#1051 |
![]() Join Date: Apr 2009
Re: Shrunken66Stroker's build thread.
This truck has the perfect stance. How tall of a tire are you running front and rear?
- Patrick 1964 GMC pickup lwb ~ My newest build! 1937 Ford Coupe ~ Custom frame, LS1, quickchange 1950 Chevrolet 3100 ~ Bagged (Sold) 1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" ![]() 1967 Chevelle ~ 454 Triple Black (Sold) 1964 Chevrolet Impala SS (Sold) |
#1052 |
THanks. 17 inch rims all around, with a 30" tall tire in the rear(255 55 17) and I think a 27" tall tire in the front(235 50 17).
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
#1053 |
Started on the headers. I've got to get them dialed in, or at least mocked up to cut the floor and push it forward. #7 down, now for the rest.
#1054 |
Since I moved the engine back i had to move the mounting holds of the engine mounts, trans and also cut a hole for the shifter to come through as close to the seat as I could go. I had to also make an offset for the shifter to clear the seat.
#1055 |
Good to see you making progress!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
#1056 |
Checking clearance between the throttle body and electric fans. Going to have to try and find a 25 degree, 4 inch elbow for the intake and go strait down between the fans with it since the intake is slanted down in the front. I shouldn't have any cooling issues with all that exposure, hopefully. I also had to offset the NoLimit rack and pinion mount. With the strong arms there was no clearance, so I cut off the mounts and offset them about 3/8" up.
#1057 |
Thanks Astronaut! It's been slow for the past few years but I'm getting out there when I can and inching along.
#1058 |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#1059 |
So, after trying to fit and tack the header pipes on the truck, I finally figured out that I needed to create a mock up, make a jig and fit them up on my work bench. Here's where I got the idea: www.stainlessheaders.com
Great video series. This is tougher than I thought it would be, but well worth it. I just need to fit number 5, tack it together and then check it on the truck. Then the fun part, welding them all up. Oh yeah and then the other side.
#1060 |
Got some Porterbuilt hood hinges today. Such quality stuff.
#1061 |
This is still one of my favorite builds on here, I'm going to use some of your ideas on my 64 build I'm going to start soon.
#1062 |
More nice work here. The header project looks like fun!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#1063 | |
#1064 |
Got the hood hinges in. I just need to weld the mounts to the hood and bolt it up.
#1065 |
Daring to be Different
Dennis ![]() http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] ![]() I AM WE TODD IT, I AM SOFA KING WE TODD IT |
#1066 |
![]() ![]() Join Date: Oct 2011
Just read this build, amazing work, ready for more
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#1067 |
Thanks guys.
I had some time yesterday, so I mocked up the passenger side headers. I repeat, if you're going to do this, do it right the first time and make the mock ups, the jig and weld them up on the bench. It saves a ton of time. Now I know exactly what bends to order too. This header looks a little crazy but it's got to bend around the starter and A-arm pivot. They're not quite equal length, but should flow pretty well. The angle makes it look like they hang down past the frame rail, but they're 3 inches above the bottom of the oil pan, so if I hit the headers on something when I'm driving I'll have bigger problems.
#1068 |
Now there's a technique I haven't seen before. Inexpensive and easy to work with. Too bad it wouldn't take the heat, you'd be done!
#1069 |
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
I am purely intrigued by the build of the headers!
That is sooooo trick!... How good of a TIG welder are you? LOL! Do you have a set-up to fill the tubes with inert gas while welding? Do the tubes really need to be equal length? or is it more critical that the exhaust pulses reach the collector at equal intervals because of the firing-order to create a scavenging effect? Sorry for all of the questions!
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=512904 |
#1070 |
![]() ![]() Join Date: Jul 2002
Very interesting build. AS mentioned, watching you do the headers is wild!
#1071 | ||
Thanks. I ordered more bends today and will post progress as I make it.
#1072 |
60-66 Nut
X2......I never would have thought of mocking up with ABS pipe
#1073 |
Great idea. I applaud your patients.
#1074 |
I got the hinge mounts welded on to the bottom of the hood and mounted it up. Damn is that hood heavy. I can't wait to cut it into 3 pieces. Stay tuned.
#1075 | |
Tags |
1966, bagged, disc, long to short, stroker |
