#976 |
I'm just glad to be here!
Re: off it goes
Are you using an old compressed door seal (with the latch too) to keep the doors in the correct shut position while your doing the blocking?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#977 |
Re: off it goes
absolutely amazing! I wish my gaps would be half as good as these!
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
#978 |
Re: off it goes
![]() I agree, this area never looks right. The other one is the body line from cab to bed. For some reason the sharp line on the cab goes away right before the bed. These look great in the pic as well. Very nice! |
#979 |
Re: off it goes
all the NOS door rubbers and latches are in for this, we will be putting all the NOS molding on the truck as well before we paint just to make sure it fits right
#980 |
Re: off it goes
thanks for the compliments guys
#981 |
Re: off it goes
#982 |
At the body shop.
Re: off it goes
Sharp line on the cab, and left the seam.
Like it.
" That didnt make it any newer " " Dont antique the equipment " |
#983 |
Re: off it goes
Where is the 3 million "Likes" button....
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
#984 |
Re: off it goes
sharp line will be knocked down to look more factory, just not done yet. Definitely left the roof seam, to fill that seam properly requires removing the inner roof panel and didn't want to get in to that.
#985 |
At the body shop.
Re: off it goes
I started to fill it, my 73 had lead or something that kept catching on fire. So the b pillar got filled and rear was left alone, looks terrible
#986 |
Re: off it goes
yeh most guys just think they can fill it in with weld....but what they forget is that there is a bonding agent in there from the factory that reacts when you try to weld. The only proper way is to remove the inner structure in the cab to get to it, which I didn't want to do, plus I like the factory look of the line...
#987 |
Re: off it goes
![]() I absolutely love this. I have a roll of this metal fabric I was making mini wood grills with. This opened my eyes to new possibilities. ![]() ![]()
I Saw Elvis at 1000 Feet - John Force |
#988 |
![]() Join Date: Aug 2014
Re: off it goes
so are you just thinking rattle can flat black at this point and just be done with it? (JK)
#989 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: off it goes
Looks great since I'd been on last
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#990 |
Moldings are all test fit to make sure the body is perfect.....
#991 |
VA72C10
![]() Join Date: Mar 2008
Re: off it goes
Wow- going to be a stunning truck
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#992 |
Re: off it goes
So stinkin' nice!...
makes my OCD happy |
#993 |
Second Chance Program
Re: off it goes
That is a level of detail that dreams are made of.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#994 |
Re: off it goes
One more blocking to go on the cab
#995 |
Re: off it goes
That is nice <as I wipe the drool off my keyboard>.
#996 |
Re: off it goes
Looking very nice as always. Why the tape and paper in the recessed panels in the back of the cab? To help keep the lines?
#997 |
Re: off it goes
Can not wait to see this truck re assembled.
#998 |
Re: off it goes
[QUOTE=rip2174;7691548]Looking very nice as always. Why the tape and paper in the recessed panels in the back of the cab? To help keep the lines?[/
Thanks for the compliments guys.......paper is in the recessed area because we don't want the filler primer in there, too much work to block those areas that aren't necessary . |
#999 |
Re: off it goes
I like the squared off corners on the back of the cab. Are you leaving that way or going to re-radius that area?
#1000 | |
![]() Join Date: Jun 2012
Re: off it goes
[quote=CHROMAHOLIC;7692233]
