Old 03-03-2015, 11:40 PM   #301
lucky71gmc
Re: Parting out 72 GMC K20 4x4 350-TH350
Replying to your February 17, 2015 message, if you can verify you have the rear most frame member z shaped plate and front GMC 4 X 4 bumper brackets I would like them. Thanks Br.
lucky71gmc is offline   Reply With Quote
Old 03-04-2015, 08:16 PM   #302
pimpston65
pimpston65's Avatar
any chance of the transfer case bracket...
pimpston65 is offline   Reply With Quote
Old 03-05-2015, 09:26 AM   #303
clemsonteg
Do you still have the water pump pulley? I can't tell from the picture, but is the crank pulley 2 groove as well? I need both pulleys with 2 grooves if you have them.
clemsonteg is offline   Reply With Quote
Old 03-06-2015, 02:49 AM   #304
tll74
"Junkyard Dog"
tll74's Avatar
Originally Posted by First c10 View Post
Thanks for the response Tom
My sons truck is a 1968 but the rear spring length was 56" so I ordered the lift for this frame. I will measure the spring again as it has been a little while. I thinks the spring eye to center pin was 28". Another question is what is the price on the/a 4x4 rear axle?
Scott
Scott, I want 400.00 for the rear axle assy. Plus shipping or pick it up. It is a 3.07 posi
No problem on the cross member and the bumper brackets.
45.00 for the complete RH transfer case support assembly. 15.00 shipping.
Not sure of the pictured items but I have many others. 45.00 for the pair plus 15.00 shipping.
Thanks, Tom
72 C-10 Cheyenne Super LWB, Vortec 427,TH700, 3.73 posi, tach, tilt, AM-FM,Frame off in process.
http://s289.photobucket.com/albums/l...t=7eae161e.pbw
88 Monte Carlo SS bought new only 10k miles.
73 Chevelle SS 454 had since high school.
74 Camaro Z28 350 AT numbers matching, Black on Black.
73 El Camino SS 350 4sp.
70 Chevelle SS 396 4sp, number matching with LS6 454
69 Chevy C30 Car Hauler
86 K20 383 4sp 4" lift frame off restoration.
http://s289.photobucket.com/albums/l...t=1b1082d3.pbw
tll74 is offline   Reply With Quote
Old 03-06-2015, 04:25 AM   #305
pimpston65
pimpston65's Avatar
Thanks, Tom
can you post a picture?
Old 03-06-2015, 12:37 PM   #306
HOTRODSBYCHIP
Do you still have the upper and lower control arms?
HOTRODSBYCHIP is offline   Reply With Quote
Old 03-06-2015, 10:34 PM   #307
clemsonteg
Thanks, Tom
Interested in the pulleys if you have a matching set of double groove water pump and crank pulleys. The alternator is on the driver side, compressor on the passenger side. Short water pump with te 2" bolt pattern fan.
Old 03-08-2015, 04:22 AM   #308
tll74
"Junkyard Dog"
tll74's Avatar
Yes but it would be monday before I can.
Ummm...this is a 4x4 thread. Are you looking for 2wd control arms? I do have all the choices.
No problem..I have what your looking for. PM me if your up for these.
Thanks, Tom
Old 03-08-2015, 05:46 PM   #309
engairuph
Looking for a heater control unit no a/c
Ralph L. Jasper
69 4x4 Suburban PTO winch(NAVY)
13 GMC Ext cab
12 Ford Fusion SE(wife)
MAI
Interior shop
engairuph is offline   Reply With Quote
Old 03-18-2015, 01:07 AM   #310
pimpston65
pimpston65's Avatar
[quote=tll74;7080865]Yes but it would be monday before I can.
any updates on the TC bracket?
Old 04-14-2015, 05:26 PM   #311
Darkgrace
Darkgrace's Avatar
Any chance you still have the engine? Looking for an original 1972 350? Thanks
We Bought another truck?
Darkgrace is offline   Reply With Quote
Old 04-14-2015, 07:35 PM   #312
1968k20
1968k20's Avatar
What parts do you have left?
1968k20 is offline   Reply With Quote
Old 04-15-2015, 11:51 PM   #313
Motorfist
nevermind
67 c30 Cab and Chassis (ex motorhome truck)
68 c10 LWB
70 c30 Cab and Chassis 133" converted to Longhorn
72 K10 LWB Rust Bucket Hunting Truck
Motorfist is offline   Reply With Quote
Old 05-09-2015, 05:21 PM   #314
gmcdeadhead
gmcdeadhead's Avatar
do you have a 4x4 throttle cable ?
gmcdeadhead is offline   Reply With Quote
Old 05-12-2015, 12:17 PM   #315
19702wdc10
Active Member
Hello,
I am looking for a TH350 dipstick and tube for a 1970 C10 I believe it is approx. 34" long.
My truck had a tranny swap done and the previous owner put a car dipstick in and it is low behind the engine hitting the firewall.
Joe
19702wdc10 is offline   Reply With Quote
Old 09-03-2015, 07:43 AM   #316
gpat@earthlink.net
Active Member
Do you have a 72 Blazer rear brake fluid line bracket that attaches to the frame and one for the axle . Both lines.
gpat@earthlink.net is offline   Reply With Quote
Old 09-11-2015, 12:14 PM   #317
rickcdewitt
rickcdewitt's Avatar
69-72 k20 rear springs, 95415 ?
1970 k20 6.0l/nv4500/np205/14bff in progress
build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014
rickcdewitt is offline   Reply With Quote
Old 09-11-2015, 12:27 PM   #318
rickcdewitt
also good 4x4 350 fan shroud? could i get a depth measurement and fan opening measurement ? i'm thinking of using it on my 6.0l swap if it will work. the 2wd shroud i have is just shy of the 6.0l fan. thanks,rick.
Old 09-12-2015, 05:25 PM   #319
wsben03
if you still have the rear leaf spring hangers i will take them both
wsben03 is offline   Reply With Quote
Old 09-28-2015, 01:56 PM   #320
DLTruck1973
To whom it may concern and to all of our valued customers.
Tom has asked me to let all of you know that he is alive and well but very busy with other obligations.
With that said he has asked me (Thomas) to post a message and ask all of you to contact DLTRuck1973 for any of your parts needs moving forward. As some of you know, Tom brought me on in January to handle on line parts sales under DLTRuck1973.
As always, we appreciate all of the business from all of our customers.
I (Thomas) will try to answer your questions, do shipping quotes and take care of any transactions as prompt as possible.
For anyone local, come in and see us Mon-Fri at D&L Truck Parts 91720 HWY 99S, Junction City, OR
Thank you all for your patients,
Thomas
DLTruck1973 is offline   Reply With Quote
Old 09-29-2015, 07:35 AM   #321
Kubie_d
I would be interested in the top part of the
Kubie_d is offline   Reply With Quote
Old 09-29-2015, 12:05 PM   #322
DLTruck1973
Are you the gentlemen I talked to on the phone this morning? Let me know if we can help you.
Thank you,
Thomas
Old 09-29-2015, 02:09 PM   #323
Kubie_d
Thank you,
Thomas
Yes. I will be searching to find it split. I will be calling on you for other parts. Thanks again for all your help.
Chris
Old 11-17-2015, 11:37 PM   #324
Rednwhitec20
Rednwhitec20's Avatar
I will take the far left crossmember in the very first picture and the front/rear hangers with the brackets that are located under the frame.
Rednwhitec20 is offline   Reply With Quote
Old 11-18-2015, 04:14 PM   #325
DLTruck1973
Do you need the front spring hangers, forward and rear position and the rear spring hangers, forward and rear position?
I should have everything you need.
Do you have a zip code for shipping quote? It will be a couple of days before I can get to it. Super busy now.
Thank you,
Thomas
