Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 08-29-2016, 05:10 PM   #101
ochre 72
Re: 72 Jimmy "Colonel Mustard"
Originally Posted by mcmlxix View Post
Also, here is a bracket for your ECU.
http://www.ironworksspeedandkustom.c...prod/prd61.htm
Thank you very much for the links. Y'all got me back on track with those ideas. I'm working on the 87-91 and the Bronco 2 tanks to see which looks like it will work better. This is the bracket that I was planning on using, but I like the one you posted. it seems more versatile.
http://www.dirtydingo.com/shop/produ...oducts_id=1402
ochre 72 is offline   Reply With Quote
Old 08-30-2016, 05:21 PM   #102
Advanced Design
Advanced Design's Avatar
Hi Ochre, I read through your build and really appreciate the quality work you are doing. The metal repairs completed were really impressive....and the old Chevrolet dealership was very cool. Anyway, enjoyed catching up and will be tagging along.
Advanced Design is offline   Reply With Quote
Old 09-01-2016, 03:05 PM   #103
ochre 72
Thank you very much for the kind words. Jim Davis @ Vintage Metalworks did an amazing job bringing the jimmy back from the dead. Appreciate you being along for the ride. I have already benefited from some great advice here.
David
Old 10-04-2016, 05:58 PM   #104
ochre 72
I really appreciate the links provided. They were a great help. After too much thinking about it, I finally installed the fuel tank.
I used:
31 gallon 91 blazer tank
Vapor worx stainless steel ring that I had the tank cut and welded in at a local fab shop.
AC delco MU1416 - Fuel pump assembly
Precision Z11003 fuel pump pigtail
AC Delco - 10325852 locking ring for fuel pump
Bought a used extra rear cross member from this site and powder coated to match.
LMC- 32-5822 fuel tank straps- for the bottom
Spectra - ST120 straps for the top.
S.U.R&R. 3/8 nylon fuel line with quick connects
I moved everything rear ward and drilled new holes to secure the front & rear cross members.
I modified the straps and had to add a small spacer to the front cross member
Very straight forward install.
I ended up with what I wanted:
A higher capacity tank.
Fuel pump that will provide correct fuel pressure for my LS
Quiet and reliable with no sucking air or having to fill up at 1/4 tank.
Returnless with no filter or regulator on the rail. Just one line running up the rail.The filter is inside the module.
Looks semi-factory and didn't spend close to the expense of an aluminum tank.
Old 10-04-2016, 08:28 PM   #105
gringoloco
A guy with a truck
gringoloco's Avatar
Very nicely done, sir.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-04-2016, 10:36 PM   #106
IronCanine
I'm trying....
IronCanine's Avatar
Ditto. Top work.
IronCanine is offline   Reply With Quote
Old 10-05-2016, 06:38 PM   #107
ochre 72
Originally Posted by IronCanine View Post
Ditto. Top work.
I really appreciate it!
Old 10-10-2016, 01:12 PM   #108
ochre 72
Driveshafts cut, shortened/lengthened, balanced and torqued. New U-joints, slip yoke caps, bushings, new parts in the double cardan joint.
Old 10-10-2016, 01:16 PM   #109
ochre 72
Decided to do some electrolysis to see if I could save some parts. Turned out pretty good. Made my tub too small so I could only do half of the part at a time.
Old 10-10-2016, 01:20 PM   #110
ochre 72
Solution for size change from my filler neck to the larger neck on the tank. Tank was in a different spot. This looks like it will do the trick. Made a template out of a paper towel roll and a local exhaust shop made it for $10.00. I think the small original pipe that got smaller in the S bends was the source of my trouble getting it to take fuel without shutting off.
Old 10-10-2016, 01:37 PM   #111
ochre 72
When I set the body down for a test fit of the filler neck I noticed that the tail pan was hitting my rear cross member. I had to trim a little off.
A little touch up on the powder coat
Old 10-10-2016, 08:31 PM   #112
flashed
I have just caught up with all you have been up to ,got behind due to my wife's sudden death friday .I will come see you as soon as I can.
flashed is offline   Reply With Quote
Old 10-11-2016, 12:21 PM   #113
ochre 72
Man , I am so sorry to hear that. My condolences to you. I can't imagine what you may be going through right now. Prayers for you and your family. I look forward to seeing you as soon as you're able. Please let me know if there is anything I could help with.
Old 10-11-2016, 12:30 PM   #114
ochre 72
Radiator was a little more trouble than I thought, but I am happy with how it fits. The radiator hoses were for a 2004 6.0L and fit with a little trimming.
Old 10-11-2016, 12:31 PM   #115
ochre 72
Most of the brake lines bent and attached
Old 10-11-2016, 09:46 PM   #116
Advanced Design
Great looking work! You have a very nice and clean shop too.
Old 10-12-2016, 11:15 AM   #117
gringoloco
A guy with a truck
gringoloco's Avatar
What radiator are you using? Truck looks super clean--great work
-Chris
Old 10-12-2016, 11:43 AM   #118
ochre 72
Thank you very much.
I went with a heavy duty version for a 72 and bought adapters from O'reilly's for the cooler. The lower retaining brackets needed to be moved out dn re-rivoted for the thicker core and the upper brackets had to be trimmed on the grinder. Another reason I screwed up getting everything powder coated before the test fitting of everything. Live and learn. Thanks for the compliment! Ditto on your build. Now I'm searching for a well fitting dual cooling fan set-up. Every car that comes through the shop that we pull the fans out of get carried over for a test fit.
Old 10-23-2016, 11:19 AM   #119
Lieferson
Lieferson's Avatar
http://www.thehollisterroadcompany.com/MarkVIII.html
quick search found this, might be something to look into??
1970 1/2 ton 4x4 4spd Suburban
1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 10-28-2016, 08:46 AM   #120
ochre 72
Thank you for the link. Looks like that would work. I'm going to look more into it.
Old 11-03-2016, 02:50 AM   #121
mcmlxix
Collector of Projects
mcmlxix's Avatar
Did you look into the Jeep Grand Cherokee fan that fits into the factory shroud? I found a true dual speed (meaning two windings in the motor) version.
MOPAR part number 52079528AD or Dorman part number 620-041
Rich
1972 K5 Blazer CST Click HERE
Old 11-03-2016, 08:41 AM   #122
ochre 72
Thank you. I'll check into that also. Not sure if I will have rrom for the factory shroud anymore. Will dig it out and see.
Old 01-17-2017, 04:04 PM   #123
Bocker85
What size lift did you go with?
Bocker85 is offline   Reply With Quote
Old 01-17-2017, 04:33 PM   #124
ochre 72
4 inch front/ 6 inch rear springs
Old 01-17-2017, 04:47 PM   #125
flashed
Im sorry I have not been by there to see your build ,just too much going on right now .
