Old 11-26-2016, 08:26 PM   #1301
Advanced Design
Advanced Design's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
More floor and I did gusset under the engine mount for additional strength. The crossmember notch weld is still on the to do list.
Advanced Design is offline   Reply With Quote
Old 11-26-2016, 08:28 PM   #1302
Advanced Design
Strapped the fuel tank in to begin running the fuel fill. The 90 degree elbow was just too tall even cutting it down as far as possible. I didn't want to trim any additional as there would be little for the hose clamp to clamp too.
Old 11-26-2016, 08:29 PM   #1303
mongocanfly
mongocanfly's Avatar
Floor looks good Doug...I like the peanut gallery in your shop...nothing like spectators...
mongocanfly is online now   Reply With Quote
Old 11-26-2016, 08:36 PM   #1304
Advanced Design
I asked dwcsr...Dave Hollister Road Company...if a rubber 90 degree would work here. Yes was his quick email response...thanks Dave...and my local NAPA could have it next day.
Here you can see how much I trimmed the steel 90 down. I didn't start trimming on the hose yet....hopefully it will work out.
If not, I am thinking I will fab a 90 degree in the size needed to fit.
Old 11-26-2016, 08:40 PM   #1305
Advanced Design
So I put that fuel fill on pause a bit as I wanted to install the Camaro pan on the engine, then get the powertrain installed in frame again for figuring out the steering.
Yeah, I forgot the Camaro pan was used and I hadn't cleaned it up yet.
Old 11-26-2016, 08:41 PM   #1306
mongocanfly
Is that a fuel grade rubber 90?
Old 11-26-2016, 08:41 PM   #1307
Advanced Design
A few hours in the parts washer cleaned it up pretty well.
Old 11-26-2016, 08:44 PM   #1308
Advanced Design
For the first time I dropped the truck pan to see what it looked like inside.
Old 11-26-2016, 08:50 PM   #1309
Advanced Design
Found a little surface rust in one of the cylinders. It should clean up pretty easy and hopefully I can get back on it Sunday afternoon.
Hey Mongo, yes that is fuel fill hose and was a bit spendy. A good peanut gallery is always fun...though we don't get many visitors out here.
Hope to pick my progress up a bunch this winter! Marc is going to pull way ahead of me in our Burb building competition and I need to get back in the swing of things...
Old 11-26-2016, 08:53 PM   #1310
mongocanfly
Yeah I had to buy some of that fuel filler hose for my ls swap..talk about sticker shock...
Old 11-26-2016, 10:16 PM   #1311
youngrodder
youngrodder's Avatar
Doug
The floors look good. I got back out myself and worked on welding in some floor structure myself.. I having the welder is great. I should have bought one years ago...
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 11-26-2016, 11:22 PM   #1312
mongocanfly
Ooops...
Old 11-26-2016, 11:39 PM   #1313
Advanced Design
Originally Posted by youngrodder View Post
Doug
Marc
Thanks Marc, doing the fab work in these builds sure does make having a welder handy. Glad you have one now. Looking forward to see what you do for your floor.
Old 11-27-2016, 05:56 AM   #1314
RockinKees
RockinKees's Avatar
When you do some things all at the same time, you need a space to rest and just look at what you have made
But I see the chairs are empty, that means you were working on cars?
Just joking
Floors look good!!
I'm sure you'll get the fuelfiller just the way you want it!!
Is that motor a 350 sbc or a LS?
Missed that I think....
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 11-27-2016, 10:07 AM   #1315
Advanced Design
Thanks Kees, that is a 5.3 LS from a 2004 Chevy truck. The truck oil pan hangs below the front crossmember and the Camaro pan isn't as deep, staying about even with the crossmember.
Old 11-27-2016, 10:29 AM   #1316
reaper71
reaper71's Avatar
Looking good Doug, did your Camaro pan come with the pickup,tube and dipstick?
Mark...
reaper71 is offline   Reply With Quote
Old 11-27-2016, 11:10 AM   #1317
Advanced Design
Mark...
It did Mark. A friend bought the Camaro to swap the powertrain into his wagon and used the Holley pan for fitment. I ended up with the pan, dip stick, pick up tube and splash shield.
Oh yeah, that wagon has a new 9" rear from Quick Performance in Ames IA. Really nice set up. Here it is down at my buddy Luke's shop for some metal work around the rear side windows and lower quarters behind tires.
Old 11-27-2016, 01:58 PM   #1318
reaper71
reaper71's Avatar
Thats cool, Quick Performance is a really good co. to work with that's who I used for John's mustang rear diff.
Mark...
Old 11-28-2016, 11:37 AM   #1319
lower50's
lower50's's Avatar
A few more updates like this and you will pull into the lead.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 11-28-2016, 02:40 PM   #1320
99 to Life
99 to Life's Avatar
looks cozy in there. making me second guess jumping back into my cold dungeon this year!!!
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 11-28-2016, 09:48 PM   #1321
Advanced Design
Yeah Mark, I believe the next time I need a complete rear I will give them the business. Reasonable prices and quality parts for sure.
I don't know Lowers...I need a bunch of updates like this. Winter with no yard work will help....I hope.
99, that spot is right under the radiant heater and is very cozy...zzzz...
I was able to pull myself away from the peanuts and cozy spot long enough to throw the now clean Camaro pan on the engine. There is still more work to be done in prepping this engine for paint.
Any slick ideas for removing the last of the engines dirt and corrosion? I plan to continue with Dremel, wire wheels, die grinder with rotary brush, simple green cleaner....lotta elbow grease.
Old 11-28-2016, 11:56 PM   #1322
youngrodder
Cleaning a dirty LS1 brings back some memories..
It's getting there...
Marc
Old 11-28-2016, 11:56 PM   #1323
reaper71
reaper71's Avatar
SUPER CLEAN my man....works a ton better than simple green.
Just my own experience.
Mark...
Old 11-29-2016, 08:33 AM   #1324
lower50's
lower50's's Avatar
and Brake Clean
1951 MG TD
Old 11-29-2016, 10:32 AM   #1325
reaper71
reaper71's Avatar
And before you know it,it will look like this!!!
Of course after Hrs of taping,painting,more tape and more paint...oh and then assembly
Mark...
