Old 04-25-2016, 12:30 AM   #3701
Gregski
Gregski's Avatar
Re: Restoring Rusty
alright, and it all must come off now, we need at least the two brackets by the headlights, so time to drill those holes
we used the long lost art of self tappin' screws (pronounced: lazy) to secure them, when they fall off we'll add some nuts to those bolts, ha ha
and passenger side done
Gregski is offline   Reply With Quote
Old 04-25-2016, 12:31 AM   #3702
Gregski
Gregski's Avatar
Re: Restoring Rusty
time to drill the driver side... and done!
Old 04-25-2016, 12:37 AM   #3703
Gregski
Gregski's Avatar
Re: Restoring Rusty
What's this, more parts, at this stage in the game?
Yup, after Clips and Fasteners dot com let me down (see small green box below) I had to order the right white nylon grille nuts
Funny thing is, I paid to get a box of the wrong ones, than I paid to get six of the right ones, and meanwhile since I can not use the '73 brackets, all I need is 2 of them and out of the six old ones, two are perfectly fine, ha ha
Classic Parts comes through again! Not to be confused with Classic Industries
Old 04-25-2016, 12:42 AM   #3704
Gregski
Gregski's Avatar
Re: Restoring Rusty
and so here's the '73 grille mounted up to the '79 core support, and supported with 2 screws in the middle bracket and 2 additional ones (one at each end by the headlights) good enuff fer me, IT'S A TRUCK!!!
and that's all the updates for tonight
Old 04-25-2016, 08:39 PM   #3705
enaberif
Re: Restoring Rusty
Trying to figure out what your doing then realize you have a GMC not a Chevy lol
enaberif is offline   Reply With Quote
Old 04-25-2016, 09:30 PM   #3706
Gregski
Gregski's Avatar
Re: Restoring Rusty
Great, so not only is there a difference between early seventies trucks (73-74) and late ones (75-79ish) but now you are telling me there is a difference between Chebbys and GMCs, ha ha ~ man I should've known
oh well my grill mounted fine,
FYI: I did rely on these LMC diagrams for a reference when buying the donor '79 core support and they claim the 73-80 core supports be the same
Old 04-25-2016, 09:47 PM   #3707
enaberif
Re: Restoring Rusty
Yeah its weird there was a few cross over years and I think 77-78 is when they switched from front released to interior release hoods as well which can screw up people.
Old 04-25-2016, 09:58 PM   #3708
79sierra
79sierra's Avatar
Re: Restoring Rusty
No difference between GMC and Chevy hardware they all mount the same. Your grill should be fine the way you mounted it, it is supported in the middle and on the ends.
79sierra is offline   Reply With Quote
Old 04-25-2016, 10:34 PM   #3709
enaberif
Re: Restoring Rusty
No actually they don't. There is drastic changes in how grilles mount to the front of these trucks. I discovered this myself when I swapped from my 74 grille to a 76 chevy grille.
Even the center mount was different between the two because of the depth of the grilles.
Old 04-25-2016, 11:41 PM   #3710
Gregski
Gregski's Avatar
Re: Restoring Rusty
there is a difference between year differences ie 73-74 vs 75-78
~ but ~
there is no difference between Chevy and GMC of the same year is what we all are trying to say?
Old 04-25-2016, 11:45 PM   #3711
Gregski
Gregski's Avatar
Re: Restoring Rusty
the 1983 El Camino 61" long drive shaft is ready to be taken to the Drive Line Shop to be shortened 2 1/4 inches (that factors in that my truck be lowered)
taking the "nice" car so had it wrapped like a salami
fingers crossed maidens
Old 04-26-2016, 01:16 AM   #3712
79sierra
79sierra's Avatar
Re: Restoring Rusty
~ but ~
Yes!
Old 04-26-2016, 06:40 AM   #3713
LeesTruk
Re: Restoring Rusty
Hey Gregski, check for clearance of the center bearing mounting bracket when you install your one-piece driveshaft. You may find that the bracket and shaft will become intimate under spring compression from bumps or load. And seeing as how you've raised the rear axle in relation to the frame, clearance becomes even more critical
LeesTruk is offline   Reply With Quote
Old 04-26-2016, 08:23 PM   #3714
deejaaa1
Re: Restoring Rusty
you can do the shaft yourself. it's not rocket surgery. just make sure the yokes are opposed.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 04-27-2016, 12:11 AM   #3715
Gregski
Gregski's Avatar
Re: Restoring Rusty
will do, thanks for the tip, though I removed the carrier bearing center bracket with the two piece drive shaft leaving only the cross member there, so I should be ok
Old 04-27-2016, 07:48 AM   #3716
hatzie
Moderator
hatzie's Avatar
Re: Restoring Rusty
the drive side headlight wiring harness section proved trickier as it is the middle section of the daisy chain run
I'm gonna have to come back, and cut ans splice the headlight plug 3 inches over so it's not that tight when I plug it in (I am currently out of butt connectors)
Don't use insulated Butt Conectors. They will come loose and cause all kinds of grief.
Solder and Heatshrink the connection. I generally use "Marine Grade"Adhesive Lined heat shrink Adhesive Lined heat shrink on connections that will be exposed like these.
Radio Shack 60/40 Sn/Pb rosin core solder is generally pretty smoky. I use Kester 44 .80mm 66/44 Sn/Pb Kester 44 .80mm 66/44 Sn/Pb and MG Chemicals Liquid Flux MG Chemicals Liquid Flux on old wires. <---That 1lb spool and tiny bottle is a lifetime supply. You can wipe off any excess flux with Ispropyl Alcohol.
Use a wet sponge to clean the tip. It'll clean off the corrosive burnt flux leavins and oxidized lead and tin. You won't have to use tip-tinner cleaner tip-tinner cleaner as often, or maybe at all, if you keep the crud off the tip by wiping it often.
A third hand tool can be built with ROMEX and alligator clips... See the first few minutes of the last video. Eric uses a soldering gun. I don't recommend a soldering gun it's way to difficult to control the heat so it's way too easy to burn the wire jackets off.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-30-2016, 10:54 AM   #3717
Gregski
Gregski's Avatar
Re: Restoring Rusty
so took another Thursday off and drove up to Chico California to hunt in their Pick N Pull yard, came across a 1977 truck so decided to yank some of the grille brackets, just to have them really, at the time I didn't realize there was a difference between 77 and 79 ones, so here's a little style recap:
1973-74 (my truck)
1975-78 (this truck in the yard)
1979-80 (my new donor core support)
Old 04-30-2016, 11:02 AM   #3718
Gregski
Gregski's Avatar
Re: Restoring Rusty
anyway I pulled the stuff I needed plus a couple other do dads and the total came out to be $120 BUCKS!!! I kid you not for a bunch of brackets, the kid wanted to charge me $11 bucks per bracket, so I put them all back, not ashamed to admit it, what a rip off
he even wanted $11 bucks for that round plastic air breather thing, then when I pointed it out to him he changed it to $4 bucks
so $22 for pair of side grille brackets
$11 for the center bracket plus another $14 for the attached hood latch assembly
$11 for the plastic round thing (till he changed it)
etc.
Old 04-30-2016, 11:07 AM   #3719
Gregski
Gregski's Avatar
Re: Restoring Rusty
they wanted another $22 bucks for these automatic transmission crossmember support brackets, I have the big bar already just wanted these to complete the ensemble, I'm just funny that way (a completionist I've been called)
I passed on these too, I can get them for like $3 bucks each at my local yards, where the cashiers are properly trained, I mean I am not trying to steal them I am just willing to pay what they are worth
the way I see it, metal is cheap, they can get .11 cents total for recycling all this metal, or they can sell it to me, but at 10,000% markup that's ridiculous
Old 04-30-2016, 11:14 AM   #3720
Gregski
Gregski's Avatar
Re: Restoring Rusty
... which brings us to today, Saturday March 61st, 2016
~ Captain's Log ~
it's been a long month of March (ha ha), but today marks the last day of what we have dubbed March Madness, in literally 1 hour I am going to pick up the shortened drive shaft, the last peace of the puzzle, the last ingredient in this Top End / Overdrive Transmission Upgrade concoction that has become so much more, new exhaust, new(ish) core support, blacked out grille, relocated alternator, new waster pump, a HURST shifter, etc...
I am very excited and can't wait to take Rusty around the block for the first time
Old 04-30-2016, 12:46 PM   #3721
rusty76
rusty76's Avatar
Re: Restoring Rusty
Looking forward to it myself along with the multitudes of others on here.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-30-2016, 03:13 PM   #3722
Gregski
Gregski's Avatar
Re: Restoring Rusty
I have no idea why they painted it silver, but they did, so something had to be done about that, and judging from the quality of the paint job, I'm sure their surface prep didn't go beyond, shake can, LOL
naturally today was the windiest day of the decade so I had to paint the shaft inside the garage
Old 04-30-2016, 03:38 PM   #3723
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: Restoring Rusty
4K tv! Wow thats the most expensive painting box I've ever seen!
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 04-30-2016, 05:35 PM   #3724
Gregski
Gregski's Avatar
Re: Restoring Rusty
~ Test Drive = SUCCESS !!! ~
Old 04-30-2016, 05:38 PM   #3725
Gregski
Gregski's Avatar
Re: Restoring Rusty
... and here's a clever way to show off the blacked out front end without admittin' you haven't put the hood back on yet, ha ha
