Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1947 - 1959 Chevrolet & GMC Pickups Part Board
Old 11-30-2016, 07:31 PM   #26
Oldmoe518
Re: 1957 GMC 4 speed trans and V8 bellhousing
Do you know what the motor came out of ?I think this might be a stupid question but you don't have and extra belly pan ...?
Oldmoe518 is offline   Reply With Quote
Old 12-01-2016, 07:30 PM   #27
Oldmoe518
I have a friend of mine that will be coming home in two weeks .he may pick up the motor and bellhousing and stuff from you ...going to check with him and let you know ...also if he doesn't my other friend is going down to Fla in January for 10 days he said he would definitely pick it up for me ....so one way or another I got a ride for the stuff....
Old 12-02-2016, 12:57 PM   #28
GMCNUT
GMCNUT's Avatar
perfect - tell your Florida bound buddy I am gone the first week of Jan returning around the 9th / 10th so I assume hes traveling later in the month
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 12-02-2016, 01:04 PM   #29
GMCNUT
GMCNUT's Avatar
Engine is from a low miles one owner 1957 GMC 3/4 ton pickup I found on its original farm near Nashville TN. He said he pulled the whole engine and trans because nothing else would bolt up to the great running 347 and he had access to a Buick V8 already coupled to a working trans, so it was far and away easier to slide that whole unit down in there and sell the 347 and Hydramatic. At the time I needed a running known-to-be-good 347 so I drove 3 hrs North and picked it up - later I found another excellent 42K original mileage running 347 in another 3/4 ton truck in South GA and bought it - it was already cosmetically restored and repainted and pretty so I used it instead of the first 347 you are getting. As for the belly pan, the only one I have is bent up off the 336 and not entirely certain what I exactly did with that either....I also have a complete 56 GMC 316 V8 that ran great but seems like she was almost frozen from sitting last time we turned it over.
Old 12-02-2016, 01:16 PM   #30
Oldmoe518
Ok good .....can you send a pic of the motor
Old 12-02-2016, 01:19 PM   #31
GMCNUT
GMCNUT's Avatar
working on that today - I have to run to the neighboring town and will go past my building where its stored and see if I can get a shot of it. Its way back in a dark corner of the bldg sitting on a concrete pad but behind a bunch of truck parts and will be difficult to photograph but I'll try.
Old 12-02-2016, 01:22 PM   #32
Oldmoe518
Ok good
Old 12-02-2016, 01:53 PM   #33
Oldmoe518
Can you send me your address so I can send you some money ..
Old 12-10-2016, 09:36 PM   #34
Oldmoe518
How did you make out with pics ?
Old 12-11-2016, 02:27 PM   #35
GMCNUT
GMCNUT's Avatar
I did finally get pics of the 347 but nothing to write home about - darkness in the building and cramped space made it difficult - as I said, I removed the intake to get to the bellypan and had to steal the distributor out of it, but looks like everything else is there
Old 12-11-2016, 02:31 PM   #36
GMCNUT
GMCNUT's Avatar
Amid being a typically "dirty" engine, everything looks great parts wise - not a lot of build up on anything internal like a high miles engine would have. PM for payment info and I'll get to pulling parts. I'll have to get the mechanics on separating the 347 from its Hydramatic automatic trans, so that could take some time otherwise this stuff should pretty much be ready whenever your people can come by
Old 12-11-2016, 02:40 PM   #37
Oldmoe518
Ok sounds good
Old 12-11-2016, 02:42 PM   #38
Oldmoe518
My email is burkinsandfoley@yahoo.com if you want to send me info ...
Old 12-11-2016, 06:23 PM   #39
Oldmoe518
Use that or I can give you my cell #
Old 12-14-2016, 02:52 PM   #40
GMCNUT
GMCNUT's Avatar
Sending the email now
