70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Need Name or Part Number
I'm trying to keep my truck as original as possible including the emissions stuff. My truck is a 72 with 35/350 and factory A/C. On the passenger side there is a hose that goes form the Air Cleaner to the valve cover and I want to replace the "thing" that goes in to the valve cover. I know it has arcs in it but can't sem to find a listing for it and do not know the proper name of it. I would like to replace it, does anyone know where to buy one or have name and/or part number for it?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Need Name or Part Number
If my memory serves me correctly it's called a spark arrester.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
PCV valve?
It is called a flame arrestor.
![]() Join Date: Sep 2015
whats in the valve cover on the other side generally there is a grommet and then the PCV valve in the cover while yours appears to simple be jammed into the valve cover...
I have never seen or heard of a flame arrestor on a vehicle except for a race vehicles air cleaner being made of flame resistant materials but could be wrong here Here is an image of a simple PCV Valve OEM numbers could be as follows 25040145, 25040148, 25043355 ![]()
"Orange Crush" |
#6 | |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Is this it?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
![]() Join Date: May 2010
As stated above, it's a flame arrestor. It is not considered to be a normal service replacement item. Why do you feel you need to replace it? My 1969 service manual recommends this:
"Remove the flame arrestor and wash in solvent, then dry with compressed air." I believe as long as it permits the free flow of air, all is well. |
This is it..At the bottom of the hose.
#10 | |
Thanks, and that is why I probably cant find one. I didn't realize they lasted the life of the vehicle. I just thought it'd plug up over 40 years and thought its time to replace. I guess i should get a Service Manual for the truck.
Okay did some more looking through catalogs and for 72 400 BBC and 350 SBC I found a flame arrestor part number 6262992 it's not shown in a diagram though or else I would have scanned one in for us
"Orange Crush" |
I'm still running my original (119,000+ miles) as long as I can blow through it without restriction, I'm happy. I've never cleaned it that I can recall.
Go Pack Go!
So, does the flame arrestor have a one way valve inside to prevent possible backfire flame from entering inside the valve cover?
No. It's free flowing both directions. It appears to have metal "louvers" (probably a series of them) which apparently block a backfire from entering the valve cover. It's visible from the valve cover end. I've never looked at one from the carb end. Some other Chevys (Corvettes, etc.) used a screen-like dome filled with a metal mesh which I believe was inside the air cleaner.
#15 |
Go Pack Go!
#16 | |
ST_330_72_1972_Chevrolet_Truck_10-30_Chassis_Service_Manual Oops... that didn't work. Here's the link to the thread. http://67-72chevytrucks.com/vboard/s....php?p=5781194 |
#17 |
This is what it looks like at the valve cover end.
#18 |
Here's some basic patent info. Not much use though.
http://ip.com/pat/US3287094 EDIT: Tis time to beat the dead horse... http://www.freepatentsonline.com/3287094.pdf Last edited by FirstOwner69; 05-18-2016 at 04:39 PM. |
#19 |
OK, for those wanting a new one. Gm Part #3857476 (discontinued).
http://www.ebay.com/itm/Corvette-NOS...3D170965175853 http://www.ebay.com/itm/GM-NOS-1964-...-/170965175853 http://www.ebay.com/itm/NOS-Genuine-...dWnPjo&vxp=mtr http://www.ebay.com/itm/1964-1965-Co...VW7u0x&vxp=mtr http://www.ebay.com/itm/1964-1967-Co...tW6XI9&vxp=mtr http://www.ebay.com/itm/NOS-Corvette...tWhL2C&vxp=mtr Last edited by FirstOwner69; 05-18-2016 at 05:12 PM. |
#20 |
I appreciate all your help but t 49 and 55.00 US diallers plus shipping and what the Government takes, I pulled mine today and could blow through it so I'll keep it for now.
#21 |
#22 |
Ok...so my memory isn't so good.....flame arrester not a spark arrester......lol
#23 |
#24 |
Mr. Cheyenne
![]() ![]() Join Date: Jun 2020
So my spark arrester was hardly letting any air through - it was serious caked with old oil. I have it about 90~95% opened up now I wasn't able to get it off the hose and I ended up cracking it (at the 90 degree bend).
Anyone got a lead on the hoses?
Richard '72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT SBC 350 | TH350 | LWB | AC | Buddy Seats Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim |
#25 |
![]() Join Date: Apr 2016
Grumpy old man gave a link to a marine engine supply here in this post:
https://67-72chevytrucks.com/vboard/...05#post8858005 There is also discussion on that thread and some other threads about using heater hoses but I'm not sure I would take that approach because it would not be fuel and oil resistant material (EPDM rubber that Gates part #28475 is made of is not fuel and oil resistant). |
