01-27-2016, 02:47 AM | #76 |
Re: 1970 K20 Restoration
http://www.billavista.com/Tech/Artic...ble/index.html this is good info for 14 bolts, got it from (JIM's 70GMC) in the all 4x4 tech section
01-27-2016, 10:34 AM | #77 | |
02-24-2016, 11:48 AM | #78 |
Picked the frame up from sandblast and powder coat a couple weeks ago. The powder coat shop drilled holes for my ORD steering box brace, powder coated brace, cleaned up a couple welds, filled and re-drilled bumper mount holes, straightened frame in rear, and blasted the exhaust manifolds. Really happy with how it turned out.
02-24-2016, 05:20 PM | #79 |
Nice work on the frame almost as nice as mine. just kidding. looking good.
02-24-2016, 10:59 PM | #80 |
Nice platform to start building it back up from!
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
02-28-2016, 01:46 PM | #81 |
Got the engine and transmission crossmembers bolted back on the frame yesterday. Id like to torque them down today. Anyone know the torque specs for frame crossmembers and miscellaneous frame bolts? Also, should I be using threadlocker on these bolts? Thanks
02-29-2016, 04:56 AM | #82 |
Don't know if your using 5/16, 3/8 or 7/16 but you should use Grade 8 bolts nuts and loc washers, note the zinc chromate finish, the bolts will have the 6 lines on the head of the bolt.
https://www.boltdepot.com/fastener-i...head-size.aspx
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-29-2016, 10:02 AM | #83 |
That frame sure is purdy! Nice job.
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! |
02-29-2016, 10:33 AM | #84 | |
03-01-2016, 01:20 PM | #85 |
Do you guys recommend I use threadlocker on the frame bolts? If so, what kind should I look for? Thanks
03-01-2016, 09:17 PM | #86 |
I used lock washers, or nylock nuts
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
03-02-2016, 02:26 AM | #87 |
yes, use nylock nuts
03-02-2016, 01:07 PM | #88 |
Here's my take on the subject, your buying grade 8 bolts, most Nyloc nuts are grad 5 or grade 2, plus the only part that lock's on the bolt is the nylon, i would try and find steel deformed thread lock nuts if your insistent on a loc nuts.
I would just use the loc washers and permanent loctite
03-03-2016, 04:27 PM | #89 |
If you use loctite, don't use the red permanent,it is PERMANENT! use the blue,it is good and you can get the nuts back off at a later time....
03-30-2016, 02:26 PM | #90 |
Any new progress on your truck lately?
03-30-2016, 08:25 PM | #91 |
Unfortunately I haven't got much done on the truck lately. Kind of at a stand still until I find some axles. I did go pick up some blue loctite, so hopefully I can get the frame bolts torqued down this weekend.
03-30-2016, 09:28 PM | #92 |
One of the First
Nick, did you check with Tom up in Phoenix? He usually has axles around his place.
Tom, http://67-72chevytrucks.com/vboard/member.php?u=966 I'll be in Sierra vista the first week in May, love to see the project.
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
03-31-2016, 08:20 PM | #93 | |
04-01-2016, 02:00 AM | #94 |
I guess you are still trying to find axles from a 71 or 72 K20? wish I was closer, I could move perches for you on a newer rearend
04-01-2016, 02:44 AM | #95 |
Yeah I'm still trying to find a 71-72 14 bolt rear and dana 44 front with discs. Most of the stuff I've found is 73+. Trying to make it a simple bolt in swap since I don't have any welding equipment or experience. I have a mechanic friend that could probably do it. If I can't find what I'm looking for I may just have to have him relocate spring perches/shock mounts.
04-28-2016, 05:41 PM | #96 |
Ok, so I'm ready to get this project moving again. Got a little sidetracked the last few months. Tom up in Phoenix has a 14 bolt rear with detroit locker and 10 bolt front with discs in 4.10 gears for $700. Came out of a 76. Anyone have any advice on the 10 bolt vs a d44?
Also I'm looking to buy a lift kit and get that installed on the frame. Would like new springs all around, probably 4" lift with 35's. Thought some of you might have advice on what companies to look into. Skyjacker, Tuff Country? Let me know what you would recommend. Not looking to do any hardcore wheeling, just occasional off-roading for hunting, etc. More concerned with ride quality than anything else. Last edited by K20rookie; 04-28-2016 at 05:50 PM. |
04-28-2016, 07:58 PM | #97 |
You could look into BDS for lift springs or SDtrucksprings.com also Offroad design for springs and shackles
05-06-2016, 04:20 PM | #98 |
Its a Truck Thing......
The truck I am working on has Rough Country suspension on it. Looks pretty good. You can swing by and check it out if you want. I also have all the parts I used for the disk upgrade.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
05-06-2016, 06:14 PM | #99 |
Right on, I'd like to check that out sometime. How much did the disc upgrade run you? Dana44 front I'm assuming?
05-06-2016, 11:40 PM | #100 | |
Truck will be here for another week so you might wanna come over soon, pm me and Ill shoot you the address. Smitty
