Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 12-01-2015, 12:16 AM   #501
Captainfab
60-66 Nut
Re: D52 Caliper Rear Disc Brake Brackets
Payment received and PM replied to
Originally Posted by rydeordie View Post
Payment sent.
Old 12-04-2015, 07:52 PM   #502
LDO
LDO's Avatar
Originally Posted by cpetersen View Post
I believe these are D52 calipers? With these calipers and rotors off of the astro van they will work with 15" Wheels won't they?Attachment 576917
anyone have pictures of how the e-brake cables mount to these calipers and what cables to use?
LDO is offline   Reply With Quote
Old 12-04-2015, 11:46 PM   #503
BIGJOEGS
I received my brackets today and they look great. Also I told John I needed these brackets as soon as possible because I had my truck on stands waiting to finish the install and he went out of his way to get the to me asap.
Thanks again John I really appreciate the great service and product.
Joe
BIGJOEGS is offline   Reply With Quote
Old 12-05-2015, 01:06 AM   #504
Captainfab
60-66 Nut
Bob. The brackets I made for you do not utilize D52 calipers. They use D154 calipers which are similar but smaller. Did your calipers come with the levers, cable brackets and springs? The cable housing attaches to the cable bracket with a clip and the cable itself goes up thru thru spring and connects to the notch in the lever.
Thank you for the purchase Joe
Joe
Old 12-05-2015, 09:35 AM   #505
LDO
LDO's Avatar
Thanks Capt, I'll email you a pic of what I have.
Old 12-25-2015, 02:46 PM   #506
dunyet
Capt, looking for a set of brackets for a 68 C10, purchased the 5 on 5 axle conversion from summit, would like to upgrade with these at the same time. Let me know how to pay
dunyet is offline   Reply With Quote
Old 12-25-2015, 10:32 PM   #507
Captainfab
60-66 Nut
I replied to your PM
Old 12-27-2015, 07:20 PM   #508
dunyet
payment sent via paypal
Old 12-28-2015, 12:08 AM   #509
Captainfab
60-66 Nut
Payment received.
Old 12-28-2015, 10:48 AM   #510
dunyet
thx
Old 01-13-2016, 02:43 AM   #511
crakarjax
crakarjax's Avatar
Won't these brakes cause pad knockback on the 12-bolt?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 01-14-2016, 12:44 AM   #512
Captainfab
60-66 Nut
What do you mean by "pad knockback"?
Old 01-14-2016, 01:16 PM   #513
crakarjax
crakarjax's Avatar
This is when the rotor deflects slightly, pushing the pad and piston in with it -- the result is less braking power until the brakes are actuated again. This site does a good job explaining but seems to be missing illustrations:
http://www.stoptech.com/technical-su.../pad-knockback
On full-floating rears this isn't an issue, but with our 12 bolts there's some axle endplay that causes pad knockback. Floating calipers get around this with the ability to move with the hub. Fixed calipers like these do not. An alternative solution although not 100% effective is to use c-clip eliminators which hold the axle in place to a much greater degree.
So I guess the answer is that these calipers are ok if you are running c-clip eliminators.
Old 01-15-2016, 01:37 AM   #514
Captainfab
60-66 Nut
Is this 'pad knockback' something you have experienced with your rear disc brakes? Did you purchase a set of these D52 brackets from me?
The D52 calipers are not solidly bolted to the caliper bracket. They do slide on the 'bolts' that connect them to the caliper bracket. Yes the axles in a semi floating differential do have some lateral movement. In a differential that is in good condition, that movement should be minimal. I have not had one complaint regarding 'pad knockback' from any of my 100+ customers that have bought any of my rear disc brackets.
Old 01-15-2016, 03:30 PM   #515
crakarjax
crakarjax's Avatar
My bad, I saw the first brake pic and it looks like the willwoods have front and back pistons which would make it a fixed caliper! Since these are floating I surmise that they'd work well without the c-clip eliminators.
Old 02-06-2016, 12:41 PM   #516
The Rocknrod
Moderator
The Rocknrod's Avatar
Will the 1985 Cadillac Eldorado calipers fit? They ave e-brake as well.
Old 02-07-2016, 01:28 AM   #517
Captainfab
60-66 Nut
No. Those are the smaller Metric calipers. Only the '76-'79 calipers as stated in this thread.
Old 02-15-2016, 06:48 PM   #518
Spartan44
Hey capt I'm interested in a set of your brackets can you send me an incoice. Are these in stock ready to ship? Thanx
Spartan44 is offline   Reply With Quote
Old 02-16-2016, 01:16 AM   #519
Captainfab
60-66 Nut
No I do not have a set ready to ship. I do have the parts for them, that will have to be cleaned up and finished. I will send you a PM with ordering and payment info.
Old 02-16-2016, 12:31 PM   #520
Spartan44
Hey captin I just paid through paypal. Can you let me know when you ship them so I can look out for them thanx. Jose
Old 02-17-2016, 12:46 AM   #521
Captainfab
60-66 Nut
If you have your PayPal settings turned on, you will receive an automatic shipped notice along with the tracking number. I should be able to ship your D52 brackets tomorrow.
Old 02-21-2016, 11:14 PM   #522
whytry85
whytry85's Avatar
You wouldn't happen to have any pics of someone using this kit with a porterbuilt rear 4 link would you? I'm wanting to get a set of brackets but think I'm gonna have issues with the panhard bar bracket interfering with the caliper with my differential being narrowed 8.50 inches
whytry85 is offline   Reply With Quote
Old 02-22-2016, 12:01 AM   #523
Captainfab
60-66 Nut
Sorry but no I do not. No one sends me pictures. All there are, are what you see in this thread.
What about moving the caliper to the front of the differential?
Old 02-22-2016, 11:58 PM   #524
whytry85
whytry85's Avatar
No worries. I can modify the bracket if push comes to shove. I could do that more than likely but the bars aren't much further inboard than the panhard bar bracket
Old 02-23-2016, 12:14 AM   #525
Captainfab
60-66 Nut
The inside surface of the caliper bracket will be 1-5/8" inside from the outside of the backing plate flange.
