12-13-2015, 06:23 PM | #151 |
Re: The Snortin' bull
Rear brakes's all assembled and reconditioned and ready to from backing plate's out.Waiting for axle's now to come from being redrilled.
The Snortin' Bull |
12-20-2015, 02:35 AM | #152 |
Adapting the 1960 gmc hubcap's to later model 5 on 5 wheel's.This is still a budget build . I had some (impala) Caprice Police Cruiser rim's around so I used these for the Bull at this time. Kept it simple to keep the cap's retained.
The Snortin' Bull |
12-23-2015, 12:18 AM | #153 |
The axle's are back.Reinstalled them today into housing. Redrilled for 5 on 5 and turned down in the center to fit the later model drum's.FYI or BTW on these early Dana 44 axle's they use same as the big Ford ( torino ) axle bearing's very common and they are 30 spline axle shaft's.
The Snortin' Bull |
12-26-2015, 06:42 PM | #154 |
Rear brake drum's are on. As other's have noted in the past on these build's 11 x 2 finned from later c-10's work and clear the backing plate.
The Snortin' Bull |
12-26-2015, 06:44 PM | #155 |
Also the correct rear park cable's arrived and are now installed.Napa still offer's these.LMC list them though they are not for the 1960 to 63 dana's.
The Snortin' Bull |
12-27-2015, 02:11 PM | #156 |
Rear wheel's back on .
The Snortin' Bull |
12-28-2015, 12:08 AM | #157 |
SAVING ONE TRUCK AT A TIME
Lookin very nice. Love the caps.
53-suburban (99% done) 40-pick up (99.9% done) 12-cc lb dually D-max (dd) 61-crew cab D-max "PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT" 53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091 1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088 1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999 |
12-28-2015, 12:48 AM | #158 |
Those caps really set it off, nice touch.
12-28-2015, 11:36 AM | #159 |
Thank you .,The cap's i just wanted to try to make work.
The Snortin' Bull |
12-28-2015, 11:38 AM | #160 |
Thank's .I think the cap's are cool for a 1960 GMC there kinda' fancy.
The Snortin' Bull |
01-03-2016, 09:35 PM | #161 |
Exhuast need's to be run off the shorty block hugger header's before I start the engine. Gettin there . Check list to move the truck on it's own down to few item's.
The Snortin' Bull |
01-06-2016, 11:12 PM | #162 |
a little frame webbing insulation for the bed wood to lay on bed cross rail's.
The Snortin' Bull |
01-08-2016, 12:27 AM | #163 |
Getting closer and closer every update.
01-08-2016, 04:46 PM | #164 |
It's funny, I'd never see a hubcap like yours till I saw this thread. Then 4 of these showed up for sale locally, still in the factory boxes, never installed. 1955 though, you said yours were 1960?
01-09-2016, 12:59 AM | #165 |
Yes the caps are 1960. The one's you are showing are sweet gem's.
The Snortin' Bull |
01-09-2016, 11:48 AM | #166 |
naloc, check your private message folder.
01-10-2016, 08:24 PM | #167 |
I did manage to get a bit of time in this weekend on the Bull .Not much Thuough, got the exhaust started .The first foot of the down tube's.
The Snortin' Bull |
01-16-2016, 12:24 AM | #168 |
Piece by piece.Fab up exhaust front to back. This is alway's time consuming.There are very talented exhaust builder's out there though on my home garage floor I am not one of them.Especially on a bagged truck.
The Snortin' Bull |
01-17-2016, 03:06 AM | #169 |
Right side exhaust together to midpoint of truck.
The Snortin' Bull |
01-17-2016, 03:09 AM | #170 |
one last underhood install the detent cable bracket for the transmission tv cable.
The Snortin' Bull |
01-17-2016, 03:12 AM | #171 |
Amazing looking work here.
Every hour you get is progress.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
01-17-2016, 10:14 PM | #172 |
Got the lh and rh front exhaust pipe's done and hung.The goal is tuck up high and muffler's to the rear past the cab floor .
The Snortin' Bull |
01-17-2016, 10:16 PM | #173 |
This is hour's into pipe's finally a muffler .More pipe to fab.to come.
The Snortin' Bull |
01-17-2016, 10:20 PM | #174 |
The easy way out build a couple of stack's up thru bed floor.Just playin' around.Fab'd pipe's to flow out to side's to follow kickup and to rear of bed into corner's to dump.
The Snortin' Bull |
01-17-2016, 10:21 PM | #175 |
Thank's Grizz.5 Minute's or 5 hour's a day the past 18 month's to get this point.
The Snortin' Bull |
