Old 05-22-2016, 11:26 AM   #176
TJ's Chevy
TJ's Chevy's Avatar
Re: 1964 GMC 1500 "crustine" semi- build.
And here is a comparison of the 3 manifolds.
Stock, 4 down to 2 adapter, and the true manifold.
Surprised at how clean the plugs were to. All that fuel and limited air and burning nice an clean with stock points and a hot coil. lol! Really hoping the extra air will help. It should. Later guys! More updates to come!
Old 05-22-2016, 12:36 PM   #177
rusty76
rusty76's Avatar
Cool
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-22-2016, 12:39 PM   #178
rusty76
rusty76's Avatar
Can you explain to me what a magnum intake is? What it came off of and so on. Pretty cool intake.
My build thread
Crossmembers CC
Old 05-22-2016, 01:03 PM   #179
Ta2Don
Ta2Don's Avatar
Awesome job Brotha!!!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 05-22-2016, 01:34 PM   #180
62stepside longbox
62stepside longbox's Avatar
Wow that looks really good, can't wait for a video with it on crustine
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 05-22-2016, 01:57 PM   #181
TJ's Chevy
TJ's Chevy's Avatar
Thanks Rusty! A magnum intake has the larger ports and used the large base two barrel whereas the non-magnum had baffles and a small base two barrel. Magnum intakes would have been on Magnum engines...351M, 401, 478 and others.
Thanks brotha!
Me to!!! Heading out right now to finish it up!
Old 05-22-2016, 07:30 PM   #182
rusty76
rusty76's Avatar
Ok. So what did these magnum engines come in. You've got my curiosity up. Lol. Thanks
My build thread
Crossmembers CC
Old 05-22-2016, 08:18 PM   #183
Classic v6 GMC's
Classic v6 GMC's's Avatar
Nice job on the intake!! x2 on the video.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 05-22-2016, 08:23 PM   #184
TJ's Chevy
TJ's Chevy's Avatar
The 351M was available in 2500's and up I believe. Then the larger engines like the 401 and 478 would be available in the 4500 and up. Here's a link to the 6066 GMC site...Lot's of info there!
www.6066gmcguy.com/EngineData.html
Old 05-22-2016, 08:24 PM   #185
TJ's Chevy
TJ's Chevy's Avatar
Thanks man!
Old 05-22-2016, 08:44 PM   #186
TJ's Chevy
TJ's Chevy's Avatar
Well guys, Installed everything today...and aside from a few vacuum leaks to fix...Man..I say MAN did opening the plenum make an improvement!!! Sheesh! Has a couple leaks around the intake manifold gaskets so new ones will be here Tuesday. Also has a tiny one between the adapter and manifold. So Wednesday I'm planning on installing the new gaskets and re-sealing it all up. Should run like a champ then! Idling a bit rough and back fires a tad when slowing down which is what it never did before. So, that all should be remedied soon I hope! Later guys! Hope ya'all had a great weekend! Will be making a video soon.
Old 05-22-2016, 09:22 PM   #187
Very nice work on the manifold TJ. You may have uncorked the BEAST!!
Old 05-22-2016, 10:40 PM   #188
TJ's Chevy
TJ's Chevy's Avatar
Thanks Palf! She's a dern good runner that's fer sure! Just gotta work out them bugs!
Old 05-23-2016, 07:15 PM   #189
beanstock
beanstock's Avatar
Originally Posted by TJ's Chevy View Post
Yeah, I'm think of either the 500 2 barrel or a quadra jet 4 barrel. I meant that the engine is not original....we ran the numbers and came up with a 67 or later model engine.
Mine is a 64 GMC also and has a 305E also and I know it's original cause my dad bought brand new and gave it to me a few years back.
I only drive a Fix Or Repair Daily when I have to, Otherwise it's a 1964 GMC 4X4 or 1989 C3500 Silverado PROPANE POWERED
beanstock is offline   Reply With Quote
Old 05-23-2016, 08:46 PM   #190
TJ's Chevy
TJ's Chevy's Avatar
Yep! One Easy way to tell is on the back of the intake. There will be a month-day-year stamp there telling when the engine was made. In my case..1967 telling me an engine swap was done...which is cool cause mine is the more powerful one. lol!
Old 05-24-2016, 01:06 AM   #191
beanstock
beanstock's Avatar
Can you explain to me what a magnum intake is? What it came off of and so on. Pretty cool intake.,A magnum intake has the larger ports and used the large base two barrel whereas the non-magnum had baffles and a small base two barrel. Magnum intakes would have been on Magnum engines...351M, 401, 478 and others.
so,let me see if i understand, when you got the truck it already had the magnum
engine swaped in for the orginal 305 E, then you had the intake milled down for the adatper plate so a 4 bbl could be fitted.??
Old 05-24-2016, 10:07 AM   #192
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Excellent Intake mods! TJ, you'll be the forum's V6 guru in no time at all.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
Old 05-24-2016, 09:15 PM   #193
TJ's Chevy
TJ's Chevy's Avatar
Nope, The engine had the original 305E swapped for a later model 305E. I bought the magnum intake off of a guy with a 351E and modified it and put it on my 305E.
Old 05-24-2016, 09:16 PM   #194
TJ's Chevy
TJ's Chevy's Avatar
Thanks Man! I don't know about that. lol But I sure do love these beasts!
Old 05-25-2016, 01:42 PM   #195
61K10
61K10's Avatar
For a young man your age you already have the 6's down patt! You remind of myself at your age. It's funny if you are interested in something, all the info remains in your head for some reason lol. Great info TJ--nice work.
Kimble
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-25-2016, 02:41 PM   #196
TJ's Chevy
TJ's Chevy's Avatar
Kimble
Thanks Kimble! Yeah, straight 6's and the GMC V6's have had my interest for awhile. Mainly because you don't see them to often and because you can do mods that require fabrication rather than just purchasing stuff from Summit. Love fabricating; so making my own 4 barrel intake was a blast.
Old 05-31-2016, 12:10 AM   #197
TJ's Chevy
TJ's Chevy's Avatar
Well we have a running and driving video finally! Unfortunately I couldn't do a good acceleration test because I was holding the camera. Much easier to have someone else holding it while driving. lol But it's way better than stock no the less. She tows better to! hauled a fairly heavy load of wood Saturday and she done good! Later guys!
Hey brotha, You mind doing Bomp's video trick for me? lol Or re-sending me the how to? I'm still cornfused. haha!
https://www.youtube.com/watch?v=Gjpfx4YZzoY
Old 06-04-2016, 04:16 PM   #198
TJ's Chevy
TJ's Chevy's Avatar
Well Crustine did another job well done this morning! Hauled a couple loads of fire wood...load on bed and trailer. That 305 V6 pulled with ease. Can't believe people complain about these! And if ya take some time and do a 4 barrel mod and dual exhaust things get even better!
Old 06-04-2016, 05:53 PM   #199
ChrisDollins
ChrisDollins's Avatar
Love seeing the old trucks put to work! Intake mod is really cool!
Chris
ChrisDollins is offline   Reply With Quote
Old 06-04-2016, 05:54 PM   #200
TJ's Chevy
TJ's Chevy's Avatar
Chris
Thanks Chris!
