stock ones....
Old 11-26-2015, 04:30 PM   #416
FarmerSid
FarmerSid's Avatar
Got my Hooker headers yesterday. Fit up better than the camaro manifolds.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-26-2015, 04:33 PM   #417
FarmerSid
FarmerSid's Avatar
C4 IFS & D44 IRS
5.3 HO L33
Old 11-26-2015, 04:36 PM   #418
FarmerSid
FarmerSid's Avatar
A few of the new oil pan. Thing is pretty heavy! There's a lot of casting flash in side and out. I'd like to smooth it up a bit. Good idea or not? Gasket is riveted on the pan in two places. Worried about filings and such>
C4 IFS & D44 IRS
5.3 HO L33
Old 11-26-2015, 05:34 PM   #419
Advanced Design
The header looks pretty tight on the right side. May be the angle of some of some of the pictures? If you want to clean up casting flash you can drill the rivets to move the gasket out of the way and to allow for cleaning.
Old 11-26-2015, 09:01 PM   #420
FarmerSid
FarmerSid's Avatar
The flange is higher above the frame than the Camaro manifold. They tuck in a bit more than the Camaro manifolds after being angle milled. The engine is centred. I will get a few more pics.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-26-2015, 09:16 PM   #421
99 to Life
99 to Life's Avatar
thanks for the pics. I'll be starting an LS engine in and OG frame for a guy real soon. Ordering parts while they are on sale. So this info is gonna help!! What pan did you go with? I see you posted the numbers. I'd clearance every bit you can put some tape around the whole top of the gasket and pan if you are that worried, which I wouldn't be. Just clean it good.
Old 11-26-2015, 10:41 PM   #422
FarmerSid
FarmerSid's Avatar
No problem 99! The pan is for a 98-02 F-body Camaro. GM part# and part. Truck pan hangs way lower than the cross member. These pans are pricey as everyone wants/needs it for a lot of LS swaps. I think I got lucky and found a brand new one for $215 US shipped to the Canada/US border. It came with some extra parts that are needed for the swap.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-26-2015, 11:48 PM   #423
lower50's
lower50's's Avatar
You could always tape up the gasket to keep it clean. Manifolds look like they should work.
1951 MG TD
Old 12-13-2015, 03:03 PM   #424
FarmerSid
FarmerSid's Avatar
Had a rare day off so I worked on cleaning up the casting flash on the f body oil pan and installed it.
Shortened the truck windage tray and modified it for the pickup tube.
C4 IFS & D44 IRS
5.3 HO L33
Old 12-13-2015, 03:05 PM   #425
FarmerSid
FarmerSid's Avatar
Much better clearance.
C4 IFS & D44 IRS
5.3 HO L33
