Old 03-07-2016, 04:14 PM   #2851
68post
Re: Restoring Rusty
Originally Posted by Gregski View Post
Hi Tim
The oil pump and pickup screen is brand new, I replaced it a few months ago when I did the rear main seal and the oil pan gasket.
That's swell !! Your engine loves you
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 03-07-2016, 08:32 PM   #2852
Titomars
Titomars's Avatar
Re: Restoring Rusty - Budget Top End Build
but don't you got one of them BBC, Big Beautiful Chevrolet? lol
yup, a huge heavy gas guzzling 454.................. and loving every second I drive it.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 03-07-2016, 10:03 PM   #2853
Gregski
Gregski's Avatar
Re: Restoring Rusty - Engine Stroll
we finally got a break in the weather and the sun came out, so I decided to take the engine for a walk
I don't get how in our fourth year of a drought here in Norther California it has been raining and I mean poring for the last seven days, (things that make you go hmmmm)
Gregski is offline   Reply With Quote
Old 03-07-2016, 10:07 PM   #2854
Gregski
Gregski's Avatar
Re: Restoring Rusty
doctor, the patient is prepped and ready for surgery
Old 03-07-2016, 10:09 PM   #2855
Gregski
Gregski's Avatar
Re: Restoring Rusty
then it was time to [ahem] MAKE THIS ENGINE GREAT AGAIN !!!
Old 03-07-2016, 10:25 PM   #2856
enaberif
Re: Restoring Rusty
Do yourself a favor and do NOT break that lower dipstick tube and do not misplace it lol. Be lucky you still have it.
enaberif is offline   Reply With Quote
Old 03-07-2016, 10:26 PM   #2857
Gregski
Gregski's Avatar
Re: Restoring Rusty
somehow I am always happier behind a wheel, even if it is a 4 inch on an angle grinder, ha ha
I don't know about you, but I can find plenty of things to cut my hands on under the hood, so I decided the engine block wasn't gonna be one of them
time to smooth out that casting crust
Old 03-07-2016, 10:40 PM   #2858
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: Restoring Rusty
I would replace those steel cast plugs with some brass ones while you are at it its cheap and should never leak if installed correctly that's not a fun job with the engine in the truck/car
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 03-07-2016, 10:47 PM   #2859
Gregski
Gregski's Avatar
Re: Restoring Rusty
dang it you are right about that, I already replaced two of them with the engine in the truck, luckily they were not the ones hiding behind the motor mounts, but I wasn't smart enuff to go brass, I got the cheap shinny ones from China that the AutoZoner handed to me, lol
Old 03-07-2016, 10:49 PM   #2860
Gregski
Gregski's Avatar
Re: Restoring Rusty
the sharp edges around the oil filter housing got some angle grinder love too, there much better
Old 03-07-2016, 10:51 PM   #2861
Gregski
Gregski's Avatar
Re: Restoring Rusty
and on to the other side
Old 03-07-2016, 10:54 PM   #2862
Gregski
Gregski's Avatar
Re: Restoring Rusty
first we knock off the ugly
Old 03-07-2016, 10:58 PM   #2863
Gregski
Gregski's Avatar
Re: Restoring Rusty
and by zi Pompa de Gasolina
Old 03-07-2016, 11:00 PM   #2864
Gregski
Gregski's Avatar
Re: Restoring Rusty
and second side done
labor = about 1 hour per side
Old 03-07-2016, 11:10 PM   #2865
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
Always wanted to do the type of smoothing you are doing!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-07-2016, 11:19 PM   #2866
Jeramy
Jeramy's Avatar
Re: Restoring Rusty
something i plan to do when i start assembling mine...unless i forget
1981 Silverado C10 LS/4l60e
My truck may be loud and ugly but I love her like bacon
Jeramy is offline   Reply With Quote
Old 03-08-2016, 08:57 PM   #2867
Gregski
Gregski's Avatar
Re: Restoring Rusty
had to go into town fer supplies, yup this is how the magic happens
Old 03-08-2016, 08:58 PM   #2868
Gregski
Gregski's Avatar
Re: Restoring Rusty
it was a nice day so I decided to have a little pool party and all the dirty bits were invited
Old 03-08-2016, 09:04 PM   #2869
Gregski
Gregski's Avatar
Re: Restoring Rusty
word quickly got out and friends invited their friends, dirty little rascals
Old 03-08-2016, 09:08 PM   #2870
Gregski
Gregski's Avatar
Re: Restoring Rusty
and a few more
the harmonic balancer was a dirt magnet for sure, I'm surprised it stayed balanced with that 9 pounds of dirt stuck to it
Old 03-08-2016, 09:10 PM   #2871
Gregski
Gregski's Avatar
Re: Restoring Rusty
while those bits were soaking I got started on the engine
got the front side cleaned
Old 03-08-2016, 09:13 PM   #2872
enaberif
Re: Restoring Rusty
Check your harmonic balancer for cracks in the rubber as it may need replacing and now is a perfect time to invest in that.
Oh and your missing the lower bolt on the right side of the block at the front to secure the fuel push rod. This area WILL seep and leak oil if you do not put the bolt back in.
Old 03-08-2016, 10:01 PM   #2873
Gregski
Gregski's Avatar
Re: Restoring Rusty
thanks I will and up until recently I didn't even realize there was rubber in the balancer
the bolt was removed during disassembly in order to slide that rod out allowing the cam to be removed
Old 03-08-2016, 10:36 PM   #2874
Gregski
Gregski's Avatar
Re: Restoring Rusty
Every time I try to get out - they pull me back in!
as I was spinning the engine block on that engine stand, I realized that it was sliding out of the rotating thingmajig, so I decided to use a C clamp from time to time to pull it back in, you know to prevent getting dead
so if you gots a similar stand, be careful you hear, engine blocks are expensive!
Old 03-08-2016, 10:40 PM   #2875
Gregski
Gregski's Avatar
Re: Restoring Rusty
time to do the passenger side set of cylinder banks 2-4-6-8 who do we appreciate?
I covered the other end with a rag, and kept the cylinders slightly pointed down, so when I shot brake cleaner in there to rinse them out, the debris would flow down hill and out the cylinder, seemed to work
