Roll bar mounting
After years of trying to find a roll bar for my blazer I finally got one. Obviously after cleaning it up I'll be installing it. It's the type that the rear down tubes mount right behind the wheel well. In fact the very end of the mounting plate is turned up slightly to match the angle of the wheel well. I plan to use the mounting plates as templates to drill the holes in the bed and a backing plate. One thing I was unsure of though is how to trim the carpet around the newly installed bar in a way that looks neat? My truck is very original and nice and I don't want it to look like a hack job with fraying carpet all around. Other than having the edges bound (p.i.a.) does anyone have any ideas or know what a dealer install with this type of set up looked like? Thanks in advance for any suggestions.
Re: Roll bar mounting
My blazer didnt have carpet in it when I bought it, it had the vinyl mat. Its got carpet in it now. When I took the roll bat out to do some work on it, the mat just had holes in it to match the bolt pattern of the bar mount. I would think they did the same for the carpet..
Huh...I hadn't considered going right over the carpet. Can anyone confirm this is the way to go? Anyone with a picture of how theirs mounts would be really appreciated.
I installed mine right over the carpet. Looks good and know worries of the carpet fraying. Try to get a pic for you.
A picture would be much appreciated if you can find the time!
![]() Join Date: Jun 2012
I put mine in on top of the carpet. Just use a cheapo soldering iron to make the holes so the carpet does not fray.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
I'm on top too.
72 CST 4x4 Blazer, 1 ton 70 SS Chevelle, L78, 396 Everytime someone calls your Blazer a Bronco, God kills a kitten. |
Yours sounds like maybe a Smitty built by your description of how it mounts behind the wheel wells. I like that style but haven't found one yet. May just have to get one made up.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
I just had it sandblasted and I primed it. Hopefully this weekend I'll get some paint on it. I was going to powder coat it but it's probably going to be covered anyway so I figured I'd save some money and just spray it. When its installed I'll post some pictures. Thanks to those who replied and posted pics, that was a big help.
![]() Join Date: Mar 2004
warbucket - I like the front cage on your rig. I want one now.
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
Thank you, I scored it on Craigslist for $200.00.
