![]() Join Date: Jan 2001
$$$ Toyotas
I'm very frustrated this afternoon with my wife's 2008 Highlander Hybrid. The display panel has been showing a VSC/Brake error for a while, and the code it throws is the brake accumulator/ABS actuator. After doing a lot of searching online, I was able to find a replacement for $2,000. I also had to pay for Toyota Information Systems ($55 for 2 days) so I could bleed the brakes once I had it installed (yep, need a computer to bleed brakes).
After replacing the actuator and downloading the software, it asks me for a registration key. My account information won't allow me to register, and, of course, it's Memorial Day weekend so there's no tech support until Tuesday (after my subscription expires). And did I mention that I need to use the computer to bleed the brakes? It really makes me appreciate the simplicity of my Blazer. |
Re: $$$ Toyotas
sorry i'm no help but i feel for ya. i'm having a problem with my wifes rolling computer also.
they should have the cha ching sound when one of those little dash lights start glowing.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
Re: $$$ Toyotas
You had the intelligence and patience to fix it without being a Toyota line tech. Give yourself a pat on the back for that one. I'd make an assumption that there will be a point in time where the majority of the populace will be so reliant on advanced tech, that there will be a 1% of the population that knows how to fix their own stuff.
So congrats - you have made it to the coveted 1% bracket and can now charge a premium for your services. ![]()
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you. |
#4 | |
Re: $$$ Toyotas
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
Re: $$$ Toyotas
Wait until you get the VCS light with the engine light and some other light that comes on at the same time. After much troubleshooting, I found that it was due to my fuel cap not sealing correctly. (Gasket worn). Replaced the cap, disconnected the battery to reset the lights and computer, then had to figure out why my windows no longer worked correctly. That required some youtube help on how to reprogram the window motor sensors. I finally got it done and no more issues. This is my 2nd Highlander and really like it as a commuter vehicle. Good luck on getting yours squared away.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
Re: $$$ Toyotas
I wish it were that simple. The accumulator had an internal leak ($2,000) so I replaced that. Then I had to buy Toyota's Techstream software so I could bleed the brakes ($55 for a 48 hour subscription) plus a new cable to connect the Highlander to Techstream. After 5 hours of trying to reset the computer, I realized that it wouldn't work because the steering angle sensor is not at 0 degrees. One of my daughters curbed the car hard enough to bend the lower control arm a few months ago. I replaced the control arm and had the vehicle aligned. I didn't realize there was a problem until I figured out that the computer uses VSC, ABS, yaw angle, steering angle, accelerometer, and speed information all to determine if it will let you drive it. It's going back to the alignment shop Monday, and then I'll see if I can reset it - after spending another $55 for a 48 hour Techstream subscription renewal.
Disconnecting the battery on the hybrid doesn't erase codes; it can actually cause new codes, like "linear solenoid valve learning undone." |
Re: $$$ Toyotas
Ouch! Good luck on getting yours fixed.
My wife was hugely opposed to anything hybrid, and I tried after many years and makes of Toyotas owned, I was ready to make the jump into hybrid, but she wasn't. After hearing your trials, I think I will stay with the traditional (old) Toyota technology.
Re: $$$ Toyotas
Probably a good call. It's nice when it works, but...
By the way, I counted up the total number of ECMs the Highlander Hybrid has - there are 19. Yep, 19 computers to run this thing. The Apollo moon missions were simpler. |
![]() Join Date: Jun 2012
Re: $$$ Toyotas
Yep.....no hybrids for me. Good luck with yours though
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
Re: $$$ Toyotas
Similiar situation with a friends GMC 1300 miles off warranty---GM said no way --after he got it fixed he sold it and bought a FURD
Re: $$$ Toyotas
Yep, it's a known issue with the Highlanders, but Toyota says it's not their problem.
My wife suggested selling hers. I couldn't sell it without fixing it, and once I've done that I might as well keep it. It goes back to the alignment shop tomorrow. Since they're friends of mine I'm planning to ask them to do the reset procedure on the VSC once they've corrected the alignment, since it was the incorrect alignment that kept me from being able to reset it. I'll let you all know what happens. |
