![]() Join Date: Nov 2013
I have a 68 GMC K20 and I'm looking for the best 4" lift kit for it. My engine weights 860lbs and I want leafs that will hold up to the weight. any suggestions on what kit to get I was looking at the rough country 4" heavy duty lift kit. also any pics of trucks with 4" lift that are k20?
Re: Best 4" lift for big block V6 GMC and pics?
Hi, I have a 67 Chevy K-10. A few years ago, around 1996 I changed the 1/2 ton springs for 3/4 ton springs along with shocks. this gave me about 2" of lift. Now many years later I am rebuilding the truck again. It is a driver. The front springs have settled 1/2 inch over time. I carefully measured it out before pulling the engine. I intend to build 3" blocks to go between the rear axle and springs. 3 1/2 inch blocks for the front. Then I will figure out what length of shocks I need. The steering will be another issue to get set up as well. I think it will work. I will use new U-bolts too.
I will get you some detailed pictures as I get deeper into it. |
#3 | |
All about them K’s
![]() Join Date: Jun 2014
At the bottom of this article it explains Why front blocks are bad. http://www.fourwheeler.com/how-to/12...-alternatives/
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() Last edited by 57taskforce; 10-27-2016 at 09:23 PM. |
I would give Off-road designs a call. I know they will have a solution for you. I will NEVER buy an off the self lift spring again. yes, you do spend a little more for the springs, but its absolutely worth it, if you don't want your truck to ride like a basketball... or a brick on steel wheels....
I'm not really that concerned with how it rides as much as the springs not sagging from the weighy of the engine. I live near St Louis and there is a place called stl spring I guess I will give them a call or some other places and just get custom Springs.
All about them K’s
In my opinion your better off that way because they can build the springs to your application rather than the opposite.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Tags |
1968 k20 4x4, gmc, k20 |
