08-16-2016, 01:12 PM | #201 |
Re: "Geronimo" 54' 3100 LS built in PA
I like the color. I love how you are still using the dog crate lid.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
08-16-2016, 07:47 PM | #202 |
Hey 99, enjoying your progress. The blue looks almost like an old Oldsmobile color.
08-16-2016, 07:50 PM | #203 |
Rude dude, I'll have to get the measurement on the moch up bars I used for the front springs.
The color looks more baby blue here in pics. On eastwoods site it looked more navy blue, but yes they do have an olds blue that I really liked. It was a lighter metallic blue. The dog crate is nice for keeping all this grease and oil out of my driveway.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
08-16-2016, 09:31 PM | #204 |
I have pictures in the archives of an AD at a local show almost 15 years ago that was that corporate blue, great color. I took the picture because of that color.
08-30-2016, 09:18 AM | #205 |
8-30
Still working on engine. got almost 33 hrs in tear down, cleaning, painting, and getting crank and 4 pistons in. I always forget how long and tedious this is. If any of you have been down this road, I think you'll agree this small package is full of parts. Just have a look at some of the parts laying in the bed of the truck. So many parts and gaskets. Not to mention sourcing it all. Rings, bearings, timing chain, proper gaskets, water pump, lifters, push rods, balancer, fasteners, oil pump, valve seals and the list goes on. Luckily I already have intake, msd controller and carb. Hoping to wrap up bottom end next week. I have to still clean some parts, paint some parts. Have to get exhaust bolts out of heads, clean them, replace valve seals and reassemble. So hopefully I can rig this up in a couple weeks to do a test fire. Then scramble onto some metal work to try and get stuff painted before it gets too cold.
08-30-2016, 05:44 PM | #206 |
Cool!! Are you making a 4 cylinder V8? LOL
08-30-2016, 09:45 PM | #207 |
haha yah hope I remember to put the other 4 pistons in! don't need no rice burner.
08-31-2016, 01:30 AM | #208 |
nothing wrong with 4 bangers, my 65 was one!
33 hrs in rebuilding an engine you have more patience than me!
08-31-2016, 11:38 AM | #209 |
I guestimated atleast 40hrs in the engine. I think I'll have more than that. I still have some parts to clean and then paint. Then final assembly and hooking up a temp fuel system. Then the start up. The biggest downfall here was cleaning the piston grooves. They had a ton of carbon built up. Been down this road bf but this ate up alot of time. But.... it was still cheaper to clean and reuse than to buy new pistons. If I could find a good machine shop that could do some basic stuff for me, that would be ideal. Seems hard to find around my parts.
But, I enjoy putting engines together and knowing everything is new. This engine supposedly ran yeah sure, had a bad head gasket. So that the main reason why I always tear something down if I haven't driven it. Every single engine I have gotten has had something wrong with it, so the whole tear down was essential anyway.
08-31-2016, 03:17 PM | #210 |
Yup I agree with the tear down. I learnt my lesson with the trans in my '52, shuda done it.
09-11-2016, 09:24 AM | #211 |
9-10 More engine stuff. about 45 hrs on it so far. Got a bunch of little things cleaned and painted, got oil pan and rear main cover done, also valve covers and accessory bracket. Just have to put cam back in, put covers on and then the heads.
I got 4 busted head bolts out. I just weld a nib onto the busted stud, let it cool, weld another nib on it, then put a 3/8 nut on it, weld it up, let it cool, then take out. Tried doing the washer trick first, didn't like it. I need to put the new valve seals in the heads and they are done, oh and coat them with some clear. Rod bearings were all checked and torqued, so its just cam and top end. I have to order a few things so I can attempt to start it up soon. I'll just be starting it with no pulleys hooked up. So a couple minute run time here and there until its in and all put together.
09-11-2016, 10:14 AM | #212 | |
09-11-2016, 04:03 PM | #213 |
yah, clearance is fine since the truck isn't too low. plus I have the engine mounted up a little higher so the headers clear the frame at the flange.
09-11-2016, 06:13 PM | #214 |
Looks good 99, What are you using below the beaker bar while torquing the main bolts, some kind of a degree wheel for stretch bolts?
Thank, Rob
My '47 C.O.E build |
09-12-2016, 11:09 PM | #215 |
You got the motor looking good! Not planning to touch mine until next summer. At least till all of the body work is done. I did get a look inside the crank case of mine when I changed from the GTO oil pan. Hopefully I won't find anything major. . . LOL
09-12-2016, 11:41 PM | #216 |
Rob, its a degree torque tool. Basically LS's technology not only changed in the parts, but the "building" of them. You torque to 15ft lb then to 60* for example.
Tikal48, better to tear down sooner than later. Just never know what you'll need. A spun bearing could spell disaster, broken rings etc. Just never know till you bust into it. Slight and I mean slight chance I may get it buttoned up and try to fire up this weekend. Ordering parts right now. Plug wires, all new coils, fuel pump.
09-14-2016, 12:48 PM | #217 |
learn something every day! I had no idea, I actually just watched a video on it
09-14-2016, 12:59 PM | #218 |
Lots o work, but looking good! I like the Pontiac Blue color too, looks kinda like it in the pics....
My Build: 57 Chevy Pro-Street |
09-14-2016, 04:51 PM | #219 |
thanks guys, yes insane amount of work. I have to find a shop to hot tank the block next time. You can see my method of cleaning parts here. If I can step up to an 80g compressor, I can start sandblasting some stuff. Either way, even if I could shave ten hours it would help, but there is simply just alot of time in putting it all back together.
some more pics of the blue. Wasn't really what I was going for, but it should look good in the engine bay. Going with a tan fire wall and inners. Going to have red spark plug wires along with the msd box. So a touch of red and blue and the tan, should look cool. Really hoping to get the engine atleast almost put back together this weekend.
09-14-2016, 10:13 PM | #220 |
Nice, the tan, red wires and blue engine will be a good look. Moving right along....
09-15-2016, 12:02 AM | #221 |
Ya those colors should look real nice together. Hope you get all your parts and get it together.
09-16-2016, 10:19 AM | #222 |
Little teaser for yinz. Got new coils and awesome 10mm wires. Gonna look good. I got high temp tape coming so I can re wrap the harness for these.
snagged a moch up trans for $20 - credit to CL snagged running boards (little ruff but fixable) - credit CL 100 bucks also bought a trans xmember kit ($40 bucks, not worth the time to build one) and some new LS mounts. The ones I made are good but very tight so there its a bit cumbersome removing and installing engine. We'll see if I make the final move on the new ones.
09-16-2016, 10:34 AM | #223 |
FYI, the best and only thing that will make a dirty aluminum piece look like new is Turtle Wax Rim Clean. Spray it on and let it sit a minute without drying and then pressure wash it off. It works amazing. It will wreck paint and will etch the aluminum if left on too long. I use it on quad engines mostly.
Wade |
09-17-2016, 11:58 AM | #224 |
ssammud, good call man, I'll try that. I loaned my pressure washer out and it blew up.
Def need to get another. Next time I do an engine, I'm hoping to have my blaster working too. I'll try the rim clean on my moch up trans! Im hoping to just get a brand new trans with warranty for this build, so will save me some time cleaning!
09-17-2016, 07:17 PM | #225 |
Yup, load up your trans and do it at the car wash. I guarantee you will be happy.
Wade |
Tags |
1954, ls engine, patina |
