07-19-2016, 01:20 PM | #1 |
Finishing Bed Wood with oil: Does it last, Let's just see
I decided to Oil my bed wood. I know there are lots of post on this; but this post is different. This will be kind of a case study for Tung Oil. I never really saw anyone with a 10+ year old bed that was oil finished and how it fared. So here's a post with a, hopefully, searchable title to see the actual wear and tear and needed maintenance. I will attempt to keep this post updated periodically with pics, so perhaps others in the future will have better info for the "Oil or Not Oil" decision.
I you are in the process of oiling bed wood(especially something other than tung) you should post here of your application and some periodic pics of wear results. I was at the Brother truck show a couple weeks ago, lot's of examples of what varnish does! Here's my process and materials. Quick Note: I'm not a Tung Oil evangelist! It's what I choose, so I'm just going to give honest info on the end results... whether I have to eat crow or not! If my process turns to $hit in 5 years, you will see it here! You will see how it weathers and when it weathers. I've had good luck with this type of Oil though(there, that statement just solidified it, it going to *ell in a hand basket) Materials: Yellow pine bed wood kit. Pure tung oil. Turpentine. Why I chose Tung Oil. I think tung oil will give better protection for water then blo(boiled linseed oil) blo has additives for drying, but so does most tung sold as exterior use oil. I don't really pay attention, interior exterior, pure tung is pure tung. Safety Note: Learn about drying oils and how to avoid starting a fire in your shop! Here's what I did. Sanded with a heavy hand using 200 Coat 1: 50/50 tung oil and turpentine. I mixed in a jar and applied with foam applicator. Rubbed down after about an hour. Coat 2: Hit it lightly with 200. applied 75/25 oil/turpentine. rubbed down after about and hour. Coat 3: Hit with 0000 steel wool. Used a condiment dispenser from walmart to squirt a bead of straight oil along the boards, spread with foam applicator. Rubbed down after a few hours with cotton cloth. Coat 4 -8 same as above, except I only used steel wool on the spots that looked like they needed it. Last coat no steel wool and a very light wipe down. But the bottom of the boards I did not rub down. Plus I baked the boards bottom side up in the driveway on a couple 100 degree+ days, after the 4th coat. So I slathered the bottom and sides then baked. It will dry with a nice layer. When I got to coats 6-8 on the tops(when I was doing top only) I did not bake in driveway. Just cracked the front and rear garage doors and got a good convection going. I also blotted the end grains heavily with the applicator each time. The ends ate up the oil pretty good cut and straight. My last coat of tung oil was applied almost three weeks ago. I couple days before I installed the wood. Tung Oil Dries sloooooow! But it will get hard... some day! Patience is a virtue with tung oil! July 2016 3 weeks in So here's the first progress report: The truck has been in the sun for three days straight. The bed wood is still slightly tacky, but that's OK, I laid it on pretty thick especially the last coat. I'm thinking if this weather keeps up I'll have it hardened in another couple weeks. It was under a tree for a bit over the weekend. The leaves and dust swept out fine, it's tacky not sticky; so everything does not stick to it like fly paper. Tacky not sticky, if that makes any sense. I'll post again at any next major event worth logging!
White K20 |
07-19-2016, 02:34 PM | #2 |
Re: Finishing Bed Wood with oil: Does it last, Let's just see
That looks great! I wish my truck still had a wood bed....
07-20-2016, 01:22 PM | #3 |
Someone trolled a wood bed being oiled post? Kinda wish I'd seen that, I can't imagine.
Is it still continuing to dry? I'm 5th generation paint/hardware store and I've never heard of Tung oil, though I've sold a lot of linseed oil in my lifetime. How long does it take to fully harden? I mean is it days, weeks, or sometime next year? It hardens on exposure to air, but how long it takes I have no idea...
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
07-20-2016, 02:39 PM | #4 |
That looks perfect!
Did you select each piece of wood yourself at the lumberyard and then fabricate the boards or was that a bed wood kit? If it is a kit which brand? I think you did the right thing choosing the Tung oil. Here is a cut-and-paste of the first paragraph of the wiki about oil polymerization as a refresher for others who might be interested: ******************* A drying oil is an oil that hardens to a tough, solid film after a period of exposure to air. The oil hardens through a chemical reaction in which the components crosslink (and hence, polymerize) by the action of oxygen (not through the evaporation of water or other solvents). Drying oils are a key component of oil paint and some varnishes. Some commonly used drying oils include linseed oil, tung oil, poppy seed oil, perilla oil, and walnut oil. Their use has declined over the past several decades, as they have been replaced by alkyd resins and other binders. Since oxidation is the key to curing in these oils, those that are susceptible to chemical drying are often unsuitable for cooking, and are also highly susceptible to becoming rancid through autoxidation, the process by which fatty foods develop off-flavors.[1] Rags, cloth, and paper saturated with drying oils may combust spontaneously (ignite) in a few hours as heat is released during the oxidation process ****************** |
07-20-2016, 02:58 PM | #5 |
I believe your truck bed looks fantastic. I'm well aware of tung oil as my grand parents used it all the time to refinish furniture. I need to do my bed in the future and am also thinking of using Pine. I know the beds, wood & strips both were painted from the factory, but the finish looks great. Did you paint the strips? It's hard to tell in the pictures. I'm anxious to see how it does over time. Thanks for taking the time to write this article and posting the picture.
07-20-2016, 03:07 PM | #6 |
looks excellent , I think mar kay did an evaluation of many finishes , and reported on it on their site
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
07-20-2016, 06:35 PM | #7 | |
White K20 |
07-20-2016, 06:39 PM | #8 | |
White K20 |
07-20-2016, 06:44 PM | #9 | |
White K20 |
07-20-2016, 06:47 PM | #10 |
I did not see anything about oil on Mar-K so I posted this. I hope someone puts up a BLO bed too. We could compare and contrast in this thread.
White K20 |
07-20-2016, 07:51 PM | #11 |
The Older Generation
I used a Danish Oil Finish on the wood for the 4x4 Longhorn. I went out to the shop to check on the brand name but I couldn't find the can.... You would understand if you saw my shop...... Anyway, I had a head start on my finish because the wood was cut from old power poles. It has been finished for about a year but I just started driving the truck this spring to work the bugs out of it. We shall see what it does. LockDoc
07-20-2016, 07:57 PM | #12 |
Who is that young man working on the bed ?
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
07-20-2016, 08:32 PM | #13 |
That's my Grandpa.......(I wish) LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-21-2016 at 09:46 AM. |
07-20-2016, 08:36 PM | #14 | |
White K20 |
07-20-2016, 10:39 PM | #15 | |
LockDoc
07-21-2016, 06:56 AM | #16 |
lol I wish my Grandpa was here also, he loved old cars and trucks. We would be having a blast together building these old trucks
07-21-2016, 07:14 AM | #17 |
Both the beds shown look great!
07-21-2016, 11:52 AM | #18 |
I'm not a wood bed fan, usually skip over threads about them, and as such hadn't seen a wood bed in a white truck. Until today. Wow. That is gorgeous!
07-21-2016, 12:08 PM | #19 |
Both beds look great! I love how the grain comes out in both.
I have used Lynn Seed Oil on a few period correct jobs that the customer said thats what they used back in the 50s. it looks great but I usually have to sand and re finish it every 2-3 years. kyle |
07-22-2016, 06:50 AM | #20 |
Any oil will leach out in time and need more coating. The thing is, it gets deeper the more you do and it will never scratch or peel. You just clean and re-apply. You can sand if you want to keep smooth or let it age with time without the rot. For a work truck a great oil is used motor oil thinned with kerosene. Ever seen oil soaked wood blocks in the shop or an old wood shop floor? That stuff couldn't absorb water if it wanted to.
07-22-2016, 07:04 AM | #21 |
used motor oil has many purposes, Grandpa used to use it to keep the dust down in front of our house
10-31-2016, 03:36 PM | #22 |
Here's an update on the Tung Oil. As said I will post as I do anything to the wood. I put another coat of oil on the wood a week ago. The wood did not look like it needed any oil. But I set out to put on another coat so, I did so.
Took about 15 minutes! Two week ago in anticipation of the applying more oil, I got out the can of white rustoleum and touched up some scratches in the bed strips and wheel wells. I did not tape, just touched up with a foam applicator. The following weekend, last weekend I applied the oil. I squeezed oil onto the wood from a condiment container. Then used a green scotch brite pad to spread the oil. I used light pressure. Then after a few minutes I wiped the whole thing down with a cloth. Done! What the bedwood has been through since install till this reapplication. I have done a couple projects. One major refurbish or a rental house with lots of demo rubble. I chickened out and put a piece of sacrificial plywood down for protection. But after I finished that project, I used the plywood. And after that the truck bed has been used with no protection. One more minor demo project, and I had two 40gal trees with bare root balls in the bed. Big muddy mess with boots grinding mud into the bedwood. It hosed out fine and I wiped it with a wet wash towel after the hose out to get the ground in mud out. It rained yesterday here so I also included a rain pic of the wood. Current Oiling and three months prior original oiling. Condiment container and scotch brite, only 15 minutes. beads up nice in rain.
White K20 |
10-31-2016, 05:34 PM | #23 |
That looks really good. I was going to do oak and do all the fancy stain and clear. Now you have me rethinking my idea
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
10-31-2016, 05:38 PM | #24 | |
10-31-2016, 10:34 PM | #25 | |
Yes, they were Cedar power poles. The nice thing about it is Cedar is really easy to work with. I am going to get some more pieces of it tomorrow. LockDoc
