Old 04-10-2016, 10:16 PM   #3526
Gregski
Gregski's Avatar
Re: Restoring Rusty
now then, where were we... ooh shinny
~ WE ~ MUST ~ MOUNT ~
Gregski is offline   Reply With Quote
Old 04-10-2016, 10:19 PM   #3527
Gregski
Gregski's Avatar
Re: Restoring Rusty
man, you're so lucky, the bolts on your truck were in that good of a shape, they are like brand new, oh wait... never mind
... and as I sat there on the ground thinking how pathetic I am not to even have a workbench, I tried to think of some positives of the situation and the only one I could come up with was that at least nothing can ever fall off the floor, ha ha, get it
yes I am a wire wheelin' mad man, but I can't bring myself to putting on rusty clay filled / wrapped nuts and bolts on the newly painted bits, this aint ROADKILL!!!
Old 04-10-2016, 10:23 PM   #3528
Gregski
Gregski's Avatar
Re: Restoring Rusty
and so we had to do the other side, and by the way these motor mounts are identical as far as I can tell, it's not like there be a right and a left one, they both have a cut off corner on the bottom but its in the same place, fits kinda nice on the dirver side and silly on the passenger, the cut off corner should be towards the rear of the vehicle seems like, not in front
Old 04-10-2016, 10:26 PM   #3529
Gregski
Gregski's Avatar
Re: Restoring Rusty
hmmm I wonder how the matching engine brackets will look on the block...
alright, and the other side... nice, though I wonder how these turned out Champagne instead of Cast Iron, glad I chose the other brand of paint for my engine, I like the Cast Iron look more better
Old 04-10-2016, 10:32 PM   #3530
Gregski
Gregski's Avatar
Re: Restoring Rusty
um Dummy you used the wrong bolts on the motor mounts and engine brackets, I mean why take all those pictures if you aint gonna refer to them
Ah, you know what they say, never time to do it right, but always time to do it over!
Oh, and by the way was I supposed to use some Special Sauce on these, cause I just screwed them in dry? Pretty clairvoyant if you ask me, now that they'll have to come out anyways.
Old 04-10-2016, 10:48 PM   #3531
enaberif
Re: Restoring Rusty
Dude get yourself a cheap bench grinder and a wire wheel for it. I got a free 6" bench grinder and tossed a wire wheel on it.
Then I just use some vice grips to hold bolts and crap to clean it up.
enaberif is offline   Reply With Quote
Old 04-10-2016, 11:59 PM   #3532
Gregski
Gregski's Avatar
Re: Restoring Rusty
funny thing is I got one, but it sucks I don't think it RPMs high enuff, its one of them orange Harbor Freight ones
Old 04-11-2016, 12:03 AM   #3533
Gregski
Gregski's Avatar
Re: Restoring Rusty
Re clocking the alternator, if you YouTube this procedure you will see guys doing it a couple different ways, some remove the back, some remove the front, I removed the back cause I wanted to see the brushes and the guts, the unit looks pretty tired, it may be the last old accessory on the truck, me having replaced everything else
I used the red WD40 straw trick to hold the brushes in while I slipped the housing back on
I think I rekeyed it from 9:00 o'clock to 3'clock unless it's upside down
Old 04-11-2016, 12:06 AM   #3534
Gregski
Gregski's Avatar
Re: Restoring Rusty
not sure this re clocking is going to fly in my book as it moved the hole for the mounting bracket away from where the nice hefty spacer bracket needs to go, and I am not a fan of the new simple pipe spaces
Old 04-11-2016, 12:10 AM   #3535
Gregski
Gregski's Avatar
Re: Restoring Rusty
here's just the before and after shots for comparison, see how the plug was on the left which would have been crammed against my engine and now its on the right, nice and away from all the action
and now on the engine
Old 04-11-2016, 12:13 AM   #3536
enaberif
Re: Restoring Rusty
Is there any reason you are wanting to use a low mount alternator bracket for? There are high mounts which put the alternator up MUCH further and much much easier to work on.
Old 04-11-2016, 12:17 AM   #3537
Gregski
Gregski's Avatar
Re: Restoring Rusty
I want to be able to see my engine, not the accessories, lol, plus I think it looks silly and ugly way up there, just a personal preference, going with form over function on this one, lower center of gravity, ha ha
Old 04-11-2016, 09:20 AM   #3538
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
The reason GM mounted them high is to get away from the exhaust.
You should probably put a metal heat shield between the alternator and the headers with some reflective heat shielding attached.
I'd put a metal heat shield with reflective heat shielding between the starter and the headers too. Make sure there's space between the starter and the shielding to allow some airflow...
Don't forget the torque brace between the starter tail and the block... The big Delco MT series and smaller Delco gear reduction PT series starters can break the mounting bolts, cast nose, and block pad just like they do on the diesels. Classic Industries sells em but... fabbing a brace should be fairly easy too.
Post #4 to the end of this thread... http://67-72chevytrucks.com/vboard/s...d.php?t=238063
More info in this thread specificaly braces for the 153 and 168 tooth flywheel 10MT starters. http://67-72chevytrucks.com/vboard/s...d.php?t=492532
How do you tell the difference between 153 tooth and 168 tooth starters? Look at the mounting bolts. 153 tooth are straight across 168 tooth are diagonal.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-11-2016, 11:32 AM   #3539
Oberon67
Re: Restoring Rusty
Originally Posted by Gregski View Post
Honestly, cause I'm not that smart, but I'm learning, and wouldn't that effect my gitty up, in other words if I put in highway gears in the diff to cruise at 75 MPH at about 2500 RPM wouldn't my truck be slower off the line, yet with an overdrive trans I get the best of both worlds a "quick" and I use that term loosely, LOL truck off the line and a happy truck on the freeway
Dunno. Yes, dropping the rear-end ratio alone will make all the gears relatively "higher," but that's comparing Muncie-before-the-change to Muncie-after-the-change... and I bet you weren't using that granny gear anyhow.
The only fair comparison to make would be Muncie-with-lower-rear-end-ratio vs. OD-tranny-with-current-rear-end-ratio. And that would require math. Acid test is working out the engine RPM to rear wheel ratio for all gears with both transmissions... that will tell the tale.
But you've already gone down the new-tranny road, so there's no point in working all that out now.
Oberon67 is offline   Reply With Quote
Old 04-11-2016, 02:48 PM   #3540
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
I think that transmission has a .73 OD ratio. If you are currently running a 3.42, final will be 2.49.
Jake Wade is offline   Reply With Quote
Old 04-11-2016, 07:30 PM   #3541
rusty76
rusty76's Avatar
Re: Restoring Rusty
Your doing a killer job. It's funny but I never had any heat soak problems between my starter and headers. Drove it with headers daily for years no trouble. As for the alternator I could see possibly some heat problems but I have no clue there.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-11-2016, 11:48 PM   #3542
Gregski
Gregski's Avatar
Re: Restoring Rusty
the core support rode shot gun from my buddy's barn as we raced home before the sun set after media blastin' all the hard to reach nooks and crannies
Old 04-11-2016, 11:52 PM   #3543
Gregski
Gregski's Avatar
Re: Restoring Rusty
the GM gods were not smiling on us tonight, it was one obstacle after another, I ran out of wire wheel, the wife interrupted to help her start the grill (the other kind) I said no, so they were having steak while I was having chicken nuggets...
Old 04-11-2016, 11:56 PM   #3544
Gregski
Gregski's Avatar
Re: Restoring Rusty
but I was determined to get this core support covered in primer tonight, so I put on my night vision goggles and primered by feel
Old 04-12-2016, 01:19 AM   #3545
Titomars
Titomars's Avatar
Re: Restoring Rusty
but I was determined to get this core support covered in primer tonight, so I put on my night vision goggles on and primered by feel
Hah! I love those night vision goggles.....
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 04-12-2016, 07:36 AM   #3546
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
Now if she had wanted you to help start the other grill, you probably would not have got that in primer. lol
Old 04-12-2016, 11:23 AM   #3547
Gregski
Gregski's Avatar
Re: Restoring Rusty
well hopefully by the end of the day all these parts will be green (ok technically all but the hood latch mechanism and its companion spring, those will be le black)
I counted a bakers dozen, what did you get?
apologies if some parts may be backwards or upside down in the photo, getting all of them to sit still for 30 seconds was like herding cats, plus the wind was a blowin the tarp up, things I do for you guys
Old 04-12-2016, 12:06 PM   #3548
flashed
Re: Restoring Rusty
I think you need to recount .........................................
Just kidding ,LOL .
flashed is offline   Reply With Quote
Old 04-12-2016, 01:55 PM   #3549
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: Restoring Rusty
Excellent!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 04-12-2016, 02:44 PM   #3550
WE B CRUZN
WE B CRUZN's Avatar
Re: Restoring Rusty
Love the post man, the way you explain in such detail with just the right amount of humour its perfect. Keep up the good work cant wait to see it when your done.
WE B CRUZN is offline   Reply With Quote
