05-30-2015, 09:36 AM | #1 |
A very nice restored A/T Tilt Column.
I have for sale a very nice restored A/T Tilt Column.
The rebuild includes a complete disassembly and inspection for worn or broken parts. This is followed by cleaning and bead blasting most parts. The Hub and Housing are powder coated on most of the time but not always. The rest of the column is then painted and rebuilt to factory specs. This includes packing and set torque to factory specs on upper bearing assembly. The lower bearing is cleaned and packed. The dust or air seal is replaced with a new one. I have the lower bearing retainer and the screws that mount to neutral safety / backup light switch re-cadmium plated. The original turn signal harness is checked using one of my trucks. It will be reused if it passes the use test. It is then cleaned and re-greased. A new turn signal harness is available on request. The column is rebuilt using new, NOS and quality used parts. Column is ready to bolt in. On automatic columns the neutral safety/backup light switch is installed and has been adjusted to match the shift indicator. No additional adjustment should be needed, just plug and play. If you want to replace the reproduction shifter arm I have a number of GM original shifter arms that have been re-chromed. All of them are high quality show chrome. I have both the standard pickup shifter as well as some out of vans which are about 4” shorter. Some owners opt for the shorter shifter based on a smaller steering wheel size. The price is an additional $50.00. The following New or NOS parts were installed: - Flasher Knob - Lower Inner Dust Seal - Upper Rubber Gasket to Dash Bezel - Lower Rubber Gasket to Firewall - Standard Shifter Arm or Short Van Shifter. Your choice. - Shifter Arm Knob - Tilt Release Arm - Turn Signal Arm - Tilt Pointer - Transmission Indicator Lens Price is $500.00 and up plus shipping to CONUS. I accept Checks, MO's and PayPal. Please include your shipping address. I will ship this via UPS or FedEx. I have several more columns to complete, so if you would like one let me know.
Roger Koop Last edited by RogerKoop; 07-06-2020 at 02:01 PM. |
05-30-2015, 09:37 AM | #2 |
Re: A very nice restored A/T Tilt Column.
More pics
Roger Koop |
05-30-2015, 04:14 PM | #3 |
They look good , great deal !!! Is the one posted 500.00 with either shifter
or are they all 500 + 50 for shifter ? How will you ship them in cardboard or wood ? Can I get a quote to 37043 ? Thanks
72 GMC K 1500 SWB W/ 68 CHEVY FR/CLIP -- SOLD 70 CHEVY C/10 LWB x 2 ----- SOLD 67 CHEVY SWB IN PROGRESS " ALMOST HEAVEN " Build thread : http://67-72chevytrucks.com/vboard/s...15#post6826315 |
05-30-2015, 06:39 PM | #4 |
PM sent
Roger Koop |
07-07-2015, 03:15 PM | #5 |
ttt
Roger Koop |
07-10-2015, 12:35 AM | #6 |
Quote to 67801 please
07-10-2015, 01:53 PM | #7 |
Roger Koop |
07-10-2015, 05:16 PM | #8 |
If someone brought you a column, how much would you charge to rebuild it for them?
1969 Chevy CST/10 396, PS, PB, A/C |
07-10-2015, 08:04 PM | #9 |
Do you have any gear selectors that would work with my 4l60e? Beautiful column that's my only holdback. I would even take a tilt floor shift column if you had one restored.
07-10-2015, 09:51 PM | #10 |
Price runs around $250.00 to $300.00 plus what ever parts are needed.
Roger Koop |
07-10-2015, 09:55 PM | #11 | |
I will have a 4-speed later next month. Still need some parts for it.
Roger Koop |
12-05-2015, 11:50 PM | #12 |
ttt
Roger Koop |
12-06-2015, 09:13 AM | #13 |
Would you rebuild the tilt that I have in my truck or exchange it for one you have already rebuilt? If you would exchange is there any value in the one I have as a core?
Ugly 61 |
12-06-2015, 05:33 PM | #14 |
70+ ( Old Skool Club )
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
12-06-2015, 06:04 PM | #15 |
I can do either. The price either way is based on what parts were used to rebuild yours and mine. What condition is yours and what parts will need to be replaced?
Roger Koop |
12-06-2015, 10:33 PM | #16 |
Shift bowl is worn out where the gearshift pin goes through and the bottom 2 or 3 notches won't stay latched. Also need a new turn signal unit.
Gary |
12-13-2015, 01:25 PM | #17 |
I've got the parts to repair yours. Its possible I may be able to repair your hub or replace it with a nice used one or NOS. As for it not staying latched I will need to get it apart to see whats happening. Let me know.
Roger Koop |
12-20-2015, 11:36 PM | #18 |
I'll be starting on a complete rebuild on my truck after the 1st I'll contact you when I get the column out.
Gary |
12-21-2015, 10:13 AM | #19 |
I have another tilt column ready for shipping.
Roger Koop |
01-31-2016, 01:17 PM | #20 |
ttt
Roger Koop |
02-02-2016, 09:38 AM | #21 |
ttt
Roger Koop |
02-02-2016, 11:12 AM | #22 |
I have a 68 gmc with a 700r4 zip 37745 short shifter price quote please .
02-02-2016, 11:39 PM | #23 |
Loves all GMC trucks
Roger,
I have 2 people asking for tilt columns... Are you bringing any to the swap meet this weekend?
Mike If your helping someone and expecting something in return... your doing business not kindness! |
02-03-2016, 09:33 AM | #24 | |
Need any vent windows. I have 2 sets ready to go.
Roger Koop |
02-03-2016, 09:38 AM | #25 |
what would a 4 speed tilt for a 71 blazer shipped to 01720?
