Old 09-15-2016, 02:35 PM   #1
hardwaa
hardwaa's Avatar
1973 Chevy Cheyenne-Super "Holyugacamoly"
Bought this truck from the 2nd owner. It has been painted 1 time on the exterior only. Very clean truck runs and drives Great. 130K miles. 350V8/350Trans truck has had a camper shell most its life.
I LOVE BURNOUTS:metal
NO BOZO's
hardwaa is offline   Reply With Quote
Old 09-15-2016, 02:40 PM   #2
hardwaa
hardwaa's Avatar
Re: 1973 Chevy Cheyenne-Super "Holyugacamoly"
The interior is amazing! I can't get over how nice this truck drives. No rattles or squeeks with out a doubt the nicest square I have ever driven.The truck still had the owners manual in the glove box.
NO BOZO's
Old 09-15-2016, 02:42 PM   #3
phillipm
Nice truck!
Old 09-15-2016, 02:42 PM   #4
hardwaa
hardwaa's Avatar
Under the hood was all stock this truck is really like a time machine.
NO BOZO's
Old 09-15-2016, 02:47 PM   #5
hardwaa
hardwaa's Avatar
The only thing that bugged me about this truck was it was a long bed. So decided to make it a short bed. So I took the bed off and took it to my buddies and we made it a short bed. I have another 76 gmc short bed we looked at both trucks side by side.
NO BOZO's
Old 09-15-2016, 02:55 PM   #6
hardwaa
hardwaa's Avatar
Couple pics from the process. Brooks made a really Nice kit. Uses 12 factory holes for reference. Inner and outer plate bolts together with grade 8 hardware.
NO BOZO's
Old 09-15-2016, 03:02 PM   #7
hardwaa
hardwaa's Avatar
Learned a couple things by doing this.
1. Gas tanks had to be changed. Shortbed tanks are shorter. Picture attached.
2. rear leaf springs are 4" longer after axle compared to short bed. However the frame has factory holes to move rear spring perch 4" forward if desired. I did not change to short bed leaf springs. I can drill new holes for bumper brackets.
NO BOZO's
Old 09-15-2016, 03:06 PM   #8
hardwaa
hardwaa's Avatar
I have driver the truck 20 miles at variable speeds and terrain Kit is solid! I scribed around plates after drive no changes seen. Will be adding some welds because we can. (haha) This pic of truck is after kit installed and driven!!! still needed to cut end of frame
NO BOZO's
Old 09-15-2016, 03:11 PM   #9
hardwaa
hardwaa's Avatar
After cutting rear of frame and putting stock short bed on. Fits perfectly!!
NO BOZO's
Old 09-15-2016, 03:16 PM   #10
hardwaa
hardwaa's Avatar
Next will be getting the truck static dropped, and some new wheels and tires.
Also my buddy Kyle is going to be cutting down the green and white long bed sides making them short bed sides. Cant wait to see it all back together.
NO BOZO's
Old 09-15-2016, 04:39 PM   #11
cochino12
It followed me home?
cochino12's Avatar
Who is Brooks? Couldn't find any info on them
I like the truck
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-15-2016, 06:10 PM   #12
daddyjeep
daddyjeep's Avatar
I have never seen a bolt on kit to shorten the frame. I am glad you are welding it too. Nice truck.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 09-15-2016, 06:20 PM   #13
phillipm
For a lot of reasons a bolt on kit is safer to market and sell to the average consumer. I spoke to Bret the owner of Ride Tech about it at length some years back. He explained to me that from an engineering stand point they are able to account for the strength and load that each fastener will carry and calculate the overall rigidity of that assembly. When you sell a product to be welded you are relying on the field installer and his knowledge of the welding process to create the bond. That is both unpredictable and not smart from a safety stand point. I thought that was an interesting take on the subject.
Old 09-15-2016, 07:09 PM   #14
SCOTI
SCOTI's Avatar
A bolt-on kit is the way to go especially for a novice or someone that doesn't own a welder. One can weld it after initial assembly for additional insurance if desired (if they're skilled & have the equipment or the novice could take it to a shop to get just the welding done).
Nice truck.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-16-2016, 10:44 AM   #15
Westwind
Wow that is really a beautiful truck. Maybe it would be worth the trouble to save the original bed?
Westwind is offline   Reply With Quote
Old 09-16-2016, 01:49 PM   #16
tinydb84
tinydb84's Avatar
I like the truck
Looks up Built by Brooks on Instagram. He works (or used to) over at Porterbuilt. He has a build thread on a one off tube chassis on here. Amazing fab and design skills.
David
Instagram: myfabguy
Old 09-16-2016, 05:00 PM   #17
hardwaa
hardwaa's Avatar
Built by Brooks.
Old 09-16-2016, 05:04 PM   #18
hardwaa
hardwaa's Avatar
Built By Brooks
NO BOZO's
Old 09-16-2016, 11:23 PM   #19
joe231
joe231's Avatar
http://instagram.com/builtbybrooks
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-17-2016, 09:17 PM   #20
hardwaa
hardwaa's Avatar
Took the long bed apart.
NO BOZO's
Old 09-18-2016, 10:05 AM   #21
TrailerTrash
TrailerTrash's Avatar
Thumbs up Re: 1973 Chevy Cheyenne-Super "Holyugacamoly"
Beautiful truck i cannot wait to see it finished. and that woodgrain interior is the cats meow!
how much of a drop are you going with?
- When the Reaper makes his deal, trust in your steel -
'77 C10 350/350 2/4 drop and a mild street engine
TrailerTrash is offline   Reply With Quote
Old 09-18-2016, 10:50 AM   #22
hardwaa
hardwaa's Avatar
Pics.
NO BOZO's
Old 09-18-2016, 10:58 AM   #23
hardwaa
hardwaa's Avatar
Also had a short bed we took apart. Couple pics showing long to short bed floor comparison. Definitely want to do more long to short bed conversions.
NO BOZO's
Old 09-18-2016, 12:26 PM   #24
daddyjeep
daddyjeep's Avatar
It is cool to see see both laid out side by side. So, 14" difference in the front and 6" in the rear?
04 1500 crew cab
Old 09-18-2016, 12:43 PM   #25
hardwaa
hardwaa's Avatar
Yes 14" and 6". I thought it was neat to see a side by side comparison also.
NO BOZO's
