Old 10-03-2016, 08:48 AM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
Wood bed
Hi yall im in the process of re doing my wood on my 65 sb how difficult is it?also is there other options besides wood? Please help.
1966FLEETSIDE is offline   Reply With Quote
Old 10-03-2016, 10:40 AM   #2
Figuarus
Figuarus's Avatar
Re: Wood bed
What are you asking exactly?
Difficulty in installing the oak strips? alternatives to boards?
I used 5/8 plywood because I was missing the rail strips. came out ok I think.
Obviously I still need to finish it with a cap on the end. (I also left the plywood out too long before I used it for this project, hence the slight bowing)
There are people that have used Trex Decking boards, and some that have gone with steel floors from the 75-87 trucks.
It al depends on your resources and the time you want to invest.
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 10-03-2016, 11:34 AM   #3
bpmcgee
bpmcgee's Avatar
Re: Wood bed
66,
It's a pretty easy job once the old material is removed. In terms of materials -- you can put anything imaginable there.
B
bpmcgee is offline   Reply With Quote
Old 10-03-2016, 10:27 PM   #4
Enduro55
Re: Wood bed
Just put in new strips and oak wood from mar - k easy to do
Enduro55 is offline   Reply With Quote
Old 10-04-2016, 08:14 AM   #5
jbgroby
jbgroby's Avatar
Re: Wood bed
Replacing your bed wood is somewhat easy, but it will need to be lifted off the frame (makes the job easier). This will also give you a chance to address any other issues you need to such as painting the rear frame, check and replace any cross rails you need, etc.
I chose to go factory original using plain pine supplied by Mar-K. Their products are first rate and well proven. I followed their recommendation to paint the board black using 2 coats of POR-15 then a top coat of BEHR Exterior Grade Semi-gloss black. (See pictures).
I like it.
jbgroby is offline   Reply With Quote
Old 10-04-2016, 09:08 AM   #6
GWs62
GWs62's Avatar
Re: Wood bed
Agreed. It's not too difficult. It just depends on how much money and time you want to put into it.
When was the last time you did something for the first time?
We never really grow up, we only learn how to act in public.
GWs62 is offline   Reply With Quote
Old 10-04-2016, 09:09 AM   #7
1966FLEETSIDE
Re: Wood bed
Thx so much good info.jbgroby you did an awsome job what does wood retail for$ do you have a link for mark
Old 10-04-2016, 09:28 AM   #8
1966FLEETSIDE
Re: Wood bed
By the way i found link to mar-k thx
Old 10-04-2016, 09:29 AM   #9
trexcompany
Re: Wood bed
Trex decking is noted in the previous post as an option, but the Trex warranty would not cover this type of application. Thanks Trex Customer Experience Team.
trexcompany is offline   Reply With Quote
Old 10-04-2016, 10:11 AM   #10
jbgroby
jbgroby's Avatar
Re: Wood bed
http://www.mar-k.com/index.aspx
This is a link from Mar-K on wood finishing
http://www.mar-k.com/wood_finish_testing_ii.aspx
Old 10-04-2016, 10:12 AM   #11
jbgroby
jbgroby's Avatar
Re: Wood bed
http://www.mar-k.com/final_summary.aspx
Old 10-04-2016, 10:24 AM   #12
The1960APE
The1960APE's Avatar
Re: Wood bed
They really aren't that hard, and the more work you put into the finish the more gratifying the end result!
1965 Olds 442 "Project Oldmobile"
1971 2wd GMC Jimmy..."The Orangutan"
1961 Apache "The Ape"
http://67-72chevytrucks.com/vboard/s...d.php?t=679735
The1960APE is offline   Reply With Quote
Old 10-04-2016, 12:15 PM   #13
idreama300
Re: Wood bed
Beautiful work. That came out amazing!
idreama300 is offline   Reply With Quote
Old 10-04-2016, 12:28 PM   #14
The1960APE
The1960APE's Avatar
Re: Wood bed
Thanks, It needs a good cleaning and final buff but it is kinda neat how it goes with the rust!
Check out the build thread, there are a few things going on that are unique!
Old 10-04-2016, 04:40 PM   #15
forestb
forestb's Avatar
Re: Wood bed
Be careful when deciding that finish to put on it if you are doing wood planks if you are going to keep the truck outside. I used a marine varnish and it tarted pealing in a couple of months. I am now in the middle of refinishing it with a POR product but I am getting bubbles in it and have to sand those down. I would do it a lot differently if I had not already purchased the wood.
forestb is offline   Reply With Quote
Old 10-05-2016, 10:19 AM   #16
Figuarus
Figuarus's Avatar
Re: Wood bed
I second this. Mar-k wrote up a test about different sealers/finishes. they did a final report in june of 2010.
http://www.mar-k.com/june_2010_update.aspx
in the end, paint is the best option, but obviously not as pretty.
2013 Malibu LTZ
Old 10-05-2016, 02:11 PM   #17
DLW
Re: Wood bed
The finish that jbgroby did was one of the most resilient finishes using pine in the Mar-K test. I may do this exact same wood and finish as my truck doesn't sit in a garage and will be exposed to the elements year round.
DLW is offline   Reply With Quote
Old 10-05-2016, 10:21 PM   #18
Praxiss454
Praxiss454's Avatar
Re: Wood bed
I'm looking to go that route in the next couple of weeks here if I can carve out the time to cut some HD common boards into the right shape. The part about that that was confusing to me was the POR-15. Isn't that a metal rust preventative? Why would you put it on wood?
1965 GMC 1000 SWB Fleetside L6 230 - SOLD
Thanks everyone for the help over the years.
Praxiss454 is offline   Reply With Quote
Old 10-06-2016, 07:36 AM   #19
The1960APE
The1960APE's Avatar
Re: Wood bed
I have used a high quality Spar poly on several occasions with great results, I did the wood slab seats on a small fishing boat that stayed uncovered on the water for 3 years until I sold it, it looked the same as the day I applied it when it left home!
Old 10-06-2016, 08:55 AM   #20
jbgroby
jbgroby's Avatar
Re: Wood bed
The kiln dried pine absorbs the POR-15 into the grain a touch and then hardens, once you top coat, once you top coat it with paint to protect it from UV light (sun) it becomes near bullet proof😉.
Old 10-06-2016, 12:19 PM   #21
forestb
forestb's Avatar
Re: Wood bed
They have many different products. The transparent (emphasis on transparent) coating that worked the best in the mar-k test was a "POR-15 Pelucid" which they no longer sell. When I called por-15 they told me that the product they substituted it with is POR-15® 2K Urethane. That is what I am going to try. So far it looks good with no stain and no undercoat. Except for some bubbles that I have to sand back because I applied it when the whether was to hot and humid.
Old 10-06-2016, 01:22 PM   #22
Clyde65
Clyde65's Avatar
Re: Wood bed
I did the Mar-k thing as well but used Oak. Looks great after a couple years under a carport in the Texas heat
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-07-2016, 08:56 PM   #23
Willie 66
Re: Wood bed
I used a couple coats of spar varnish over pine. No stain, but I like the natural look a lot. Mine is garage kept since my DD won't fit in the garage and the HOA would have a fit if I left it in the driveway. The boards and finish don't cost much, it's mostly the time and patience it takes to finish properly. My crossmembers were all rotted, and I was lacking bed strips and hardware, so mine actually ended up costing a lot...
Willie 66 is offline   Reply With Quote
