02-10-2016, 10:33 AM | #26 |
Re: Mufflers VS Catalytic converters
My girlfriend loves the smell of a car running a QuadraJet. I never paid much attention to the smell and thought she had a sensitive nose
02-10-2016, 02:53 PM | #27 |
Get an exhaust hose and run it out the door.
02-10-2016, 03:20 PM | #28 | |
- Carb'd car with a cat ('75 Monte factory) - Carb'd truck with no cat ('70 GMC) - EFI car with no cat ('69 Camaro ZZ502 BS3 Sequential EFI) The EFI car still smells like raw gas. It runs at about 14.6:1, but to get near stoich at idle with a cam in a motor like these requires a lot of extra fuel that winds up getting in your girlfriend's hair. Now a poorly tuned car with cats will stink like sulfur dioxide, so there's no substitute for properly tuning the thing. But properly tuned, cats get rid of the raw fuel smell. Maybe if gasoline still smelled like it did in 1970 I'd be OK with it, but it doesn't.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
02-10-2016, 06:26 PM | #29 |
Parts and more parts
I may be missing something here. You told us that the truck was a 350, but never talked about the carb brand, the size of the carb, what jets are in the carb, or what the timing is set at, type of intake on the engine, or what temperature of T/stat that you use. There could be changes made here that could make it smell less like an old dump truck and more like a well tuned machine. What grade of gas do you use and what your spark plugs are set at. If you consider a multi-spark unit, like a MSD 6AL; you can get a more complete burn of your fuel since it keeps sparking through the fuel burn. What heat range are your spark plugs and are they burning at the right color? A good set of low resistance spark plug wires will help give you a better burn and a little more HP.
I personally would not put cats on the truck, I would consider a good set of mufflers---I use the Magnaflow stainless mufflers, since I used up several Flowmaster mufflers and had to replace them on a regular two year basis. This was on more than one truck, too--so it is not how the truck was used (daily driving and lots of highway use) Do you have a full exhaust or does it dump out under the truck? There is an advantage in the longer pipes, to get a good purge of your engine's cylinders and give the exhaust gases time to collapse and complete the burn of the fuel. Are you getting plenty of air through the carb to get the proper air/fuel mix for a right burn of the fuel. If your air cleaner is restrictive, then the fuel mix could be rich. If you have a cam in the engine, then you may not be running in the right air flow area of the venturis. A cam can make you set the idle up to keep the engine running and cause the butterflies to sit in the transition area and not in the idle area, which would make your carb run rich.
Frank |
02-10-2016, 06:58 PM | #30 |
I'll add my vote for Magnaflow - I have them on my Truck and my 2+2 because they're quiet when you want to be quiet and loud when you don't, and they don't drone.
02-10-2016, 07:24 PM | #31 |
I agree with this. I can smell an old carbed car a mile away but my Stock 5.3 without cats has no smell.
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
02-10-2016, 08:20 PM | #32 |
Blue 67
Very good information.
Piecesparts, to answer some or your questions, I don't know anything about the engine internal since I bought the truck with it. I have the edlebroke performer intake and eldlebrock 1406 600 cfm carb. I don't know the jet sizes but they are what the carb came with them when I bought it. Downsizing the jets is what I was thinking about as my next step since fuel injection is out of the picture at this point financially. I have the initial timing set at 12-15 and total timing at 35-37 at 2500 RPM. I have HEI ditributor and I changed the spark plugs and gapped them accordingly when I did the upgrade, I don't remember the numbers since it was while ago. I don't know the heat rating or the plugs. Thermostat is 180 degree. I put 87 gas. The air filter and housing is the edlebrock, the one which is open all around. My exhausts pipes exist behind the rear wheel. It is a very good point to have them exist straight out back. The exhaust pipes and mufflers are JCWhittney (if I remember correctly since it has been few years). Does muffler can make a difference?!
1953 GMC 3/4 ton: current project 1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake 1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!! 1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive 1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project 2005 Silverado 2500, 4x4 Duramax, original owner |
02-11-2016, 01:31 PM | #33 | |
We also tend to have more aggressive cams in the older engines but a lot of LS guys wind up running factory cam profiles because the motors make enough power in stock form. I can't prove the cylinder head is the difference, but my '69 Camaro with EFI still smells the same as the Q-Jet car. But it has a fair bit of cam overlap.
02-11-2016, 05:00 PM | #34 | |
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
02-11-2016, 06:12 PM | #35 |
I'm running a complete Magnaflow system on my 72 with cats. The engine is a ZZ4 with FIRST TPI. The stank is gone. The cats are very small and around $85 dollars each. My wife will now not only ride in the truck, but on occasion actually drives it.
Here's a pic of the cats.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
02-11-2016, 09:56 PM | #36 |
Shortbed club member
Maybe you can try an alternative route and use one of these.
http://www.powerpluslubricants.com/fuelfragrances.html
71 custom/10 6.0/4L80E SWB ece 4/6 72 custom camper 350/3 spd 2020 Chevy Express 3500 2023 Hyundai Tuscon 1986 GMC 3500 Bucket Truck Sent from my Rotary Phone via 14.4kb/s modem. |
02-11-2016, 10:29 PM | #37 | |
Does your EFI employ an air-fuel sensor to monitor and adjust the mixture live?
02-13-2016, 09:38 AM | #38 |
I think this guy already has mufflers. The problem is the exhaust smell and no brand or design of muffler will effect that.
An LS engine is a totally different design, so not to be compared in this situation. A carbureted LS engine w/o cats will likely produce less fuel smell than a fuel injected 350 with cats. Cats are an after the effect mask the issue add-on. LS engines have addressed these issues from within with a more efficient design from the get-go than the one from 1955.
02-13-2016, 01:56 PM | #39 |
I also had a TBI 350 in my 76 K10, it had vortec heads, 10.5:1 compression, edelbrock performer rpm intake, bored throttle body, and headers with no cats, and that truck had zero fuel smell from the exhaust. When I first got it running it wasn't properly tuned yet so it did stink a little, but after it was properly tuned it did not stink.
