07-19-2015, 12:32 PM | #76 |
Re: C20 lowered pictures
Yes sir, stock front springs & shocks with drop spindles & it rides great.
07-19-2015, 01:22 PM | #77 |
The reason I ask is I have a 1970 suburban c10 I just installed the 4inch HD by cpp in the rear an mine looks lower than yours in the rear now the front sits like an 1ich or inch an 1/2 taller. The guy at cpp told me to drop the front 3inchs an it should b close. I believe the c20 set taller than the c10 ? What size rims an tires are you running? The reason I as all this is cause I'm going to be towing my travel trailer it's about 3,000 lbs an I don't want to b to low
07-19-2015, 02:07 PM | #78 |
I'm running 16" wheels all around & yes the c20s sit higher than the c10s
07-19-2015, 02:13 PM | #79 |
Either run air shocks or air "helper" bags that go inside the coil springs when towing
07-19-2015, 05:40 PM | #80 |
Anyone have a GMC or Chevy with heavy duty suspension lowered, 8 lug? I have a 72 GMC 2500 with leaf springs rear. Would love to find a simple kit without having to replace every part? Hate to sell her as she is in great shape
1972 GMC 2500 2007 Chevrolet Silverado 1500 |
07-19-2015, 09:24 PM | #81 |
07-19-2015, 09:31 PM | #82 |
07-20-2015, 11:34 PM | #83 |
My Spoon Is Too Big
Is this bolt on kit using stock suspension? No grinding or welding?
1972 C20, 03-14-10 Build Thread 2000 Silverado 4.8L, 11-04-13 (Currently Parting) 1999 Silverado 5.3L, 07-07-14. (Engine Donor) 2015 Ram 05-20-15 (Daily Driver) |
10-01-2015, 04:00 PM | #84 |
Well I started this thread almost 5 years ago to try and figure out how low to go and then how to achieve that goal.
Here is the before pic. After replacing the coil springs and shocks. 2" front and 4" rear. I used 1/2 ton coil springs because I could not find a reasonable way to get 3/4 ton springs shipped into northern Canada. It rides great and drives wonderfully. And a front corner shot. I also ditched the hub caps and painted the wheels a flat green. The trim rings where always there but with the white shinny wheels and hubcaps they did not show up well.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
10-01-2015, 04:13 PM | #85 |
Active Member
Looks Great ! !.. Love that Color
*K10 SWB. Orange/White *69 Ford F100 21K Actual Miles, 2nd owner in family since new *67 Chevy II RestoMod, Wilwood all around, Heights Pro G front sub,, Shockwave Air Ride, 383cu in etc.. |
10-01-2015, 06:24 PM | #86 |
What he said! ^^^^
01-21-2016, 05:42 PM | #87 |
Northern GMC; I Like the stance! I have a 71 Chevy C20. I installed 2" drop coil in front last spring. I have 4" drop coil for the rear to install this spring. I will soon load a pic of the original stance, current and when I ha E installed the rear
01-21-2016, 05:56 PM | #88 | |
Posted via Mobile Device |
04-04-2016, 04:02 PM | #89 |
Here is mine, 2.5 drop spindles, and 4" drop coils. It has 265/75 16 up front and 235/85 16 in the rear just to get it rolling. Need to change out the rear studs to 9/16 and then decide on some wheels and tires...
04-23-2016, 08:52 AM | #90 |
My lowered, uh.... c10+p30= C20?
3"dropped spindles, spring over rear P30 frame (mostly) |
04-25-2016, 12:29 AM | #91 |
Great truck chuckomatic!
04-25-2016, 12:53 AM | #92 |
Wow! I would love to hear the story on that c10+p30 chuckomatic!
1967 Chevy CST 10 1969 Chevy C/20 Longhorn 1969 K10 Suburban 1972 Chevy Cheyenne Super 10 turned K30 (sold) |
04-25-2016, 07:58 AM | #93 | |
Low mileage 454, TH400, 4.10 14bolt rear, power steering, hydroboost, oil cooler, trans cooler, etc. Put a Gennie shifter in so it looks like it still has a real transmission. I still have room to lower it some more, but those 32inch tall rear tires help calm down that rear gear. Original plan was to switch to regular front wheels/hubs, but I'm diggin those Budd wheels. |
10-07-2016, 12:38 PM | #94 |
I don't know how to edit my previous post... so here is my 70 C20, with 2.5 and 4 drop, 255/65 16 on newer chevy steelies.
10-08-2016, 12:16 AM | #95 |
Nice truck neighbour!
10-08-2016, 07:36 AM | #96 | |
laying low
10-09-2016, 01:07 AM | #97 |
10-09-2016, 02:00 PM | #98 |
Here's my 69 c20. Lowered 3.5 front 5.5 in the back with 225/75r16 tires. Sits almost level.
10-10-2016, 12:14 AM | #99 |
I hear you, while it hasn't snowed yet, I parked my truck for the winter last week.
10-11-2016, 05:48 PM | #100 |
Here is a 3/4 ton that I sold a few yrs. back. spindles ,bags,notch,blocks,etc.
72 C10 suburban, lowered,nice original 55.1 Panel, bagged,old school 56 Panel,ls power,frame up build 72 C30 enclosed car hauler, 454,FI,4L80E |
