Old 02-22-2016, 10:26 PM   #1
lexteak
58 Apache with C4 Flatout Engineering
New to the form. Just starting on my first build. 58 Apache. Attempting to install Flatout Engineering C4 kit. Just got the frame back from the blaster and pondering what to do next. Love the forum and happy to post my progress.
lexteak is offline   Reply With Quote
Old 02-23-2016, 09:24 AM   #2
Kim57
Kim57's Avatar
Re: 58 Apache with C4 Flatout Engineering
Welcome.
Should be a real nice build.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 02-23-2016, 01:57 PM   #3
lexteak
Thanks Kim. Lots of work ahead, hope it all goes smooth.
Jay.
Old 02-23-2016, 06:21 PM   #4
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice looking truck! Looks like you have a C-10 clip on your TF frame?? Don't think the Flat Out cross-member will work with that setup.
ChuckDriver is offline   Reply With Quote
Old 02-23-2016, 07:06 PM   #5
lexteak
JJ You are correct, that is a c10 frame. That is what came on the TF when I purchased it. It had a c10 frame, SBC 350 with a TPI a narrowed ford 9 inch and a turbo 400 trans. Wasn't real confident in what I had, so I sold everything but the body. Found an original TF frame in Wisconsin and that is what I am starting with now. Bought a wrecked corvette, so the suspension, motor and trans from the vette is going in the TF.
Saw part of your build thread. looks great, cannot wait to go thru it in detail. looks like a lot of good information I can take advantage of.
Much appreciated. Thanks Jay.
Old 02-23-2016, 07:51 PM   #6
dug224
dug224's Avatar
Looking forward to the build.
dug224 is offline   Reply With Quote
Old 02-23-2016, 08:07 PM   #7
lexteak
Thanks Dug. Saw you thread a few weeks back. Great work. Keep it going.
Old 02-23-2016, 08:32 PM   #8
lv2tri2
I have a similar project and considering Flatout's kit so I'll be following your build. Good looking truck.
lv2tri2 is offline   Reply With Quote
Old 02-23-2016, 08:44 PM   #9
lexteak
I ordered the kit a few weeks back. It is nice stuff. real high quality. Going to try and mock up the rear first. then move on to the front. Sounds like getting the front wheel looking correct is the main challenge. I plan on putting the entire frame together first. then taking it apart for paining. Hopefully a little warmer by then, so the painting will not be a problem. I'll try a document my progress as best I can. Hopefully you can benefit from the many rookie mistakes i'm sure I'll make. Thanks.
Old 02-24-2016, 10:28 PM   #10
FarmerSid
FarmerSid's Avatar
Nice build. Doing the same but in a AD.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 02-25-2016, 10:33 AM   #11
lexteak
Thanks. Got thru a few pages of your build. Wow, I am simply stunned by your metal working skills. I would give my soul to be able to do anything close to that. Real nice work on the IFS brackets also. Looks as good as mine from flatout. Can't wait to look at the rest of your thread.
I have an uncle that lives up your way in Oshawa. not sure how far you are from there. nice area.
Old 02-25-2016, 08:28 PM   #12
Advanced Design
Advanced Design's Avatar
Great project and I will be tagging along. Have fun!
Advanced Design is offline   Reply With Quote
Old 02-26-2016, 01:04 PM   #13
FarmerSid
FarmerSid's Avatar
Thanks! I'm about an hour and a half east of there. Actually going to be up there next weekend for hockey.
C4 IFS & D44 IRS
5.3 HO L33
Old 02-26-2016, 01:22 PM   #14
Daze57
Daze57's Avatar
lexteak
Welcome to the board
i have the same vette set up - ans yes v good quality stuff --- for the IRS measure several times and mark everything -- if you are bolting it in get some good sharp drill bits .
good luck sir !!!!
Daze57 is offline   Reply With Quote
Old 02-26-2016, 08:33 PM   #15
lexteak
Thanks for the info. Going to try and mock up the rear this weekend. Weather here tomorrow is 67. Might have some yard work that gets in the way. hope its quick. Saw Jim's post and he indicated the wished he started with the Front Suspension. I was going to start at the Rear. I asked Jim for some clarification. Any thought you have on which is better to start with ?
Old 02-28-2016, 09:24 AM   #16
FarmerSid
FarmerSid's Avatar
I would start with the front first. The vette rack sits up high on the front cross member which limits how low you can set the ride height. You have to C notch the front frame rails for the rack to go through. The amount of notching depends on how low you want your truck to sit when finished. By the looks of the IRS and rear of frame picture, you plan on installing the IRS without making new C notches. If that's the case, you should have no problem with the IFS if you install the rear first.
C4 IFS & D44 IRS
5.3 HO L33
Old 02-28-2016, 09:33 AM   #17
lexteak
I might end up notching the rear also. I'm going a little low, but not dramatic. I'm in the 8 inch range for the rockers. I'll take both F&B into consideration before I make any final decisions. Again I appreciate the info. Thanks Jay.
Old 03-22-2016, 08:55 PM   #18
lexteak
Got a little farther along the last couple weeks. Had a few tiny tweaks in the very front of the frame at the end. Pushed them out with a HF pipe bender. Finally found something useful for that chuck of iron. I made some levelers for my jack stands and set the frame up with a little rake. I clamped the rear in place and took some measurements. Seems the way the rear mounts you can only go so low, because the batwings will interfere with the frame. Best I could do was about 2.4 degrees rake. Not a real fan of that much rake but without any frame mods that is my only option.
Long story, but I came across a second 58, that is a fleetside. Could not pass up the deal. Had in in storage and just drug it home. It currently sits in my driveway. So I just used it to mock up the ride height and rake from the measurements I took on the frame in the garage. Fleetside vs Stepside but I think the ride height and rake with appear similar. Made a cardboard wheel and tire, because I cannot stand up the real tire in the well when it sits so low. Tires are 28'' which is what I plan on using.
Maybe you guys can give me some feedback on the overall look of the stance. First group of pics is the 2.4 ride height, then about 1.5 and finally about .5 degrees.
Cannot decide if I should go to the effort to modify the frame so I can go lower that the 2.4
Old 03-22-2016, 09:04 PM   #19
lexteak
2.5 degrees
Old 03-22-2016, 09:06 PM   #20
lexteak
1.5 degrees
Old 03-22-2016, 09:08 PM   #21
lexteak
And finally about 1/2 degree.
Old 03-22-2016, 09:25 PM   #22
lexteak
Here are the 2 extremes from across my street. 2.5 degrees and about .5 degrees. Something draws my eye to the more flatter look. It will be a lot of extra effort to modify the frame, but it seems the better stance.
Old 03-23-2016, 06:25 AM   #23
Hilljack51
Hilljack51's Avatar
2.5° definitely gives it more of a hot rod look to it, but I'd have to agree with you on the attractiveness of the subtle 0.5°. Great illustrations!
My "life long" build: http://67-72chevytrucks.com/vboard/s...d.php?t=698026
Hilljack51 is offline   Reply With Quote
Old 03-23-2016, 08:13 AM   #24
lexteak
Thanks. I wish one looked way better than the other. Then my decision would be easy. I think I'll start exploring what it would take to drop it down. The Flatout kit mounts the batwing bushings at a very specific angle on the hump in the frame over the axle. If I go with any mods I'll have to ditch those and make my own brackets. Your build is looking good. keep up the momentum.
Thanks jay.
Old 03-23-2016, 08:18 AM   #25
Kim57
Kim57's Avatar
I like the 1.5.
2.5 is a bit much and .5 looks too low in the rear.
Kim
My build thread
