Old 11-11-2016, 02:09 AM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Coming right along
Sold the enjected BB put in a LS1 with 6 speed, vintage air and Boyd's aluminum gas tank can't wait to go for a ride
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 11-11-2016, 02:55 PM   #2
Clyde65
Clyde65's Avatar
Re: Coming right along
Nice job!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-11-2016, 05:06 PM   #3
mongocanfly
mongocanfly's Avatar
That'll be fun!!!!!!
Old 11-15-2016, 12:47 AM   #4
ChuckLee
sweet! what are you doing for your shifter? Are you going to relocate the shifter to the forward position on your t56 or keeping it as it is?
What about your clutch pedal setup and clutch master?
LS Swap build thread http://67-72chevytrucks.com/vboard/s...d.php?t=722579
ChuckLee is offline   Reply With Quote
Old 11-15-2016, 01:19 AM   #5
1970 CST Short Wide
Senior Moment
Yes I moved the shifter forward. A little tricky to do but not bad. On Hyd clutch set up see Fabmans post in parts for sale, he has a kick ass set up that works fantastic.
Pittsburg Ca
94565
Old 11-15-2016, 01:27 AM   #6
ChuckLee
Yes, Fabmans setup is very nice. Any chance you can post a picture or two of your shifter setup? Did you buy the front conversion kit (like $300-400) or did you just add some metal to your shifter to bring it forward inside your cab? howabout a clutch pedal setup picture also?
Old 11-16-2016, 11:12 PM   #7
1970 CST Short Wide
Senior Moment
Yes I bought the $400 kit to move it. Found a thread on here that made it a lot easier to do than totally dis assemble the trans. Put stock pedel in , very simple and Bought Fabmans linkage, works perfect. Hopfully pics load
Pittsburg Ca
94565
Old 11-16-2016, 11:17 PM   #8
1970 CST Short Wide
Senior Moment
Trying pics again
Pittsburg Ca
94565
Old 11-16-2016, 11:22 PM   #9
1970 CST Short Wide
Senior Moment
Sorry the pic is Messed up. Fabmans product works fantastic. Mine is modified because I didn't see his before I did mine. We just push from opposed sides. Wish I would have seen his first, it's much better
Pittsburg Ca
94565
Old 11-22-2016, 10:40 PM   #10
1970 CST Short Wide
Senior Moment
Small set back, bleeding the clutch and the slave Cyl leaks like a sieve, pulled trans, waiting on new slave cyl.
Pittsburg Ca
94565
Old 11-28-2016, 01:15 PM   #11
joesscamaro
Who did your engine wiring harness? Any more pics of the progress or finished state?
joesscamaro is offline   Reply With Quote
Old 11-28-2016, 11:37 PM   #12
1970 CST Short Wide
Senior Moment
Hot Rod Harness out of Los Angeles did the harness, fits like a glove, has port for tuning. Just getting ready to set the Rad support and plumb it.
More pics later
Steve
Pittsburg Ca
94565
Old 11-29-2016, 07:25 AM   #13
joesscamaro
Sounds good. What kind of radiator are you going with? F-body radiator?
Old 11-30-2016, 10:16 PM   #14
1970 CST Short Wide
Senior Moment
Working on that now.. I have my 70 originial in there now hopeing to make it work as I just had it rebuilt
Pittsburg Ca
94565
Old 12-25-2016, 09:17 AM   #15
Hart_Rod
Hart_Rod's Avatar
Nice project!
Hart_Rod is online now   Reply With Quote
Old 01-02-2017, 11:00 PM   #16
1970 CST Short Wide
Senior Moment
Up and running on it own power. Fenders and wells back on, temp exhaust hooked up so I can trouble shoot. Getting real close to road worthy. Drove it a little bit, LOVE the power
If your thinking about doing this swap, i say DO IT
Pittsburg Ca
94565
Old 01-02-2017, 11:50 PM   #17
uxdesigner
Nice work! Any pics and info on your Vintage Air setup?
uxdesigner is offline   Reply With Quote
Old 01-05-2017, 10:04 PM   #18
1970 CST Short Wide
Senior Moment
We made a few changes like welding up the fire wall but the install wasn't to bad.
READ the instructions and take your time and it comes out just like they say it will. I still need to buy a compressor but the heat , fan and defrost work perfect.
I'll try and take some pics this weekend
Pittsburg Ca
94565
Old 04-23-2017, 06:12 PM   #19
gringoloco
A guy with a truck
gringoloco's Avatar
Need more pics! How's it going?
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-24-2017, 07:39 AM   #20
ChuckLee
Ditto that. Need more pics! Pics of everything!
Old 04-30-2017, 01:42 AM   #21
1970 CST Short Wide
Senior Moment
Sorry for the late response, Back problems put things on Hold. still need to buy the AC bracket and Compressor to finish Vintage air. Boyd's tank is in just need to plumb it. This thing is a kick in the ass to drive. 1st- 4th around town Yee Haa. 5th & 6th on freeway 80 MPH at ~1750 RPM in 6th, ya got to love it.
More when I can, Thanks for wanting to see more
Steve
Pittsburg Ca
94565
Old 07-14-2020, 04:06 PM   #22
jjzepplin
jjzepplin's Avatar
I can't believe you are driving this around and you just left this thread hangin and no one has asked what's up. Just razzin you because this thread is years old and the last pic has no bed on your truck. HAHA! How about an update on your experiences with the longevity of the build? I have been PM ing you but I just found this thread. I love the close up pic of your clutch setup. This is how I was thinking of doing mine.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 07-15-2020, 12:48 AM   #23
1970 CST Short Wide
Senior Moment
I drive it every day I can. Reliability is great. Just finished coil overs in the rear, wish I could afford the front - Huge improvement.
As far as the swap I couldn’t be happier run around on 90 deg days with AC on temp never gets over 210 which is where LS motors run. Having fun shifting and with the 390 gears in the Ford 9” and Detroit true trac posi Yea Ha
Thanks for asking
Steve
Pittsburg Ca
94565
