04-27-2016, 08:23 PM | #176 |
Re: DBW Gas Pedal Adpater bracket for truck/suv pedal
Great product! I've only got one issue. The throttle is a good inch above my brake pedal, but my brake pedal is not on the rest. My question is with power brakes does the brake pedal rest against the stop?
04-27-2016, 09:04 PM | #177 |
How far off of the stop is it? I think it should rest again the stop regardless of power or not, at least all of mine have.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-27-2016, 10:00 PM | #178 |
It's got a good inch before it touches the stop. Do you think there is that much adjustment in the rod?
04-30-2016, 03:25 PM | #179 |
Looking back through this thread most of the pictures show the brake pedal higher. Here is one a little furthur back in this thread shows what mine looks like.
04-30-2016, 03:36 PM | #180 |
Here is what mine looks like. I took it loose & tried to adjust it back some. I made about 5 full turns and the end fell off in my hand. So it looks like there isn't enough adjustment there to make it come close to touching the stop. You can see where I cut the pedal & tried to make it work then welded it back.
05-02-2016, 08:19 AM | #181 | |
05-02-2016, 08:54 PM | #182 |
Hi Rob.
I bought your pedal bracket a while back and have gotten around to installing it today. It seems that the pattern for mounting to the firewall is off. Assuming the orientation in the picture is correct (other than the picture is 90 degrees counterclockwise), my actual holes in the truck are 1.50 between the top holes and 2.00 to the bottom one. Not sure whats up but, no big deal, I'll take it to work tomorrow and just slot the holes. |
05-03-2016, 11:30 AM | #183 | |
Rob
05-03-2016, 06:11 PM | #184 |
No problem. Strange that my 71 would have a different pattern, but oh well. It will still save me a bunch of time and fabrication!
05-04-2016, 02:23 PM | #185 | |
Rob
05-22-2016, 05:46 PM | #186 |
Do you have any brackets available? I need one.
Thanks! |
05-22-2016, 06:41 PM | #187 |
Yes I do! Paypal info in first post. Thanks!
05-22-2016, 06:55 PM | #188 |
Payment on the way. Thank you.
05-24-2016, 09:09 AM | #189 |
05-25-2016, 03:50 PM | #190 |
I'm fitting my DBW gas pedal in my AD. It's the same as in the pic. It is comfortable to have the gas pedal ahead of the brake pedal. Mines looking the same in order to get full travel.
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 |
08-27-2016, 09:56 PM | #191 |
bump!
09-15-2016, 08:12 PM | #192 |
Sir, I would like to order a pedal bracket please.
Thanks Chris |
09-15-2016, 08:15 PM | #193 | |
09-15-2016, 08:25 PM | #194 |
Money sent...thanks
09-15-2016, 09:39 PM | #195 |
Thank you! It will ship via USPS tomorrow. Take care.
Rob
09-15-2016, 11:48 PM | #196 |
Man, do you have ANY way to make a 97-04 Corvette pedal to work in a 66 C10?
My mother is a recent cancer survivor and this truck build is for her |
09-16-2016, 09:02 AM | #197 |
Please post pictures of the pedal and the firewall.
10-19-2016, 09:33 PM | #198 |
Hey bud.. I FINALLY got around to xtrying to get the pedal in. I had cherry insulation. Kinda hurt to cut it! Lol
Anyways has anyone mentioned havng to notch the bracket for the taillight plug? No biggie just wanted to mention it. Thanks again rob. Early production 67.
1967custom |
10-20-2016, 09:00 AM | #199 | |
10-21-2016, 10:59 AM | #200 |
i made the cut larger than it had to be but after i did that it worked perfect. i wouldnt doubt the plug location being just a bit lower on a 67.
1967custom |
