#4076 |
Re: Restoring Rusty
That's about right for a stock pump, usually just under 6 psi. Performance pumps can be 7-9 psi.
#4077 | |
![]() Join Date: Aug 2014
Re: Restoring Rusty
here I made a video of it, please take a looksee Mr. Gasket Inline Fuel Pressure Gauge in Action Video |
#4078 |
Re: Restoring Rusty
It's ~averaging~ 6psi.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
#4079 |
Re: Restoring Rusty
I thought on edelbrock carbs they were happier around the 4-5 psi marking or they could flood themselves?
#4080 |
![]() Join Date: Sep 2015
Re: Restoring Rusty
this is true to my knowledge but he has a holley I don't know what they like though any input anyone?
"Orange Crush" |
#4081 |
Re: Restoring Rusty
so just to remind everyone I am still trying to track down / eliminate that mystery engine ticking sound, and trying Marvely Mystery Oil additive (did not fix a thing) so I ordered a brand new GM Chevrolet Performance fuel pump as some suggested it may be my old fuel pump making that sound
Part Number: 12355612 Last edited by Gregski; 06-10-2016 at 02:22 AM. |
#4082 |
Re: Restoring Rusty
this is my cheapie generic no name brand old one
not sure this looks like normal wear on the shaft lever thingie, we shall see |
#4083 |
Re: Restoring Rusty
the new fuel pump is very well made (in the USA), here I have it installed for a trial fit
as you can see with the outlet at 9 PM it goes right into the motor mount, the inlet at 3 PM is fine, but they move together, so looks like will have to re clock it (this is very similar to re clocking and alternator) it just means moving the connectors around it also sits way too close to the passenger side motor mount, I think it touches Last edited by Gregski; 06-10-2016 at 02:22 AM. |
#4084 |
Re: Restoring Rusty
re clocking this fuel pump is pretty easy, you just have to undo the 10 screws and rotate the base over which ever way you need it, I am going to try an Inlet at 7 PM and Outlet at 1 PM, type a setup, since the inlet and outlet pivot together your choices are somewhat limited, for instance 6 pm works for the Inlet but that puts the Outlet at noon and straight into the base of the block, not gonna work
#4085 |
Re: Restoring Rusty
and here's a mandatory side by side comparison
old fuel pump vs new fuel pump, notice how the cheap one on the left (1/5th the cost) comes with both an inlet connector, where as the more expensive one does not, LOL |
#4086 |
Re: Restoring Rusty
so I had to go out and buy a bunch of different fittings, one of these ought to work
I am running 3/8th from the fuel tank to the fuel pump and 5/16 from the fuel pump to the carb you really wanna check these fittings in the store as some folks put the wrong ones in the boxes (ask me how I know, lol) very frustrating late at night as you're trying to slip that hard 5/16 fuel injection line over the 3/8th barb that should have been 5/16th, ha ha |
#4087 |
Re: Restoring Rusty
so lets try this setup, a 90* elbow in and a straight shooter out
#4088 |
Re: Restoring Rusty
man this just aint gonna work CLEARANCE, CLEARANCE, CLEARANCE problems
even after I shoved a philips screw driver in the 90* inlet to bend it some more it still hits the motor mount support bracket and underneath the motor mount hits/rubs against the fuel pump man I really don't want to start grinding on this beautiful brand new fuel pump to get it to fit, it's just too big, the diameter or circumfrence however you look at it wonderin' if anyone on this forum is actually runnin' this GM fuel pump on their trucks? Last edited by Gregski; 06-10-2016 at 02:11 AM. |
#4089 |
Re: Restoring Rusty
picked up this handy fuel delivery system at the Dollar store, part number K&M 1, (get it, Katchup & Mustard 1) I crack myself up
I use the red one for gasoline it works great when you need to fill up the carburetor bowls through the vent tubes, top tip (the yellow one is for mustard, duh, JK) |
#4090 |
Moderator
![]() Join Date: Oct 2008
Re: Restoring Rusty
One of the annoying things about the GM performance rebuildable mechanical pumps is the inlet and outlet are 180° apart and it's difficult to get them clocked so they don't interfere with something.
GM 12355613, the one you have, is 9PSI at 115GPH with 1/2NPT fittings. GM 6415325 is 7PSI 30GPH with a slightly smaller diameter body with 1/4NPT fittings. Holley makes a rebuildable mechanical smallblock fuel pump that allows you to clock the in and out fittings independently from eachother for about the same price point as the 12355613 GM Performance pump. Holley 12-327-11 is 6.5-8PSI and 110GPH with 3/8NPT fittings
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#4091 | |
Re: Restoring Rusty
#4092 | |
Re: Restoring Rusty
#4093 |
Re: Restoring Rusty
A regular ole AC Delco 40987 is all that's needed for your application.
https://www.summitracing.com/parts/ado-40987 |
#4094 | |
Re: Restoring Rusty
#4095 |
Re: Restoring Rusty
so Mr. Money Bagz over here decided to drop $85 bucks on yet another "Performance" fuel pump (and I use that term loosely, as any company that has to tell you their part is a "Performance" part three times on the front of the box alone, is most likely not selling you an [ahem] Performance part
so here is the Holley part number 12-834 fuel pump Made in Korea (well, than it's gotta be good right?!) ha ha - didn't notice that in the store when I bought it, I was blinded by the shinnyness of this darn thing I believe the line on the back of the box should read: "Look Out for These Other Holley Performance Products" man I am on a roll today Last edited by Gregski; 06-11-2016 at 12:21 AM. |
#4096 |
Re: Restoring Rusty
once when torquing a holley fuel pump on (last fall) the housing cracked..... complete garbage that thing was hope you have better luck
"Orange Crush" |
#4097 |
Re: Restoring Rusty
OMG - Sooooo True it feels like something I picked up at the Dollar store, feels so cheap bro, I am so glad someone else said it
#4098 |
Re: Restoring Rusty
Fuel Pumps ~ collect them all!!!
or as I like to call 'em: Moe, Larry, and Curly ... am I dating myself here people? |
#4099 |
Re: Restoring Rusty
No Greg your not........... your married to yourself with a nice roommate
"Orange Crush" |
#4100 |
Re: Restoring Rusty
and once again the [ahem] Performance part does not come with any inlet or outlet fittings, and naturally the Holley uses a different size (1/4 inch pipe thread rather than the 3/8ths like the GM one did)
not the inlet and outlet ports are not 180* opposite each other like on the GM fuel pump, which is an application limiting feature, in other words an Epic Fail, I'm looking at you GM not sure if there is any Top Gear fans here (yes the UK version not the American rubish) well anyway one time they were talking about a Porsche not sure which model, (or a Volkswagen as Jeremy puts it, ha ha) and they said the base model with run you $60K and comes with AC (or climate control as they call it), Blue Tooth, and a radio, where as the "Sports" model, aka the performance one costs $80 (so $20K more) and has no AC, no Blue Tooth, and no radio... ha ha, so you pay more to get less, loved that episode!!! |
