Old 11-24-2015, 09:28 PM   #351
mooseknuckles
mooseknuckles's Avatar
Re: "Old Olive" 1970 C10 porterbuilt build
that is one sweet truck!
mooseknuckles is offline   Reply With Quote
Old 11-25-2015, 10:10 PM   #352
knomadd
knomadd's Avatar
The exhaust looks great! I do have a couple questions. I can't really figure out how its mounted from the axle back. It looks like it's under the rear axle but also mounted to the frame near the rear bumper. Or am I seeing things? Can you explain how the exhaust is going to move when you air up the suspension, or put it on a lift (suspension droop)?
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 11-25-2015, 10:18 PM   #353
randomco
Thanks man. The pictures show the suspension at full lift, so the axle won't need to drop any further. If I do ever need to drop it out further, the whole exhaust system is flanged in sections and can be removed. You can see in the pics just before the axles the flanges. I could pull the rear sections off if needed.
randomco is offline   Reply With Quote
Old 11-25-2015, 10:27 PM   #354
knomadd
knomadd's Avatar
Cool, thanks for making that clear. I really like how the tips come out under the back of the bedside.
-Duane
Old 11-25-2015, 10:32 PM   #355
randomco
No problem. Ya I wanted it to be clean and just peek out a bit. Plus didn't want to just dump it under the truck.
Josh
1970 Chevy C10 SWB build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=639787
1976 Chevy k10 Silverado Bought new in '75 by my Grandfather
1965 Lincoln Continental Convertible - SOLD
1965 Lincoln Continental Sedan - SOLD
Old 12-05-2015, 12:46 AM   #356
randomco
Anyone know if this is how the booster is supposed to mount?
Josh
Old 12-05-2015, 12:29 PM   #357
blake's first
blake's first's Avatar
You can get rid of that bracket and make a flat one that will move the booster back to the firewall I made mine I can send you a pic of the template or there are ones that you can buy
My Name is Rusty Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=570083
blake's first is offline   Reply With Quote
Old 12-05-2015, 12:32 PM   #358
randomco
Please send me the template! Glad there are options, this bracket is huge! Random.co@gmail.com
How much did you need to trim the threaded shaft that connects to the brake pedal?
Josh
Old 12-05-2015, 12:38 PM   #359
blake's first
I didn't have to but I have a 5 speed and it moved the clutch pedal up to match the brake pedal so you may have to cut it down to where you like it. What brakes do you have if there big and you talk to wilwood you can get a master cylinder that you dont need power brakes for
Old 12-05-2015, 11:29 PM   #360
blake's first
This one is on my blazer so it not very clean but it shows how much it can be moved backName:  image.jpg
Old 12-05-2015, 11:40 PM   #361
blake's first
This is the template you will have to make the metal one is a stock off a one ton Chevy so you have to make the plate to off set to the c10 you can see the tab on the stock one I just put a weld on it and filed it tell a had the tab.. They sell billet ones my friend has bough two on pro touring Name:  image.jpg
Size:  33.6 KB. In the pic the bottom is the top.. Sorry I should have turned it over...
Old 12-06-2015, 01:32 AM   #362
ajgriffin
ajgriffin's Avatar
I don't think they sell only the bracket here, but just to give you an idea. www.hyrdratech.com
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together
ajgriffin is offline   Reply With Quote
Old 12-06-2015, 04:06 PM   #363
knomadd
knomadd's Avatar
I have one of the hydratech units. It has a billet mount plate you can sort of see in the pic ajgriffin posted. Also, the hydro boost booster is mounted 180 degrees opposite of what you have yours at now.
I have pics of my install starting on page 4 in my build thread, and pics with my wilwood master/prop valve setup on page 21, if you're interested.
-Duane
Old 12-06-2015, 04:25 PM   #364
randomco
Theres not a problem with mine being mounted that far out right? The kit I bought is specifically for the 67-72 trucks.
Josh
Old 12-06-2015, 04:36 PM   #365
toolboxchev
Wow, that is looking better by the day. I would be proud to do that kinda work to my rig.
Your truck is turning out to be Da Bomb!
toolboxchev is offline   Reply With Quote
Old 12-19-2015, 12:44 AM   #366
randomco
Haven't had an update in a little while so figured I'd add one!
Started rewiring tbe whole truck using an EZ Wiring 21 circuit kit.
Wired the Dakota Digital VHX gauges control box and fitted the gauges into the original bezel.
Vintage air is installed.
Kept tbe smooth firewall look
Hidden stereo that looks like a stock radio but is totally modern with am/fm, aux and ipod hookups, preamp 4 channel and amplifier outputs
Started bending hardlines for the AccuAir air ride
The shop that is going to do my custom brake and fuel lines is moving locations, hopefully I can get the truck in there in the new year.
After that it's pretty much ready to rock!
Josh
Old 12-19-2015, 11:12 AM   #367
9teen69
9teen69's Avatar
Looking really damn nice!!
9teen69 is offline   Reply With Quote
Old 12-20-2015, 04:46 PM   #368
mooseknuckles
sweet!
Old 12-20-2015, 06:37 PM   #369
Advanced Design
Advanced Design's Avatar
Coming together very nicely!
Advanced Design is offline   Reply With Quote
Old 01-27-2016, 02:27 AM   #370
rwade
rwade's Avatar
Josh, what did you do for bracing from the bottom of the bedside back to the bottom of the bed floor since you raised it? In front and behind the wheel opening. Sorry if I missed it
Thanks, Wade
rwade is offline   Reply With Quote
Old 01-27-2016, 09:23 AM   #371
mcbassin
Still Learning
mcbassin's Avatar
Very nice! Keep up the good work
Old 01-27-2016, 11:55 AM   #372
randomco
Thanks, Wade
I used the original support rods, cut the ends off and made new, longer ones with steel rod. Bolted them to the factory spots on the fenders and attached the other ends to tbe frame. I'll take some pictures today.
Josh
Old 01-28-2016, 11:05 PM   #373
69short
69short's Avatar
I apologize if I missed it, but what drive system did you use on the engine? Alternator, PS, AC, ETC?? Looks great man!! I love this truck
69short is offline   Reply With Quote
Old 01-29-2016, 03:23 PM   #374
rikyric
rikyric's Avatar
What gauges are these?
rikyric is offline   Reply With Quote
Old 01-30-2016, 03:12 PM   #375
knomadd
knomadd's Avatar
Those are Dakota Digital VHX gauges.
-Duane
