Old 03-30-2016, 10:24 PM   #1
CoachH
Speaker location options - '54
What options are there for speaker locations on a '54 chevy pickup? I'd like to put two 6x9's in the cab but not sure where. Under the seat seems like it will muffle the sound too much. I still have the tank behind the seat so it seems a little limited there.
Any ideas>
CoachH is offline   Reply With Quote
Old 03-30-2016, 10:31 PM   #2
53 292
53 292's Avatar
Re: Speaker location options - '54
If you get a quality set of 6.5 inch speakers and amp them, the kick panels is a great spot if you aim them up toward you a bit. You wouldn't really need rear speakers either.
53 292 is offline   Reply With Quote
Old 03-31-2016, 01:36 AM   #3
mr48chev
mr48chev's Avatar
There is plenty of room for a 6x9 in each rear corner of the cab My first step father kept his stash or Rainer beer in cab corner on his 54. You could build some boxes to fit each side and then put another speaker in the stock speaker location and done.
Side note I've got small boxes with six inch speakers on each kick panel of my 48. They are too handy as a foot rest though.
My ongoing truck projects:
Old 03-31-2016, 03:57 PM   #4
mobileortho
mobileortho's Avatar
Check out this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=645857
I bought a set from him and the look & work great!
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 03-31-2016, 04:11 PM   #5
wolffcub
wolffcub's Avatar
I installed the retro sound panels a few weeks ago. They sound nice even when being placed in the kick panel area. Your legs don't block the sounds and i even installed tweets just above the main speaker. The panels only needed 3/4" removed from the bottom to get them to just fit perfect. I will take a few better pics later today and post them up. I could not install the rear corner speakers as noted in the above post as the seat belt mechanism is located at the cab floor where they go. Already have the sub behind the seat and might one day install some more speakers behind the seat facing directly upward for a more immersive sound.
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber.
If it aint broke I still try to fix it!
wolffcub is offline   Reply With Quote
Old 03-31-2016, 05:30 PM   #6
Coach529
Coach529's Avatar
I have two 6 x 9's behind the seat and a 8" sub under the seat in a custom box. I have two 5" speakers in the stock location in the dash.
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 03-31-2016, 07:55 PM   #7
mobileortho
Forgot to mention the 5.25" Kickers & the 12" sub behind the passenger seat. Sounds awesome!
Robert C.
1950 3600
Old 03-31-2016, 08:26 PM   #8
58CameoAZ
MR48, do they still show the Rainer Beer commercial with the guy on the
Motorcycle when he has revving the throttle you would hear Rainer, Rainer,
and then when he took off and shifted you would hear Raineeeer... Beeeer!!!!
Funny Commercial back in the Day!
Allen
58CameoAZ is offline   Reply With Quote
Old 03-22-2021, 08:40 PM   #9
jocww
Where did you get the brackets for the speakers behind the grill. Do you like it up there or do you think the ones behind the seat would be enough?
My build a 49 5 window ls1 4l60e on a TCI chassis
http://67-72chevytrucks.com/vboard/s...d.php?t=754926
My travel blog
The Wong Winding Road-Adventures of The Chinese Cowboy
https://thewongwindingroad.blogspot.com/
jocww is offline   Reply With Quote
Old 03-22-2021, 11:44 PM   #10
vintovka
vintovka's Avatar
I hung 2 small speakers behind seat below rear windows. I made some L brackets to do it, Running wires was a bit Had i time i would have investigated using small bluetooth speakers.
vintovka is offline   Reply With Quote
Old 03-23-2021, 12:36 AM   #11
mr48chev
mr48chev's Avatar
Someone sells a speaker setup with a pair of speakers made to fit behind the speaker grill in the dash.
This outfit sells everything but 54 https://www.classiccarstereos.com/ch...ers-audio.html
I'll show you this for inspiraton to do your own but you would have to be crazy rich with a lack of common sense to buy one. https://www.classicindustries.com/pr...e403598ccb25ec
Simply meaning, you look at that, you get a piece of card stock about the right size and stick yourself up under the dash to make some impressions and make your own mount for a pair of the right size speakers at a quality level that suits your needs.
Old 03-23-2021, 11:41 PM   #12
jocww
The classic car stereos have so many options!!! Its crazy. I did put 2 Polk audio 6x9s in today. we tried under the seat and it sounded pretty good but couldnt hear it over freeway speeds. so we moved it to behind the seats right below the corner windows and could hear it better. Instead of vertical were going to do horizontal and at about 25 degree angle. Still will prob put a speaker in the stock location as well.
My travel blog
Old 04-04-2021, 01:01 PM   #13
jocww
Ended up getting the Hertz Deici. Hopefully they work well!
My travel blog
Old 04-08-2021, 10:38 AM   #14
jocww
The hertz sound great!!
My travel blog
Old 04-08-2021, 10:39 AM   #15
jocww
Pictures would help
My travel blog
Old 04-08-2021, 10:48 AM   #16
Tempest67
Tempest67's Avatar
I bent some sheet metal as I did not want to weld it to the outer cab wall.
also welded a piece of metal to dash for a pair of 3.5 inch speakers
Tempest67 is offline   Reply With Quote
Old 04-14-2021, 09:08 AM   #17
youngrodder
youngrodder's Avatar
Nicely done Tempest
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
1954, speakers, stereo
