04-20-2016, 03:17 PM | #1 |
Another Tire and Wheel Thread But Please Read!!
Folks,
please don't hate me! I believe I have read every rally wheel and tire selection thread on here. My 1985 has 7" rallies. I was planning on going with 255/60-15 front and 275/60-15 like several members here have but they've used 8" rallies. My truck will have a 4/6 drop. 2.5 spindles and drop springs, rear flip kit. Does anyone have pics of what those tires will look like on 7" wheels? The tire rack website says they will work but it would be great to see what it will actually look like. Thank you in advance.
Once a Marine, always a Marine! My (Her) 57 Build "Beverly" My 66 Build "Betty" My 85 C10 "Old Blue" Help Me Find "Old Blue" OLD BLUE PART II |
04-20-2016, 03:28 PM | #2 |
67-72 parts collector,…
Re: Another Tire and Wheel Thread But Please Read!!
I Personally think 255's are too wide for a 7" wheel.
I do think 7's and 8's look the best though. I normally run a 215/70 on a 15x7 wheel with a 275/60 on a 15x8 wheel on static dropped 73-87 trucks. I'm always looking at side wall height and overall tire height,... Along with trying to keep the WIDER front track width in check.
04-20-2016, 04:16 PM | #3 |
Diggin The SquareLife
why not do 15x8 in the front and 15x10 in the rear? that's what I ran on mine. and 255 is gonna be pretty wide for a 15x7 wheel
04-20-2016, 07:58 PM | #4 |
You can usually do what you want but when you put wide tires on narrow rims you wear out the center of your tread prematurely. Lower tire pressures can help but it is best to get the wider rims in the first place.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
04-21-2016, 02:07 PM | #5 |
Everyone seems to be worried bout the 255 on the front, that's not as big of an issue ad the 275 on the rear. You have got to get atleast an 8" wheel fir the rear
04-21-2016, 03:40 PM | #6 |
No sir. A 275 will fit a 7 inch wheel with no drama. Case in point, GM did it factory on the 454SS trucks. A seven inch wheel with a 275/60-15 tires.
04-21-2016, 05:46 PM | #7 |
anyone have any pictures, i appreciate everyone's input!
04-21-2016, 05:58 PM | #8 |
I have pics of my 15x8/15x10 if u wana see
04-21-2016, 06:03 PM | #9 |
04-21-2016, 07:23 PM | #10 |
15x8 in the front with a 255/60/15 rubbed in the front and 15x10 rear with a 275/60/15 the drop is 5/6
04-21-2016, 09:08 PM | #11 |
^^^nice!^^^
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
04-21-2016, 11:34 PM | #12 |
I'll gladly send you a pair of nice 15x8s in trade for two of your 15x7s. I'm about to do a similar setup on my 86 but planning on 235/70 or 225/70 on 15x7s up front and 275/60s on 8" wheels out back.
04-22-2016, 08:17 AM | #13 |
wow, I just saw this. That would be pretty cool. I will pm you.
04-22-2016, 08:18 AM | #14 |
Are there any issues with a 2.5 drop spindle (Mcgauhpys)sp.... and running a 15x7 or 15x8 wheel in the front?
04-22-2016, 08:19 AM | #15 |
this is a sweet truck BBC!!
04-22-2016, 10:28 AM | #16 | |
1973 C20, 350/350 |
04-22-2016, 10:47 AM | #17 |
Actually.... it's not "odd". Height & width were considered here along w/availability. Not all tires come in the exact sizes desired & not all wheels are easily obtained in the sizes needed vs cost. It's a budget compromise that works quite well.
04-22-2016, 10:57 AM | #18 | |
Are you sure they aren't the 15x6.5" van rallys? they also have a 4" bs.
04-22-2016, 10:59 AM | #19 |
This is my old squarebody burb.
7 and 8 inch rallys. 215/70 and 275/60 tires.
04-22-2016, 12:44 PM | #20 | |
Not saying there's anything wrong with it, just that there's a significant difference in how the two look and feel.
1973 C20, 350/350 |
04-22-2016, 01:50 PM | #21 |
go with western chassis 2.5" drop spindle and you wont have to grind anything if you use 15x8 in the front
04-22-2016, 01:51 PM | #22 |
thanks!!!!! I got all parts to bag it to lay frame.
04-22-2016, 01:56 PM | #23 | |
I know for sure my spare is a 15x7, that stamping was easy to see.
