Old 06-13-2016, 12:45 PM   #1
Oberon67
Wore-out Old Spark Plugs
So Saturday I replaced the spark plugs in my '81 C10 with the 250 inline six. Here's what they looked like... that's cylinders 1 through 6 from left to right.
Now I know that a dry, light-brown deposit means normal operation... but there are limits!
Truck is running somewhat stronger now at low revs, thanks to six new AC/Delcos.
Oberon67 is offline   Reply With Quote
Old 06-13-2016, 01:23 PM   #2
storm9c1
*** That's interesting ***
storm9c1's Avatar
Re: Wore-out Old Spark Plugs
Excessive ash deposits? Is it burning oil? Or using fuel additives? How many miles are on these plugs? I don't see significant electrode wear which leads me to believe these plugs don't have as many miles as the deposits show...
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L
1995 Chevy Caprice 9C1
1994 Chevy Caprice 9C1 #3
1995 Chevy Caprice Wagon #2
1995 Chevy Impala SS
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 06-13-2016, 01:36 PM   #3
Oberon67
"How many miles are on these plugs?"
I don't really know, and have no way to find out. These plugs were what was in the truck when I bought it a few months and 2000 miles ago.
The truck uses a little oil, to the tune of maybe a quart a month. I check it when I get gas. I'm not certain how much is being burned and how much is leaking; I know a little bit is leaking because you can see a little seepage at the oil pan gasket.
I'm not using fuel additives. I am burning 87-octane regular gas with ethanol.
Old 06-13-2016, 04:07 PM   #4
TJ's Chevy
TJ's Chevy's Avatar
Keep an eye on the new plugs and see what the coloration changes to as you put more miles on. My 305 V6 in my GMC burns a bit of oil. Mainly on a hot start up it will smoke a tad and then it's fine. Plugs are burning really clean though. I think mine burned a quart over the duration of 8 months. lol Might try some thicker oil....maybe 15W-40 Rotella and a can of Engine Restore. I did that and it brought the compression up on my old 292 around 20 pounds!
Old 06-13-2016, 04:29 PM   #5
storm9c1
storm9c1's Avatar
With the looks of those plugs, I'd say most of that "lost" oil is being burned. Check those plugs again at the next oil change and see how they look. We need to find out how rapidly the deposits are building up.
Tom
Chevy by day...
Mopar by night...
1969 Dodge Charger
Plus others...
Old 06-17-2016, 01:19 AM   #6
mike16
thats nothing. i finally replaced my '90 camry's origonal plugs after 235k miles. the dealer wanted to keep some for thier wall of shame. my rotor and distributor cap too.
mike16 is offline   Reply With Quote
Old 06-19-2016, 07:50 AM   #7
homemade87
You may want to consider where you buy your gas . There is a reason those places are .05 cents cheaper . They do not put the same additives or any in there fuel the keep things burning clean . I had similar looking plugs ( fuzz looking) and went to a major fuel maker and I did not have that problem again .
The P.O. may have been burning the cheap gas .
homemade87 is offline   Reply With Quote
Old 06-21-2016, 03:05 PM   #8
Oberon67
I consistently put either Shell or Citgo gas in it, and very rarely a tankful of Exxon. I buy my gas on gas-station credit cards, so I'm reliable about that.
Dunno what the guy before me was using.
There is the possibility that these deposits are from burning oil. Oil consumption is low, as I mentioned, but it is using some and at over 100K miles now there could definitely be some getting past the rings. There's no smoke in the exhaust at all, but this truck is new enough to have a catalyst so a little bit of smoke out of the motor would get cleaned up by the time it got to the tailpipe.
The engine runs so well at present I see no need to do a ring job. I'll just put a quart of oil in it a month and drive it.
Old 06-22-2016, 01:37 PM   #9
cdowns
cdowns's Avatar
if this is a lightly used truck like less than a tankfull a month you may want to search out a station that provides nonethanolgas and try that for a few months
