06-02-2016, 08:24 AM | #76 |
Re: The Blazer Train
Long time since I updated this but still working on the blazer. My harness was finally returned and I will spare everyone the details but I had expected a 3-4 week turn around and got my stuff back after about 13 weeks and a few frustrated emails. My ecu was suppose to be tuned for my cam (I confirmed he could get it close before I bought it) and when it came time to flash it I was told he didn't want to do it. The product I received doesn't come with labels just a diagram. In all I got it to work. Not sure if I would do it again.
06-02-2016, 08:30 AM | #77 |
07-12-2016, 01:27 PM | #78 |
07-12-2016, 01:40 PM | #79 |
looks great man good job
07-12-2016, 02:08 PM | #80 |
Really looks nice !
07-12-2016, 02:39 PM | #81 |
Looks great - where in NW Ohio are you from? Looking to go with a LS swap down the road and might hit you up if I have questions.
07-12-2016, 03:33 PM | #82 |
Nice work, I have a 72 Chevy C10 pickup that needs work on the front passenger side of the cab. The rest of the body is cherry. Would you be interested in doing it?
07-12-2016, 04:01 PM | #83 |
Nice did you use the purple,Pink wire coming out the original fuse box? also can i get part # for the headers please
07-12-2016, 08:54 PM | #84 |
07-12-2016, 09:07 PM | #85 | |
http://www.speed-engineering.com/fea...c10-truck.html I used the purple wire for the started like it was originally. I didn't use the hei wire bc it was still the resistor wire. I ran new constant and key power wires. |
07-12-2016, 09:09 PM | #86 |
07-13-2016, 11:11 AM | #87 | |
07-13-2016, 04:36 PM | #88 |
There is a spot on the stock fuse box for ignition on power. That's what I used for my hei unit. Just takes a blade connector and I used a 8 guage wire I believe. Been going like that ten years now.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
07-13-2016, 04:53 PM | #89 |
That would be the thin pink wire that is used to power up the dist.
07-13-2016, 05:55 PM | #90 |
I ran my own wire from there to the distributor through the firewall. I melted that fusable link pretty quick On the stock wire to the dizzy when I first ran my hei.
07-13-2016, 06:13 PM | #91 |
Ok....that pink wire gets hot quick thats why i wanted to know how everyone else hooks up there LS engine to the key power/fusebox
07-13-2016, 07:06 PM | #92 |
I would use a meter to check battery voltage then check the wire to make sure it's keyed power and that your getting enough volts. It might be ok.
07-13-2016, 08:25 PM | #93 |
