Old 05-13-2016, 12:25 PM   #51
RodsGreen10
RodsGreen10's Avatar
Re: 85 GMC Sierra "Scarlett"
Originally Posted by N2TRUX View Post
Thanks for sharing. I had a set on the 84 Sierra I just sold and they seemed to do much better than stock.
Its sad, but I tried working with Jegs in the past and failed. I spent an hour on the phone arguing with them over a price match that they said didnt exist. Even though I sent them the link to the page, they refused to honor it. No more Jegs for me.
Yes they do perform a little better. But the looks is worth the price of admission. I just use the Jegs online price match they have so I don't have to deal with idiots.
RodsGreen10 is offline   Reply With Quote
Old 05-13-2016, 12:44 PM   #52
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by RodsGreen10 View Post
Yes they do perform a little better. But the looks is worth the price of admission. .....
They do look good peaking through an open wheel. The color is a close match to the GMC logo, so they get bonus points for that.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
"Refining Sierra"
Old 05-13-2016, 03:13 PM   #53
funkatation
Jegs has been great for me but I also just use the online link. I've only had them come back once and ask for the link again to confirm. I've probably spent 10k with them over the last year and they have been solid. Summit has been ok too but their price match isn't as easy.
funkatation is offline   Reply With Quote
Old 05-15-2016, 07:20 AM   #54
N2TRUX
Happy to be here
N2TRUX's Avatar
I took a break from shop time and hit a local swap meet Saturday morning. This one can be great source for hard to find parts. Unfortunately this time it was not.
I blasted through looking for anything I "needed" and passed on several items I "wanted"..
I found a taillight dealer and made my deal for the day and we left. I was pleased that I got a decent deal on something I really needed.
I knew the taillights were faded and yellowed. I didn't realize how much till I compared the new set. I had planned to reuse the trim, but they had more scratches and dings than I realized.
Articles-
"Refining Sierra"
Old 05-15-2016, 07:32 AM   #55
N2TRUX
Happy to be here
N2TRUX's Avatar
I pulled the old lenses and saw that the inner reflectors were faded too. They were mounted with a variety of miss matched screws too.
I scuffed and painted the reflectors a bright silver. A few minutes in my spare screw file and I hade a matching set.
Articles-
"Refining Sierra"
Old 05-15-2016, 07:36 AM   #56
N2TRUX
Happy to be here
N2TRUX's Avatar
No worries, I will dust off my hammer and dolly skills and see what I can do. The new set has your typical thin, poorly stamped ill fitting trim.
After an hour of gentle finessing dents, and sanding scratches they were ready for polish.
Another half hour spent on the Powerball, and they were taking shape. I found a set of matching stainless screws and mounted one side. It looked great and made me realize how dull the tailgate band was. .
Articles-
"Refining Sierra"
Old 05-15-2016, 07:44 AM   #57
N2TRUX
Happy to be here
N2TRUX's Avatar
I wish this segment had a happy ending but it does not. It wasn't until I tried to mount the left assembly that I realized I had two rights and no left. GRRRRR!
The vendor had all his taillights nicely displayed with one lens out of the box and the other still wrapped in plastic inside. I verified that the second lens wasn't scratched or broken but "assumed" it was a left side. GRRRR!
Since it's not worth the time or tolls to drive back to Conroe, I will just buy one locally. Another life lesson learned.
Update! I found a lens at the local O'riellys and swapped my polished trim. We are good to go now.
Articles-
"Refining Sierra"
Old 05-15-2016, 07:38 PM   #58
N2TRUX
Happy to be here
N2TRUX's Avatar
With the taillight catastrophe resolved it was time to get the rear suspension back together. We started with the replacing the wheel cylinders. As mentioned previously, one was wet so I decided to replace both. Good call because the second one was seeping too.
Fortunately the lines came off with no issues, and after a thorough clean up we installed the freshly painted cylinders. A quick scuff and shoot of the axle flange and I could put the drums back on.
Articles-
"Refining Sierra"
Old 05-15-2016, 07:53 PM   #59
N2TRUX
Happy to be here
N2TRUX's Avatar
All of the suspension components that could be removed were bead blasted and painted. The stripped and broken U bolts were replaced with a fresh set, along with new flat and lock washers were installed.
I really like the clean look of stainless button heads, so the differential cover got a polished set. We installed a new gasket and bolted everything back together. A fresh fill of #90 gear oil, and the brakes were bled. We wiped everything down and checked for leaks. She was ready to set back on the ground for now.
Ignore the bent up brake lines. Those will be straightened and painted soon.
Articles-
"Refining Sierra"
Old 05-15-2016, 08:02 PM   #60
lolife99
67-72 parts collector,…
lolife99's Avatar
Great progress on your new project!
I'm a firm believer in using anit-seize compound on double flare brake line fittings.
It allows things to come apart so much easier the next time,...
Keith
Convert to disc brakes.
Old 05-16-2016, 10:21 AM   #61
aggie91
I'm just glad to be here!
aggie91's Avatar
More great progress. I just need to get past this bad luck around here and get back to getting my own square soon.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-16-2016, 11:43 AM   #62
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks Keith. We keep a can of anti-seize and a brush handy. I use it quite a bit.
No kidding. I cant believe how much bad luck you have had with the squares in your family.
Articles-
"Refining Sierra"
Old 05-17-2016, 12:53 PM   #63
GAc10boy
GAc10boy's Avatar
I'm in. Love the attention to detail (per usual) and the overall look of the truck. Two-tone scheme is very nice!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 05-17-2016, 11:00 PM   #64
N2TRUX
Happy to be here
N2TRUX's Avatar
While under the truck working on the rear axle I spent some time looking things over. I knew there was no rust on the sheetmetal, but the inside of the frame rails werent as clean as the outside. After some research, I decided to clean up the rails and treat them with Rust-Mort to eliminate any future concern. I shopped around and once again ended up on the Summit Racing website.
I have discovered Summit Racing is like a crack addiction. They reel you in with the promise of free shipping, and all you have to do is spend 99.00. I could have just bought what I needed and paid the shipping, but I was only 72.90 away from a free ride. I went to my order history from my last build and soon had enough items to save shipping costs. Crack I tell ya, just like crack.
Articles-
"Refining Sierra"
Old 05-17-2016, 11:10 PM   #65
N2TRUX
Happy to be here
N2TRUX's Avatar
Scarlett didn't come equipped with a sway bar, so I have been looking for one. I finally connected with a guy selling some parts on Facebook that had what I needed. He had a complete front frame section and didn't need the sway bar. I picked up a smoking deal on the package. All it needs is a clean up and new bushings.
Articles-
"Refining Sierra"
Old 05-18-2016, 12:04 AM   #66
UKNOWME
UKNOWME's Avatar
Ahhhh, the start to another Summit order!
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 05-18-2016, 11:24 AM   #67
GAc10boy
GAc10boy's Avatar
Gets me every time
- Robbie
Old 05-18-2016, 12:04 PM   #68
Old 05-18-2016, 12:13 PM   #69
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Chaplain View Post
First step involves acknowledging the problem.
Hi, my name is Ken and I'm a Summit racing junkie.
Actually I can get them locally, so I'm safe for now.
Originally Posted by GAc10boy View Post
Gets me every time
I know, right? Its like a game challenge that you just cant resist. Its a good thing they dont have a high score for the week, I would be broke.
Articles-
"Refining Sierra"
Old 05-19-2016, 04:44 PM   #70
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Its a good thing they dont have a high score for the week, I would be broke.[/QUOTE]
LMAO
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 05-19-2016, 05:53 PM   #71
Claytona08
Claytona08's Avatar
Great work on all your projects Ken. Just spent the last couple hours checking them out. Beautiful trucks and great attention to detail.
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 05-19-2016, 10:19 PM   #72
N2TRUX
Happy to be here
N2TRUX's Avatar
LMAO I wish I was kiiding, but you know I'm not
Thanks for the kind words. I'm not sure if my OCD is a blessing or a curse.
Articles-
"Refining Sierra"
Old 05-19-2016, 10:29 PM   #73
Matt Man
Matt Man's Avatar
HAHA I had the same thought in my head as I was ordering my spindle bearings for my k10, I was only 60$ away from free shipping and was thinking what else do I need? But I resisted the temptation.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 05-19-2016, 10:33 PM   #74
N2TRUX
Happy to be here
N2TRUX's Avatar
Man, I though Amazon Prime was quick. I ordered my last batch of parts from Summit on Tuesday morning. They were all in stock, and shipped out of the Georgia warehouse that day. Its Thursday, and they were under my port-cache today when I got home. Now thats what I call service.
I new I didnt have enough time to work on clearing a spot to pull the bed, so I decided to take on a small task instead. When I picked up the sway bar, the seller used a sawzall to cut a section of the old frame out under the sway bar clamp stands. For those that dont know, the clamp stands are rivited to the frame.
Working with such a small piece of frame, I didnt think I could secure in my vise well enough to use my air chisel to remove the rivets, so I decided to drill them instead. I used a small bit for a pilot, then my Milwakee Uni-Bit set to take the rest out. If you dont own a good quality Uni-bit (Step-bit) you should invest in one. With the aid of some drilling lubricant, the bits cut through the rivets in short order.
The bolts were mismatched, so I dug through my spare bolt bin to find a matching set of bolts, washers, and nuts. Then I spent some quality time at the blasting cabinet getting all the rust and grunge off. They are all blasted clean, and ready for a coat of paint.
Sorry, no pics tonight. I'll get some in the morning when I spray the color on.
Articles-
"Refining Sierra"
Old 05-20-2016, 10:27 AM   #75
GAc10boy
GAc10boy's Avatar
Summit is truly amazing. Sounds like good progress!
- Robbie
